    Default Calendar & Nextcloud Calendar - CERT_HAS_EXPIRED
    19 Posts 6 Posters 14.9k Views 6 Watching
      MMRIZE @Assassins
      @assassins
      I think it’s better to upgrade your node version to v16. (and if possible, electron to v15)
      Anyway, at this moment, MM 2.17 is released. Try it first.
      AssassinsA 1 Reply Last reply
      • AssassinsA
        Assassins @MMRIZE
        @mmrize
        Same error with 2.17.0 with both node 14 and 16
        M 1 Reply Last reply
          MMRIZE @Assassins
          @assassins
          Well, sorry. I have no idea anymore.
          • AssassinsA
            Assassins @MMRIZE
            @mmrize
            But thanks for you try mate :)
              sdetweil @Assassins
              @assassins a new version is posted 2.17.1 that fixes this problem
              git pull
              npm install
              to update manually
              OR
              use my upgrade script
              see https://github.com/sdetweil/MagicMirror_scripts
              with apply, if not already on 2.17,
              use force if already on 2.17
              AssassinsA B 2 Replies Last reply
              • S sdetweil pinned this topic on
              • AssassinsA
                Assassins @sdetweil
                Thanks alot mate, i Will try to Update om monday 🙆‍♂️🙆‍♂️
                  BasicUser @sdetweil
                  @sdetweil I went the git pull && npm install route but now MM will not load
                  0|MagicMirror  | Initializing new module helper ...
                  0|MagicMirror  | [01.10.2021 15:25.04.722] [LOG]   Module helper loaded: MMM-NowPlayingOnSpotify
                  0|MagicMirror  | [01.10.2021 15:25.04.724] [LOG]   No helper found for module: MMM-PlexNowPlaying.
                  0|MagicMirror  | [01.10.2021 15:25.04.729] [ERROR] App threw an error during load
                  0|MagicMirror  | [01.10.2021 15:25.04.734] [ERROR] Error: Cannot find module 'request'
                  0|MagicMirror  | Require stack:
                  0|MagicMirror  | - /home/pi/MagicMirror/modules/MMM-learnlanguage/node_helper.js
                  0|MagicMirror  | - /home/pi/MagicMirror/js/app.js
                  0|MagicMirror  | - /home/pi/MagicMirror/js/electron.js
                  0|MagicMirror  | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                  0|MagicMirror  | -
                  0|MagicMirror  |     at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
                  0|MagicMirror  |     at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
                  0|MagicMirror  |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                  0|MagicMirror  |     at Module._load (internal/modules/cjs/loader.js:732:27)
                  0|MagicMirror  |     at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
                  0|MagicMirror  |     at Module.require (internal/modules/cjs/loader.js:959:19)
                  0|MagicMirror  |     at require (internal/modules/cjs/helpers.js:88:18)
                  0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-learnlanguage/node_helper.js:8:15)
                  0|MagicMirror  |     at Module._compile (internal/modules/cjs/loader.js:1078:30)
                  0|MagicMirror  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
                  0|MagicMirror  | [01.10.2021 15:25.04.738] [ERROR]
                  0|MagicMirror  | Whoops! There was an uncaught exception...
                  0|MagicMirror  | [01.10.2021 15:25.04.755] [ERROR]
                  0|MagicMirror  | Error: Cannot find module 'request'
                  0|MagicMirror  | -
                  0|MagicMirror  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10) {
                  0|MagicMirror  |   code: 'MODULE_NOT_FOUND',
                  0|MagicMirror  |   requireStack: [
                  0|MagicMirror  |     '/home/pi/MagicMirror/modules/MMM-learnlanguage/node_helper.js',
                  0|MagicMirror  |     '/home/pi/MagicMirror/js/app.js',
                  0|MagicMirror  |     '/home/pi/MagicMirror/js/electron.js',
                  0|MagicMirror  |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                  0|MagicMirror  |     undefined
                  0|MagicMirror  |   ]
                  0|MagicMirror  | }
                  0|MagicMirror  | [01.10.2021 15:25.04.757] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  0|MagicMirror  | [01.10.2021 15:25.04.759] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  0|MagicMirror  | [01.10.2021 15:25.05.202] [LOG]
                  0|MagicMirror  | Launching application.
                  any ideas?
                    sdetweil @BasicUser
                    @basicuser said in Default Calendar & Nextcloud Calendar - CERT_HAS_EXPIRED:
                    Cannot find module ‘request’
                    sure
                    see above
                    B 1 Reply Last reply
                      BasicUser @sdetweil
                      @sdetweil I got it figured out by just running npm install request in ~/MagicMirror/
                      Not super sure what you’re referring to when you say see above though.
                        sdetweil @BasicUser
                        @basicuser sorry, wrong topic
                        https://forum.magicmirror.builders/topic/15665/mmm-rtsp-stopped-working-on-2-17-help/2?_=1633110498656
                        • L
                          LdwVII
                          Great info in this thread, thank you!
                          Weirdly enough, I’m still experiencing the CERT_HAS_EXPIRED error on the Calendar module, despite updating MagicMirror to 2.17.1.
                          Had the certificate error on quite a few modules prior, the update fixed all except the Calendar one. Did I miss something or is it perhaps an entirely different error?
                          (What kind of certificate is this anyway? I had thought an http request wouldn’t need any.)
                          0|launchMa | [03.10.2021 09:15.33.458] [ERROR] Calendar Error. Could not fetch calendar:  http://kalender.link/ical/best FetchError: request to https://kalender.link/ical/best failed, reason: certificate has expired
                          0|launchMa |     at ClientRequest.<anonymous> (/home/pi/MagicMirror/node_modules/node-fetch/lib/index.js:1483:11)
                          0|launchMa |     at ClientRequest.emit (events.js:315:20)
                          0|launchMa |     at TLSSocket.socketErrorListener (_http_client.js:469:9)
                          0|launchMa |     at TLSSocket.emit (events.js:315:20)
                          0|launchMa |     at emitErrorNT (internal/streams/destroy.js:106:8)
                          0|launchMa |     at emitErrorCloseNT (internal/streams/destroy.js:74:3)
                          0|launchMa |     at processTicksAndRejections (internal/process/task_queues.js:80:21) {
                          0|launchMa |   type: 'system',
                          0|launchMa |   errno: 'CERT_HAS_EXPIRED',
                          0|launchMa |   code: 'CERT_HAS_EXPIRED'
                          0|launchMa | }
                            sdetweil @LdwVII
                            @ldwvii https uses encryption to protect your data while traveling across the internet.
                            to do this, the receiving host must have registered to support that encryption.
                            it does this by recording it’s url and encryption type with a certificate authority ( not just anybody can be an authority), they give back a file with a key, with a specific lifetime. ( so u can’t have old sites with bad security hanging around forever)
                            well the authorities also have expiring rights.
                            in this case the authority’s certificate expired. (it’s a chain ) … and there was a bug in electron that didn’t handle it correctly
                            now, in your case u use an unprotected url ( no longer allowed as a standard)
                            no ‘s’ on http and it was redirected to secure (https)… maybe the redirect sent to the wrong place…
