    Pi 4 B 4GB
    8 Posts 2 Posters 1.2k Views 2 Watching
    • ankonaskiff17A Offline
      ankonaskiff17 @sdetweil
      @sdetweil Using your setup routine. Answer yes to both questions in your setup.
      Primary culprit is when I’m using Developer Tools. Right now with nothing running but mm, MMM-SystemStatsshows about 30% free RAM.
      When I would have VS Code, terminal, Developer Tools running it would get down around 5% free RAM.
      Not sure how MMM-WeatherChart,MMM-SmartWebDisplayand MMM-Jastimpact things since WeatherChart is using Chart.js , Jast has the scrolling ticker and SystemStats has a pretty quick update rate.
        sdetweil @ankonaskiff17
        @ankonaskiff17 check for swap space
        free -m
        make the swap space bigger
        ankonaskiff17A 1 Reply Last reply Reply Quote 0
          @sdetweil That was way easier than sorting out CSS.
          ankonaskiff17A 1 Reply Last reply Reply Quote 1
            ankonaskiff17 @ankonaskiff17
            @sdetweil I may have accidentally stumbled on what is causing the Pi to slog down.
            Increasing the swap helped but definitely didn’t cure.
            In process of troubleshooting a module by using Dev Tools Console, I noticed a different module, and IMO the module CONTENT is generating something called a Vuex Mutatation. I don’t have a clue what that is about other than it appears tied to the National Weather Service link I am using in MMM-SmartWebDesign.
            I saw the line 304 on index.htmlso I pulled up MM’s index.html and it doesn’t even go that high.
            I’ve heard of Chart.js and Moment.js but Vue.js is a new one for me. See attatched image. Any thoughts, suggestions…
              @ankonaskiff17 Vue is a new programming model. and Vuex is a data persistence library
              all the Vue stuff runs in the browser, so inside the web display… eats cpu cycles where it runs
                @sdetweil Anything to be done for it? When I have just MM running all is well .
                Just seems to be a problem when editing.
                So that is coming from the origin point of link?
                It is national radar from NWS and I don’t update it locally in config.js
                I’ll swag this and guess it generates that Vuex stuff locally when the NWS updates the radar image remotely?
