    Default Calendar & Nextcloud Calendar - CERT_HAS_EXPIRED
    19 Posts 6 Posters 14.0k Views 6 Watching
      BasicUser
      I had to reset some stuff on my Mirror and now I cannot get my calendars to sync between my mirror and my Nextcloud calendars.
      This is the logs that I get when it tries to run a fetch.
      pi@raspberrypi:~/MagicMirror/config $ pm2 logs MagicMirror
      [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
      /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
      0|MagicMir | [30.09.2021 18:17.48.972] [LOG]   Create new calendarfetcher for url: https://subdomain.domain.tld/remote.php/dav/calendars/MAINUSER/personal/?export - Interval: 100000
      0|MagicMir | [30.09.2021 18:17.49.194] [LOG]   Create new calendarfetcher for url: https://subdomain.domain.tld/remote.php/dav/calendars/SHARED CALENDAR/shared/?export - Interval: 100000
      0|MagicMir | [30.09.2021 18:17.49.202] [LOG]   Create new calendarfetcher for url: https://subdomain.domain.tld/remote.php/dav/calendars/SHARED CALENDAR/shared-events/?export - Interval: 100000
      0|MagicMir | [30.09.2021 18:17.49.208] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 100000
      0|MagicMir | [30.09.2021 18:17.49.348] [INFO]  Checking git for module: MMM-Remote-Control
      0|MagicMir | [30.09.2021 18:17.49.491] [INFO]  Checking git for module: MMM-EasyBack
      0|MagicMir | [30.09.2021 18:17.49.577] [INFO]  Checking git for module: MMM-Todoist
      0|MagicMir | [30.09.2021 18:17.49.653] [INFO]  Checking git for module: MMM-NowPlayingOnSpotify
      0|MagicMir | [30.09.2021 18:17.49.738] [INFO]  Checking git for module: MMM-PlexNowPlaying
      0|MagicMir | [30.09.2021 18:17.49.823] [INFO]  Checking git for module: MMM-learnlanguage
      0|MagicMir | [30.09.2021 18:17.50.225] [INFO]  Checking git for module: MMM-WordOfTheDay
      0|MagicMir | [30.09.2021 18:17.50.298] [LOG]   Refreshed access token because it has expired. Expired at: 18:17:49 now is: 18:17:50
      0|MagicMir | [30.09.2021 18:17.50.652] [INFO]  Checking git for module: MMM-MyScoreboard
      0|MagicMir | [30.09.2021 18:17.50.938] [LOG]   Refreshed access token because it has expired. Expired at: 19:17:50 now is: 18:17:50
      0|MagicMir | [30.09.2021 18:17.51.189] [INFO]  Calendar-Fetcher: Broadcasting 5 events.
      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
      0|MagicMir |   code: 'CERT_HAS_EXPIRED'
      0|MagicMir | }
      0|MagicMir | [30.09.2021 18:17.50.035] [ERROR] Calendar Error. Could not fetch calendar:  https://subdomain.domain.tld/remote.php/dav/calendars/SHARED CALENDAR/shared/?export FetchError: request to https://subdomain.domain.tld/remote.php/dav/calendars/SHARED CALENDAR/shared/?export failed, reason: certificate has expired
      0|MagicMir |     at ClientRequest.<anonymous> (/home/pi/MagicMirror/node_modules/node-fetch/lib/index.js:1461:11)
      0|MagicMir |     at ClientRequest.emit (events.js:315:20)
      0|MagicMir |     at TLSSocket.socketErrorListener (_http_client.js:426:9)
      0|MagicMir |     at TLSSocket.emit (events.js:315:20)
      0|MagicMir |     at emitErrorNT (internal/streams/destroy.js:92:8)
      0|MagicMir |     at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
      0|MagicMir |     at processTicksAndRejections (internal/process/task_queues.js:84:21)
      0|MagicMir |  {
      0|MagicMir |   type: 'system',
      0|MagicMir |   errno: 'CERT_HAS_EXPIRED',
      0|MagicMir | }
      I’m assuming this is on my Nextcloud and not on MM but figured I would post in here to see if anyone has been able to solve this issue before? My nextcloud is selfhosted and behind a reverse proxy.
