    Default Calendar & Nextcloud Calendar - CERT_HAS_EXPIRED
    19 Posts 6 Posters 7.8k Views 6 Watching
      MMRIZE @Assassins
      @assassins Which method did you use?
      AssassinsA 1 Reply Last reply Reply Quote 0
      • AssassinsA Offline
        Assassins @MMRIZE
        @mmrize
        request
          MMRIZE @Assassins
          @assassins
          I think it’s better to upgrade your node version to v16. (and if possible, electron to v15)
          Anyway, at this moment, MM 2.17 is released. Try it first.
            Assassins @MMRIZE
            @mmrize
            Same error with 2.17.0 with both node 14 and 16
              MMRIZE @Assassins
              @assassins
              Well, sorry. I have no idea anymore.
                Assassins @MMRIZE
                @mmrize
                But thanks for you try mate :)
                  sdetweil @Assassins
                  @assassins a new version is posted 2.17.1 that fixes this problem
                  git pull
                  npm install
                  to update manually
                  OR
                  use my upgrade script
                  see https://github.com/sdetweil/MagicMirror_scripts
                  with apply, if not already on 2.17,
                  use force if already on 2.17
                  AssassinsA B 2 Replies Last reply Reply Quote 0
                  • S sdetweil pinned this topic on
                    Assassins @sdetweil
                    Thanks alot mate, i Will try to Update om monday 🙆‍♂️🙆‍♂️
                      BasicUser @sdetweil
                      @sdetweil I went the git pull && npm install route but now MM will not load
                      0|MagicMirror  | Initializing new module helper ...
                      0|MagicMirror  | [01.10.2021 15:25.04.722] [LOG]   Module helper loaded: MMM-NowPlayingOnSpotify
                      0|MagicMirror  | [01.10.2021 15:25.04.724] [LOG]   No helper found for module: MMM-PlexNowPlaying.
                      0|MagicMirror  | [01.10.2021 15:25.04.729] [ERROR] App threw an error during load
                      0|MagicMirror  | [01.10.2021 15:25.04.734] [ERROR] Error: Cannot find module 'request'
                      0|MagicMirror  | Require stack:
                      0|MagicMirror  | - /home/pi/MagicMirror/modules/MMM-learnlanguage/node_helper.js
                      0|MagicMirror  | - /home/pi/MagicMirror/js/app.js
                      0|MagicMirror  | - /home/pi/MagicMirror/js/electron.js
                      0|MagicMirror  | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                      0|MagicMirror  | -
                      0|MagicMirror  |     at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
                      0|MagicMirror  |     at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
                      0|MagicMirror  |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                      0|MagicMirror  |     at Module._load (internal/modules/cjs/loader.js:732:27)
                      0|MagicMirror  |     at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
                      0|MagicMirror  |     at Module.require (internal/modules/cjs/loader.js:959:19)
                      0|MagicMirror  |     at require (internal/modules/cjs/helpers.js:88:18)
                      0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-learnlanguage/node_helper.js:8:15)
                      0|MagicMirror  |     at Module._compile (internal/modules/cjs/loader.js:1078:30)
                      0|MagicMirror  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
                      0|MagicMirror  | [01.10.2021 15:25.04.738] [ERROR]
                      0|MagicMirror  | Whoops! There was an uncaught exception...
                      0|MagicMirror  | [01.10.2021 15:25.04.755] [ERROR]
                      0|MagicMirror  | Error: Cannot find module 'request'
                      0|MagicMirror  | -
                      0|MagicMirror  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10) {
                      0|MagicMirror  |   code: 'MODULE_NOT_FOUND',
                      0|MagicMirror  |   requireStack: [
                      0|MagicMirror  |     '/home/pi/MagicMirror/modules/MMM-learnlanguage/node_helper.js',
                      0|MagicMirror  |     '/home/pi/MagicMirror/js/app.js',
                      0|MagicMirror  |     '/home/pi/MagicMirror/js/electron.js',
                      0|MagicMirror  |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                      0|MagicMirror  |     undefined
                      0|MagicMirror  |   ]
                      0|MagicMirror  | }
                      0|MagicMirror  | [01.10.2021 15:25.04.757] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      0|MagicMirror  | [01.10.2021 15:25.04.759] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                      0|MagicMirror  | [01.10.2021 15:25.05.202] [LOG]
                      0|MagicMirror  | Launching application.
                      any ideas?
                        sdetweil @BasicUser
                        @basicuser said in Default Calendar & Nextcloud Calendar - CERT_HAS_EXPIRED:
                        Cannot find module ‘request’
                        sure
                        see above
