Sentences not loaded in hello-Lucy
Hi guys,
It seems my Hello-Lucy module doesnt load sentences, only words.
At least this is my explaination why Lucy doesnt understand me correctly. It seems it only takes words like “who” and “the”, which i can see in the terminal:
So my first issue which leads me to there was, that my Lucy-module wont start until i initialized
var importedSentences="";in Hello-Lucy.js.
So maybe improtedSentences is never filled with the data of sentences.json in Hello-Lucy-Folder.
I got an error with concat on line 69:start() { var combinedSentences = importedSentences.concat(this.lucy.sentences); ....Also i had some problems with module_name var, so i had to change to
Module.register("Hello-Lucy",in line 28.
SO maybe my “localPath” is wrong. Im not sure. Anyone any ideas?/home/pi/MagicMirror/modules/Hello-Lucy -
@nicodil I JUST posted a fix for that
https://forum.magicmirror.builders/topic/14918/hello-lucy-not-shown-no-error/7
@sdetweil Thanks! With your FIX i can now use this line again:
Module.register(ModuleName, {So the ModuleName seems to be found again, BUT
if i dont initialize var importedSentences=“”; in the 2nd line,
i get the following error:
It seems like sentences are still not loaded…
@nicodil I JUST tested and it worked…
in the sources view
find the module and source file (left nav) and put a stop (click the number on the left edge of the line) on line 27then hit f5, refesh page
hover over the variable and expand the array
@sdetweil Thanks for your help! Here are my errors:
@nicodil so it seems u did NOT replace the line as per my instructions
@sdetweil said in Sentences not loaded in hello-Lucy:
But i did, see my code here:
"use strict"; var importedSentences; /** Prepare variable to be populated from import. */ function readTextFile(file, callback) { var rawFile = new XMLHttpRequest(); rawFile.overrideMimeType("application/json"); rawFile.open("GET", file, true); rawFile.onreadystatechange = function() { if (rawFile.readyState === 4 && rawFile.status == "200") { callback(rawFile.responseText); } }; rawFile.send(null); } const sfn= document.currentScript.src.substring(7,document.currentScript.src.lastIndexOf(document.currentScript.src.slice(7).includes('//')?'//':'/')) const localPath= sfn.substring(sfn.indexOf('modules')) const ModuleName=localPath.substring(localPath.lastIndexOf("/")+1) //console.log("localPath="+localPath+" modulename="+ModuleName); readTextFile(localPath+"/sentences.json", function(text){ var tempImport = JSON.parse(text); importedSentences = tempImport; console.log("SENTENCE: "+importedSentences); }); //////////////////////////////////////////////////// Module.register(ModuleName, { icon: "fa-microphone-slash", pulsing: true, help: false, timeout: null, lucy: { mode: "Sprich 'Hello Lucy'", sentences: [] }, modules: [], previouslyHidden: [], defaults: { timeout: 15, // time listening for a command/sentence when mic pulsing defaultOnStartup: "Hello-Lucy", keyword: "HELLO LUCY", // keyword to activate listening for a command/sentence standByMethod: "DPMS", // 'DPMS' = anything else than RPi or 'PI' sounds: ["a.mp3", "b.mp3", "c.mp3" , "d.mp3"], // welcome sounds at startup randomly chosen startHideAll: false, // if true, all modules start as hidden microphone: "default", // speed: 1000, // transition speed between show/no-show/show in milliseconds pageOneModules: ["Hello-Lucy"], // default modules to show on page one/startup pageTwoModules: [], // modules to show on page two pageThreeModules: [], // modules to show on page two pageFourModules: [], // modules to show on page two pageFiveModules: [], // modules to show on page two pageSixModules: [], // modules to show on page two pageSevenModules: [], // modules to show on page two pageEightModules: [], // modules to show on page two pageNineModules: [], // modules to show on page two pageTenModules: [], // modules to show on page two greetingSounds: [ "a.mp3", "b.mp3", "c.mp3" , "d.mp3"], // randomized greeting sounds confirmationSound: "ding.mp3", // when command is accepted. use your own or default debug: true, // get debug information in console }, poweredOff: false, start() { var combinedSentences = importedSentences.concat(this.lucy.sentences); this.lucy.sentences = combinedSentences; //Log.info(`Starting module: ${this.name}`); this.mode = this.translate("INIT"); this.modules.push(this.lucy); //Log.info(`${this.name} is waiting for lucy command registrations.