Unsolved Client wont keep Modules up-to-date
@karsten13
yes and using pm2 to start this command:DISPLAY=:0 node clientonly --address 192.168.0.13 --port 8080
And yes I have errors, it seems as if there is a problem using the 127.0.0.1 address and port 8080:
0|mm | [13.07.2021 13:19.37.499] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080 0|mm | at Server.setupListenHandle [as _listen2] (net.js:1313:16) 0|mm | at listenInCluster (net.js:1361:12) 0|mm | at GetAddrInfoReqWrap.doListen [as callback] (net.js:1498:7) 0|mm | at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:68:8) { 0|mm | code: 'EADDRINUSE', 0|mm | errno: 'EADDRINUSE', 0|mm | syscall: 'listen', 0|mm | address: '127.0.0.1', 0|mm | port: 8080 0|mm | } 0|mm | [13.07.2021 13:19.37.506] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | [13.07.2021 13:19.37.510] [ERROR] If you think this really is an is sue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/iss ues
and I wonder why there is an error catching the newsfeed, as the stated feed is the one from the client, not the server:
0|mm | /home/pi/MagicMirror/node_modules/electron/dist/electron exited wit h signal SIGINT 0|mm | [13.07.2021 19:59.53.918] [ERROR] Newsfeed Error. Could not fetch n ewsfeed: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml FetchError: request to https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml failed, rea son: getaddrinfo EAI_AGAIN rss.nytimes.com 0|mm | at ClientRequest.<anonymous> (/home/pi/MagicMirror/node_modules /node-fetch/lib/index.js:1461:11) 0|mm | at ClientRequest.emit (events.js:315:20) 0|mm | at TLSSocket.socketErrorListener (_http_client.js:426:9) 0|mm | at TLSSocket.emit (events.js:315:20) 0|mm | at emitErrorNT (internal/streams/destroy.js:92:8) 0|mm | at emitErrorAndCloseNT (internal/streams/destroy.js:60:3) 0|mm | at processTicksAndRejections (internal/process/task_queues.js:8 4:21) { 0|mm | type: 'system', 0|mm | errno: 'EAI_AGAIN', 0|mm | code: 'EAI_AGAIN' 0|mm | } 0|mm | [13.07.2021 19:59.56.921] [ERROR] Calendar Error. Could not fetch c alendar: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics Fetch Error: request to http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.i cs failed, reason: getaddrinfo EAI_AGAIN www.calendarlabs.com 0|mm | at ClientRequest.<anonymous> (/home/pi/MagicMirror/node_modules /node-fetch/lib/index.js:1461:11)
@codac said in Client wont keep Modules up-to-date:
EAI_AGAIN
is a name server problem
the api request could not resolve the name
see this a lot with local pihole servers doing DNS filtering
yes, port 8080 on your client is already in use.
You can try another port in the clientconfig.js
but I don’t know if this works.I wonder why there is an error catching the newsfeed, as the stated feed is the one from the client, not the server:
then remove this stuff from the client config …
I’m not familiar with the clientonly setup and I think this is not used very often and therefore maybe contains some bugs.
@karsten13 said in Client wont keep Modules up-to-date:
it just launches electron pointing at the server, same as u would do with chromium.
doesn’t use the config.js
I figured out that is was due to several reasons.
- The reported error messages from the client side were old ones from the time when I set up the client and before I switched to clientonly mode. So they are supposed to be ignored.
- The calendar module was able to receive the events from all calendars except for one calendar that runs on my NAS system where I forgot to add the port number to the calendar url.
- the module MMM-Tankerkoenig is not up to date as there is an error message regarding the identifier that was not found. As far as I can see the code has an error and therefore the module wont update correctly.
- the module MMM-Formula1 (wrongly called it MMM-SocerLiveScore) module has a ReloadInterval which was just wrongly set up and far to long.
@karsten13
In the Docker on the server side is there anything adequate to the command pm2 logs --lines 300 mm ? -
wouldnt you just
docker exec container_id pm2 logs.....
to execute the command inside the container?
to clear the logs
docker exec container_id pm2 flush
there is no pm2 in the container …
The command is
docker logs <containername or id>
, so if you use my docker-compose setupdocker logs mm
@karsten13 so I have to restart the container after making config changes?
@sdetweil yes, you should do that.
I have still not fixed this.
Servers IP: 192.168.0.23 (local Port 8036, container-port: 8080)
On the client I get the following error:
Unable to connect to server: (Error: Unable to read config from server (http://192.168.0.23:8036/config/ (connect ECONNREFUSED 192.168.0.23:8036)
The servers config is set to:
address: "0.0.0.0", port: 8080, basePath: "/", ipWhitelist: ['0.0.0.0/0', '127.0.0.1', '::ffff:127.0.0.1', '::1', '192.168.0.0/24', '172.17.0.0/24'],
Any ideas why the client wont get the servers config?
