    Magic Mirror on Rancher
    13 Posts 4 Posters 4.0k Views 4 Watching
    • WmsmckayW
      Wmsmckay @sdetweil
      I’m connecting from a device on the same network that the server is running on.
      Are you just wanting a network diagram?
        sdetweil @Wmsmckay
        @wmsmckay so u have a docker container, app running on address:“0.0.0.0”, port??? exposed on the server as port?? and the firewall on the server allows access for outside the server.
        if u run a default http server container on that same server, can u access from the other system?
        WmsmckayW 1 Reply Last reply
        • WmsmckayW
          Wmsmckay @sdetweil
          @sdetweil I have a VM running Rancher, Kubernetes and Docker at 10.0.0.16. I deployed a service running the Magic Mirror image from that on port 8075. When I navigate to 10.0.0.16:8075 I get nothing.
          I have other service running on the stack that I can reach just fine e.g. pihole, mysql databases, a web server.
            sdetweil @Wmsmckay
            @wmsmckay the container cannot use it’s host address directly
              sdetweil @Wmsmckay
              @wmsmckay so mm config inside the container says port 8080, address:“0.0.0.0”, ipWhitelist:[]
              and u map that to 8075 on the host
              • WmsmckayW
                Wmsmckay @sdetweil
                @sdetweil Corrent. I used the docker image above which maps port 80 in the container to an external port on the host which I set to 8075.
                The config file is set to the default which is
                var config = {
                  address: "0.0.0.0", // Address to listen on, can be:
                  port: 8075,
                  ipWhitelist: [], // Set [] to allow all IP addresses
                  sdetweil @Wmsmckay
                  @wmsmckay no, inside the container it’s port 80
                  the mapping is done outside, nat translation
                  the app inside doesn’t know
                  app configured to port 80
                  docker does nat and exposes that on the docker host as 8075 (-p 8075:80)
                  this is exactly the same as if u wanted your mm on a pi, exposed to the internet
                  8080 on pi, router says map requests from 8075 on internet to port 8080 on the pi.
                  pi doesn’t know
                  • WmsmckayW
                    Wmsmckay @sdetweil
                    @sdetweil Right. I have that port mapped but when I navigate to host:8075, I just get an error.
                    In my logs it says
                    Ready to go! Please point your browser to: http://0.0.0.0:8075
                    But going to 10.0.0.16:8075 there is nothing there.
                    S 2 Replies Last reply
                      sdetweil @Wmsmckay
                      @wmsmckay but mm needs to be set to port 80, right? that’s what the docker setup does, right?
                        sdetweil @Wmsmckay
                        @wmsmckay you should be able to docker inspect xxxxxx, where xxxxxx is the container id to get the container IP address. typically 172. something.
                        then u can use browser on docker host to the container IP and the mm port.
                        that proves the container config is right for the mm config
                        then you can check the host port, localhost:8075, and the inspect will show u the port mapping definition. should show what is in the compose file
                        then u can go to another machine
                        karsten13K 1 Reply Last reply
                        • karsten13K
                          karsten13 @sdetweil
                          I have been using this docker image and setup to create the container, which works.
                          this docker image is not maintained anymore, meanwhile the image build fails so the image is old without containing security fixes. Also this image does not contain the latest mm version v2.16.0.
                          can you show us this service? kubectl get service <service-name> -o yaml
                          I wrote a helm chart for running mm in k8s, you find it here.