        M_M
        Same problem here with CALEXT2 and MM newsfeed module.
        Marcus
          MMRIZE @M_M
          @m_m
          It seems to be related with this;
          https://letsencrypt.org/docs/dst-root-ca-x3-expiration-september-2021/
          To fix this there might be a few options;
          1. upgrade your node version with --use-openssl-ca flag. (at least node ver 16)
          2. modify source code. Check agentOptions.rejectUnauthorized of fetch or request (anywhich in source). I think that value or equivalent option should be false (to skip unauthorized request)
          3. DANGER : process.env.NODE_TLS_REJECT_UNAUTHORIZED = 0 This is dirty and dangerous but quick solution.
          S AssassinsA 2 Replies Last reply Reply Quote 0
            sdetweil @MMRIZE
            2.16 dropped request and moved to node-fetch
            looks like older modules using request are still working, but fetch maybe not
            • AssassinsA Offline
              Assassins @MMRIZE
              @mmrize
              Get the same error you write :(
                MMRIZE @Assassins
                @assassins Which method did you use?
                AssassinsA 1 Reply Last reply Reply Quote 0
                  Assassins @MMRIZE
                  @mmrize
                  request
                    MMRIZE @Assassins
                    @assassins
                    I think it’s better to upgrade your node version to v16. (and if possible, electron to v15)
                    Anyway, at this moment, MM 2.17 is released. Try it first.
                      Assassins @MMRIZE
                      @mmrize
                      Same error with 2.17.0 with both node 14 and 16
                        MMRIZE @Assassins
                        @assassins
                        Well, sorry. I have no idea anymore.
                          Assassins @MMRIZE
                          @mmrize
                          But thanks for you try mate :)
                            sdetweil @Assassins
                            @assassins a new version is posted 2.17.1 that fixes this problem
                            git pull
                            npm install
                            to update manually
                            OR
                            use my upgrade script
                            see https://github.com/sdetweil/MagicMirror_scripts
                            with apply, if not already on 2.17,
                            use force if already on 2.17
                            AssassinsA B 2 Replies Last reply Reply Quote 0
                            • S sdetweil pinned this topic on
                              Assassins @sdetweil
                              Thanks alot mate, i Will try to Update om monday 🙆‍♂️🙆‍♂️
                                BasicUser @sdetweil
                                @sdetweil I went the git pull && npm install route but now MM will not load
                                0|MagicMirror  | Initializing new module helper ...
                                0|MagicMirror  | [01.10.2021 15:25.04.722] [LOG]   Module helper loaded: MMM-NowPlayingOnSpotify
                                0|MagicMirror  | [01.10.2021 15:25.04.724] [LOG]   No helper found for module: MMM-PlexNowPlaying.
                                0|MagicMirror  | [01.10.2021 15:25.04.729] [ERROR] App threw an error during load
                                0|MagicMirror  | [01.10.2021 15:25.04.734] [ERROR] Error: Cannot find module 'request'
                                0|MagicMirror  | Require stack:
                                0|MagicMirror  | - /home/pi/MagicMirror/modules/MMM-learnlanguage/node_helper.js
                                0|MagicMirror  | - /home/pi/MagicMirror/js/app.js
                                0|MagicMirror  | - /home/pi/MagicMirror/js/electron.js
                                0|MagicMirror  | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                                0|MagicMirror  | -
                                0|MagicMirror  |     at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
                                0|MagicMirror  |     at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
                                0|MagicMirror  |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                0|MagicMirror  |     at Module._load (internal/modules/cjs/loader.js:732:27)
                                0|MagicMirror  |     at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
                                0|MagicMirror  |     at Module.require (internal/modules/cjs/loader.js:959:19)
                                0|MagicMirror  |     at require (internal/modules/cjs/helpers.js:88:18)
                                0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-learnlanguage/node_helper.js:8:15)
                                0|MagicMirror  |     at Module._compile (internal/modules/cjs/loader.js:1078:30)
                                0|MagicMirror  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
                                0|MagicMirror  | [01.10.2021 15:25.04.738] [ERROR]
                                0|MagicMirror  | Whoops! There was an uncaught exception...
