    Need Help Changing Background Image Based on Time
    16 Posts 4 Posters 3.4k Views 4 Watching
      MMRIZE @tonkxy
      @tonkxy
      You’ve missed this.updateDom(). It needs to be called when you want to redraw your module’s output.
      Whenever you call “updateDom()”, your “getDom()” will be executed.
      • T Offline
        tonkxy @MMRIZE
        Good catch! I accidentally removed that. So, I have added it back in and tried a few spots before reaching out again. I am still not getting a background to populate… I am not sure if maybe a variable is missing or what else I could be lacking in this. Thank you for your help!
        defaults: {
            bgName: "",         // .jpg, .gif, .png, Full screen animated gifs too!
            videoName: " ",     // your local picture files go in "images" folder of MMM-EasyBack
            youTubeID: "",      // YouTube ID from the YouTube url
            height: "600px",   // your display's resolution in pixels. Enter in config.js
            width: "1024px",    // your display's resolution in pixels. Enter in config.js
            animationSpeed: "0",
            updateInterval: 60 * 60 ,
        start: function() {
            self = this;
            this.timer = null;
        notificationReceived: function(notification, payload, sender){
            if (notification === 'DOM_OBJECTS_CREATED'){
                this.myJob();
        },self.updateDom();
            myJob: function(){
         	clearTimeout = (this.timer);
        	let rand = Math.floor(Math.random()*2)+1;
                let hour = (new Date()).getHours();
        	if(hour <= 16){
                    folder="Afternoon";
                    } else if(hour >= 16 ){ folder = "Late";
        	this.timer = setTimeout(() => {
        	this.updateDom();
        	if (this.config.bgName != "") {
                    this.url = "modules/MMM-MainScreen/images/" + folder +"/" + rand +".gif";
                } else if (this.config.vidoeName != "") {
                    this.url = "modules/MMM-MainScreen/videos/" + this.config.video;
        	this.myJob();
        	},this.config.updateInterval);
        getStyles: function() {
            return ["MMM-EasyBack.css"]
        // Override dom generator.
        getDom: function() {
          if (this.config.youTubeID != '') {
            var iframe = document.createElement("IFRAME");
            iframe.classList.add("iframe");
            iframe.style = "border: 0 none transparent ";
            iframe.width = this.config.width;
            iframe.height = this.config.height;
            type="text/javascript";
            iframe.src="https://www.youtube.com/embed/" + this.config.youTubeID + "?autoplay=1&loop=1&playlist=" + this.config.youTubeID;
            return iframe;
          } else
            var image = document.createElement("img");
            if (this.config.bgName != '') {
                image.src = this.url;
                image.className = "photo";
                console.log("MMM-EasyBack: Now showing image background")
                wrapper.appendChild(image);
            }else {
                console.log("MMM-EasyBack error: Please enter either image OR video in config.js NOT BOTH");
            return wrapper;
          sdetweil @tonkxy
          @tonkxy u need to update the url before u call updatedDom()
            MMRIZE @tonkxy
            @tonkxy
            start: function () {
              this.timer = null
              this.targetURL = null
              this.setImageURL()
            getDom: function () {
              console.log(">", this.targetURL)
              var dom = document.createElement('div')
              dom.style.backgroundImage = `url(${this.targetURL})`
              dom.style.height = '100vh' // I recommend to control this through CSS, but in this example, I just hardcode it.
              dom.style.width = '100vw'
              dom.style.backgroundSize = 'cover'
              return dom
            notificationReceived: function (notification, payload, sender) {
              if (notification === 'DOM_OBJECTS_CREATED') {
                this.job()
            job: function () {
              clearTimeout(this.timer)
              this.updateDom()
              this.setImageURL()
                this.job()
              }, this.config.updateInterval)
            setImageURL: function () {
              // do your logic for picking image. Here I pick the random unsplash image instead for example.
              let rand = Math.floor(Math.random() * 100000)
              this.targetURL = `https://source.unsplash.com/random?seed=${rand}`
              sdetweil @MMRIZE
              @mmrize said in Need Help Changing Background Image Based on Time:
              job: function () {
              this.updateDom()
              this.setImageURL()
              still backwards.
              update url,
              then call updatedDom,
              which calls getDom
              which uses the url
              • T Offline
                tonkxy
                @MMRIZE @sdetweil
                Thank you both so much! That did work by the way! It worked once I moved the dom AND I was missing Module: (name), which is just dumb on my part. I appreciate the help and for solving my issue with this!!!
                Question, do you guys have a favorite beginners place for Magic Mirror? I feel I am missing some fundamentals and would love to take a recommendation.
                S E 2 Replies Last reply Reply Quote 0
                  sdetweil @tonkxy
                  @tonkxy really no design type stuff
                  you can look at my sample module which does all this…
                  https://github.com/sdetweil/SampleModule
                    MMRIZE @sdetweil
                    First url was set in start(), so I put that next of update in recursive.
                    • E Offline
                      easty @tonkxy
                      @tonkxy
                      Time based background is a great idea. Are you planning on releasing this as a module?
                        sdetweil @MMRIZE
                        @mmrize ok. my experience and training on maintaining software teaches me never to do this. you have two places where state is set.
