    Need Help Changing Background Image Based on Time
    16 Posts 4 Posters 4.6k Views 4 Watching
    • T
      tonkxy
      Hello, I am trying to set the mirror to change the background image based on the time of day. I am unsure how to check time , remake the random number and then change the background image. I am able to see when it updates on a short interval (the photo flashes) but stays the same and doesnt regrab a random number/folder based on time. Any help is appreciated!
      defaults: {
              bgName: "",         // .jpg, .gif, .png, Full screen animated gifs too!
              videoName: " ",     // your local picture files go in "images" folder of MMM-EasyBack
              youTubeID: "",      // YouTube ID from the YouTube url
              height: "600px",   // your display's resolution in pixels. Enter in config.js
              width: "1024px",    // your display's resolution in pixels. Enter in config.js
              animationSpeed: "0",
              updateInterval: 60 * 60 * 1000,
          start: function() {
              self = this;
              this.url ='';
      	rand = Math.floor(Math.random() * 2)+1; //randomn number to pick gif
      	rand = 1;
      	var day = new Date();
      	var hour = day.getHours();
      	var minutes = day.getMinutes();
      	if(hour <= 16){
      	folder="Afternoon";
      	} else if(hour >= 16 ){ folder = "Late";
              setInterval(function() {
              self.updateDom(self.config.animationSpeed || 0);
              }, this.config.updateInterval);
              if (this.config.bgName != "") {
                  this.url = "modules/MMM-MainScreen/images/" + folder +"/" + rand +".gif";
              } else if (this.config.vidoeName != "") {
                  this.url = "modules/MMM-MainScreen/videos/" + this.config.video;
          getStyles: function() {
              return ["MMM-MainScreen.css"]
          // Override dom generator.
          getDom: function() {
            if (this.config.youTubeID != '') {
              var iframe = document.createElement("IFRAME");
              iframe.classList.add("iframe");
              iframe.style = "border: 0 none transparent ";
              iframe.width = this.config.width;
              iframe.height = this.config.height;
              type="text/javascript";
              iframe.src="https://www.youtube.com/embed/" + this.config.youTubeID + "?autoplay=1&loop=1&playlist=" + this.config.youTubeID;
              return iframe;
            } else
              var image = document.createElement("img");
              if (this.config.bgName != '') {
                  image.src = this.url;
                  image.className = "photo";
                  console.log("MMM-MainScreen: Now showing image background")
                  wrapper.appendChild(image);
              }else {
                  console.log("MMM-MainScreen error: Please enter either image OR video in config.js NOT BOTH");
              return wrapper;
      M 1 Reply Last reply
        MMRIZE @tonkxy
        @tonkxy
        start: function () {
          // init your module.
          // Not recommended doing your real job here. Because this method is evaluated only one time on startup before all the stuff be prepared (e.g, DOM creating)
          this.timer = null
        notificationReceived: function (notification, payload, sender) {
          if (notification === 'DOM_OBJECTS_CREATED') {
            // This might be the best position where your real job starts.
            this.myJob()
        myJob: function () {
          clearTimeout(this.timer)
          let rand = Math.floor( ... ) // random number to pick
          let hour = (new Date()).getHours() // select hour to pick the folder
          // ...  Your logic for picking image by hour and rand
          this.timer = setTimeout(() => {
            // ... Your logic for displaying image picked.
            this.myJob() // recursive execution per updateInterval.
            // It would be a better habbit to use setTimeout instead of setInterval
        T 1 Reply Last reply
        • T
          tonkxy @MMRIZE
          @mmrize Thank you so much for the guidance!
          I am still really new to messing around in this area so I may not fully grasp your solution. I have been using the EasyBack as a guide to adjusting to what I want. I am unable to now get any kind of a background to show up.
          defaults: {
          start: function() {
              this.timer = null;
          notificationReceived: function(notification, payload, sender){
              if (notification === 'DOM_OBJECTS_CREATED'){
                  self = this;
                  this.url ='';
                  this.myJob();
              myJob: function(){
                  clearTimeout(this.timer);
                  let rand = Math.floor(Math.random()*2)+1;
                  let hour = (new Date()).getHours();
                  if(hour <= 16){
                      folder="Afternoon";
                      this.url = "modules/MMM-EasyBack/images/" + folder +"/" + rand +".gif";
                      this.url = "modules/MMM-EasyBack/videos/" + this.config.video;
                  this.timer = setTimeout(myJob, 1000) {
                      this.myJob();
              return ["MMM-EasyBack.css"]
              return iframe;
            } else
                  console.log("MMM-EasyBack: Now showing image background")
              }else {
                  console.log("MMM-EasyBack error: Please enter either image OR video in config.js NOT BOTH");
              return wrapper;
            MMRIZE @tonkxy
            @tonkxy
            You’ve missed this.updateDom(). It needs to be called when you want to redraw your module’s output.