`); }, getStyles() { return ["font-awesome.css", "Hello-Lucy.css"]; }, getTranslations() { return { en: "translations/en.json", de: "translations/de.json", id: "translations/id.json" }; }, // audible confirmation sound that Lucy understood the command playConfirmationSound() { var audio = new Audio(localPath+"/sounds/" + this.config.confirmationSound); audio.play(); }, // randomized greeting sounds playGreetingSound() { var random_file = this.config.sounds[Math.floor(Math.random() * this.config.sounds.length)]; var audio = new Audio(localPath+"/sounds/"+random_file); audio.play(); }, getDom() { //Log.log("lucy entered getDom") const wrapper = document.createElement("div"); const lucy = document.createElement("div"); lucy.classList.add("small", "align-left"); const modeSpan = document.createElement("span"); const icon = document.createElement("i"); icon.classList.add("fa", this.icon, "icon"); if (this.pulsing) { icon.classList.add("pulse"); modeSpan.innerHTML = "Command Please:" } else modeSpan.innerHTML = this.mode; lucy.appendChild(icon); lucy.appendChild(modeSpan); if (this.config.debug) { const debug = document.createElement("div"); debug.innerHTML = this.debugInformation; lucy.appendChild(debug); } const modules = document.querySelectorAll(".module"); for (let i = 0; i < modules.length; i += 1) { if (!modules[i].classList.contains(this.name)) { if (this.help) { modules[i].classList.add(`${this.name}-blur`); } else { modules[i].classList.remove(`${this.name}-blur`); } } } if (this.help) { lucy.classList.add(`${this.name}-blur`); const modal = document.createElement("div"); modal.classList.add("modal"); this.appendHelp(modal); wrapper.appendChild(modal); } wrapper.appendChild(lucy); return wrapper; }, notificationReceived(notification, payload, sender) { //Log.log("lucy module notification received="+notification) var self=this; if (notification === "DOM_OBJECTS_CREATED") { //Log.log("lucy module sending start") this.sendSocketNotification("START", { config: this.config, modules: this.modules }); } else if (notification === "REGISTER_LUCY_MODULE") { if (Object.prototype.hasOwnProperty.call(payload, "mode") && Object.prototype.hasOwnProperty.call(payload, "sentences")) { this.modules.push(payload); } } // randomly chosen startup greeting if (notification === "DOM_OBJECTS_CREATED") { this.playGreetingSound(); } // @TheStigh to manage hide/show modules on startup if (this.config.startHideAll) { if (notification === "DOM_OBJECTS_CREATED") { MM.getModules().enumerate((module) => { module.hide(1000); }); } } if (notification === "DOM_OBJECTS_CREATED"){ var showOnStart = MM.getModules().withClass(self.config.pageOneModules); showOnStart.enumerate(function(module) { var callback = function(){}; module.show(self.config.speed, callback); }); } if (notification === "DOM_OBJECTS_CREATED"){ var showOnStart = MM.getModules().withClass(self.config.defaultOnStartup); showOnStart.enumerate(function(module) { var callback = function(){}; module.show(self.config.speed, callback); }); } // to show page one on alert @TheStigh if (notification === "SHOW_ALERT") { var showOnStart = MM.getModules().withClass(self.config.pageOneModules); showOnStart.enumerate(function(module) { var callback = function(){}; module.show(self.config.speed, callback); }); } }, socketNotificationReceived(notification, payload) { if (notification === "READY") { this.icon = "fa-microphone"; this.mode = this.translate("NO_MODE")+ "'Hello Lucy'"; this.pulsing = false; } else if (notification === "LISTENING") { this.pulsing = true; } else if (notification === "SLEEPING") { this.pulsing = false; } else if (notification === "ERROR") { this.mode = notification; } else if (notification === "LUCY") { for (let i = 0; i < this.modules.length; i += 1) { if (payload.mode === this.modules[i].mode) { if (this.mode !