                                0|MagicMirror  | [01.10.2021 15:25.04.755] [ERROR]
                                0|MagicMirror  | Error: Cannot find module 'request'
                                0|MagicMirror  | -
                                0|MagicMirror  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10) {
                                0|MagicMirror  |   code: 'MODULE_NOT_FOUND',
                                0|MagicMirror  |   requireStack: [
                                0|MagicMirror  |     '/home/pi/MagicMirror/modules/MMM-learnlanguage/node_helper.js',
                                0|MagicMirror  |     '/home/pi/MagicMirror/js/app.js',
                                0|MagicMirror  |     '/home/pi/MagicMirror/js/electron.js',
                                0|MagicMirror  |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                0|MagicMirror  |     undefined
                                0|MagicMirror  |   ]
                                0|MagicMirror  | }
                                0|MagicMirror  | [01.10.2021 15:25.04.757] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                0|MagicMirror  | [01.10.2021 15:25.04.759] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                0|MagicMirror  | [01.10.2021 15:25.05.202] [LOG]
                                0|MagicMirror  | Launching application.
                                any ideas?
                                  sdetweil @BasicUser
                                  @basicuser said in Default Calendar & Nextcloud Calendar - CERT_HAS_EXPIRED:
                                  Cannot find module ‘request’
                                  sure
                                  see above
                                    BasicUser @sdetweil
                                    @sdetweil I got it figured out by just running npm install request in ~/MagicMirror/
                                    Not super sure what you’re referring to when you say see above though.
                                      sdetweil @BasicUser
                                      @basicuser sorry, wrong topic
                                      https://forum.magicmirror.builders/topic/15665/mmm-rtsp-stopped-working-on-2-17-help/2?_=1633110498656
                                      • L Offline
                                        LdwVII
                                        Great info in this thread, thank you!
                                        Weirdly enough, I’m still experiencing the CERT_HAS_EXPIRED error on the Calendar module, despite updating MagicMirror to 2.17.1.
                                        Had the certificate error on quite a few modules prior, the update fixed all except the Calendar one. Did I miss something or is it perhaps an entirely different error?
                                        (What kind of certificate is this anyway? I had thought an http request wouldn’t need any.)
                                        0|launchMa | [03.10.2021 09:15.33.458] [ERROR] Calendar Error. Could not fetch calendar:  http://kalender.link/ical/best FetchError: request to https://kalender.link/ical/best failed, reason: certificate has expired
                                        0|launchMa |     at ClientRequest.<anonymous> (/home/pi/MagicMirror/node_modules/node-fetch/lib/index.js:1483:11)
                                        0|launchMa |     at ClientRequest.emit (events.js:315:20)
                                        0|launchMa |     at TLSSocket.socketErrorListener (_http_client.js:469:9)
                                        0|launchMa |     at TLSSocket.emit (events.js:315:20)
                                        0|launchMa |     at emitErrorNT (internal/streams/destroy.js:106:8)
                                        0|launchMa |     at emitErrorCloseNT (internal/streams/destroy.js:74:3)
                                        0|launchMa |     at processTicksAndRejections (internal/process/task_queues.js:80:21) {
                                        0|launchMa |   type: 'system',
                                        0|launchMa |   errno: 'CERT_HAS_EXPIRED',
                                        0|launchMa |   code: 'CERT_HAS_EXPIRED'
                                        0|launchMa | }
                                          sdetweil @LdwVII
                                          @ldwvii https uses encryption to protect your data while traveling across the internet.
                                          to do this, the receiving host must have registered to support that encryption.
                                          it does this by recording it’s url and encryption type with a certificate authority ( not just anybody can be an authority), they give back a file with a key, with a specific lifetime. ( so u can’t have old sites with bad security hanging around forever)
                                          well the authorities also have expiring rights.
                                          in this case the authority’s certificate expired. (it’s a chain ) … and there was a bug in electron that didn’t handle it correctly
                                          now, in your case u use an unprotected url ( no longer allowed as a standard)
                                          no ‘s’ on http and it was redirected to secure (https)… maybe the redirect sent to the wrong place…