            Whenever you call “updateDom()”, your “getDom()” will be executed.
            • T
              tonkxy @MMRIZE
              Good catch! I accidentally removed that. So, I have added it back in and tried a few spots before reaching out again. I am still not getting a background to populate… I am not sure if maybe a variable is missing or what else I could be lacking in this. Thank you for your help!
              defaults: {
                  updateInterval: 60 * 60 ,
              start: function() {
                  self = this;
                  this.timer = null;
                      this.myJob();
              },self.updateDom();
                  myJob: function(){
               	clearTimeout = (this.timer);
              	if(hour <= 16){
                          folder="Afternoon";
              	this.updateDom();
              	this.myJob();
              	},this.config.updateInterval);
                  return iframe;
                } else
                  }else {
                  return wrapper;
              S M 2 Replies Last reply
                sdetweil @tonkxy
                @tonkxy u need to update the url before u call updatedDom()
                  MMRIZE @tonkxy
                  @tonkxy
                    this.timer = null
                    this.targetURL = null
                    this.setImageURL()
                  getDom: function () {
                    console.log(">", this.targetURL)
                    var dom = document.createElement('div')
                    dom.style.backgroundImage = `url(${this.targetURL})`
                    dom.style.height = '100vh' // I recommend to control this through CSS, but in this example, I just hardcode it.
                    dom.style.width = '100vw'
                    dom.style.backgroundSize = 'cover'
                    return dom
                      this.job()
                  job: function () {
                    this.updateDom()
                    this.setImageURL()
                      this.job()
                  setImageURL: function () {
                    // do your logic for picking image. Here I pick the random unsplash image instead for example.
                    let rand = Math.floor(Math.random() * 100000)
                    this.targetURL = `https://source.unsplash.com/random?seed=${rand}`
                    sdetweil @MMRIZE
                    @mmrize said in Need Help Changing Background Image Based on Time:
                    job: function () {
                    this.updateDom()
                    this.setImageURL()
                    still backwards.
                    update url,
                    then call updatedDom,
                    which calls getDom
                    which uses the url
                    • T
                      tonkxy
                      @MMRIZE @sdetweil
                      Thank you both so much! That did work by the way! It worked once I moved the dom AND I was missing Module: (name), which is just dumb on my part. I appreciate the help and for solving my issue with this!!!
                      Question, do you guys have a favorite beginners place for Magic Mirror? I feel I am missing some fundamentals and would love to take a recommendation.
                      S E 2 Replies Last reply
                        sdetweil @tonkxy
                        @tonkxy really no design type stuff
                        you can look at my sample module which does all this…
                        https://github.com/sdetweil/SampleModule
                          MMRIZE @sdetweil
                          First url was set in start(), so I put that next of update in recursive.
                          • E
                            easty @tonkxy
                            @tonkxy
                            Time based background is a great idea. Are you planning on releasing this as a module?
                              sdetweil @MMRIZE
                              @mmrize ok. my experience and training on maintaining software teaches me never to do this. you have two places where state is set.
                                MMRIZE @sdetweil
                                @sdetweil you are right. It was just an example. :)
                                • T
                                  tonkxy @easty
                                  @easty i am! Im going to integrate it with weather conditions. It’ll have a gif background that resembles the time of day / condition. Ill be adding in overlays for hrly breakdowns, 5 day etc.
                                    MMRIZE @tonkxy
                                    @tonkxy
                                    Just for reference, there is a similar module already. You’d better get a hint from it.
                                    https://github.com/BrianHepler/MMM-WeatherBackground
                                    It derive the background image from unsplash collections by weather and season condition(and ideally, everything if it can be translated and notified from any modules.)