== payload.mode) { this.help = false; this.sendNotification(`${notification}_MODE_CHANGED`, { old: this.mode, new: payload.mode }); this.mode = payload.mode; } if (this.mode !== "LUCY") { this.sendNotification(`${notification}_${payload.mode}`, payload.sentence); } break; } } } else if (notification === "HIDE_MODULES") { this.playConfirmationSound(); MM.getModules().enumerate((module) => { module.hide(1000); }); } else if (notification === "SHOW_MODULES") { this.playConfirmationSound(); MM.getModules().enumerate((module) => { module.show(1000); }); } else if (notification === "DEBUG") { this.debugInformation = payload; } else if (notification === "MODULE_STATUS") { this.playConfirmationSound(); var hide = MM.getModules().withClass(payload.hide); hide.enumerate(function(module) { //Log.log("Hide "+ module.name); var callback = function(){}; module.hide(self.config.speed, callback); }); var show = MM.getModules().withClass(payload.show); show.enumerate(function(module) { //Log.log("Show "+ module.name); var callback = function(){}; module.show(self.config.speed, callback); }); } else if (notification === "MODULE_UPDATE") { this.sendNotification(payload); //console.log("sendNoti received :"+payload); } else if (notification === "CLOSE_HELP") { this.help = false; } else if (notification === "OPEN_HELP") { this.help = true; } this.updateDom(300); }, appendHelp(appendTo) { const listLabel = document.createElement("div"); listLabel.classList.add("medium"); // heading for help screen listLabel.innerHTML = `${this.translate("Lucy Commands")}:`; appendTo.appendChild(listLabel); const list = document.createElement("ul"); for (let i = 0; i < this.lucy.sentences.length; i += 1) { const item = document.createElement("li"); list.classList.add("xsmall"); item.innerHTML = this.lucy.sentences[i]; list.appendChild(item); } appendTo.appendChild(list); } }); -
@nicodil ok, are you using https for mm?
can u stop on the sfn= line and hover over the src
I just need to see the beginning of the string
@sdetweil Yes sure:
AND No file in this folder:
@sdetweil Yes, i posted it in both folders, to get sure:
It looks like it is reading now the sentences.json. Im not sure why, the error was not shown anymore after a few restarts and changes.
BUT still Lucy understands only nonsence, only the words in the words.json…
The Array of the sentences is there, like in your picture, so it is read.She still cannot understand “Show modules” or “Hide Modules”, only words like “the”, “who” , …
Any idea?
@sdetweil Your changes creating some errors for some reason. Exactly the same line (15):
@nicodil Mykle has updated the repo
so you can git pull to update
but u need to restore the file first
in the module folder do
git checkout HelloLucy.jsthen
git pull -
Hi @sdetweil ,
im sorry to say that but this is an error after the Update.
@nicodil ok, so you will have to go into the developers window to help me
ctrl-shift-i
select the sources tab
find the module in the left nav, and Hello-Lucy.js
and click the number on the left column
for line 15 var sfn=then hit f5 refresh
it will stop at line 15, then using the mouse hove over the .src of document.currentSrc.srctake a screen shot of that
Thanks for your time and help!
@nicodil ok, then tap the button next o the blue arrow >
then hover over sfn
then put stops on line 9 and 22 and hit run (blue arrow)
It works fine when i dont load the RemoteControl, no error -Module… But the error with the RemoteControl is pointing to line 15, thats strange…
