Unsolved Opening hours for stores/places thru Google API
It doesn’t seem to work anymore, black screen for me, do you have a solution?
Hi @sdetweil thanks for your help.
Unfortunately it doesn’t work, I don’t see any dependencies to install ./home/pi/.pm2/logs/MagicMirror-error.log last 50 lines: 0|MagicMir | at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128) 0|MagicMir | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29) 0|MagicMir | at Module._load (internal/modules/cjs/loader.js:732:27) 0|MagicMir | at Function.f._load (electron/js2c/asar_bundle.js:5:12913) 0|MagicMir | at Module.require (internal/modules/cjs/loader.js:959:19) { 0|MagicMir | code: 'ERR_PACKAGE_PATH_NOT_EXPORTED' 0|MagicMir | } 0|MagicMir | [15.12.2021 22:17.06.623] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|MagicMir | [15.12.2021 22:17.06.624] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues 0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT 0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT 0|MagicMir | [15.12.2021 23:04.17.414] [ERROR] (node:21244) [DEP0066] DeprecationWarning: OutgoingMessage.prototype._headers is deprecated 0|MagicMir | (Use `electron --trace-deprecation ...` to show where the warning was created) 0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT 0|MagicMir | [16.12.2021 00:13.53.347] [ERROR] (node:22605) [DEP0066] DeprecationWarning: OutgoingMessage.prototype._headers is deprecated 0|MagicMir | (Use `electron --trace-deprecation ...` to show where the warning was created) 0|MagicMir | [16.12.2021 11:51.38.088] [ERROR] [SPOTIFY - Thomas] Failed to request API: /v1/me/player 0|MagicMir | [16.12.2021 11:51.38.093] [ERROR] [SPOTIFY - Thomas] Invalid response 0|MagicMir | [16.12.2021 11:51.38.102] [ERROR] [SPOTIFY - Thomas] Response error code: 502 0|MagicMir | [16.12.2021 11:51.38.102] [ERROR] [SPOTIFY - Thomas] Response error text: Bad Gateway 0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT 0|MagicMir | [16.12.2021 19:17.24.951] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './v4' is not defined by "exports" in /home/pi/MagicMirror/modules/MMM-OpeningHours/node_modules/uuid/package.json 0|MagicMir | [16.12.2021 19:17.24.970] [ERROR] App threw an error during load 0|MagicMir | [16.12.2021 19:17.24.971] [ERROR] Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './v4' is not defined by "exports" in /home/pi/MagicMirror/modules/MMM-OpeningHours/node_modules/uuid/package.json 0|MagicMir | at throwExportsNotFound (internal/modules/esm/resolve.js:290:9) 0|MagicMir | at packageExportsResolve (internal/modules/esm/resolve.js:513:3) 0|MagicMir | at resolveExports (internal/modules/cjs/loader.js:439:36) 0|MagicMir | at Function.Module._findPath (internal/modules/cjs/loader.js:479:31) 0|MagicMir | at Module._resolveFilename (internal/modules/cjs/loader.js:874:27) 0|MagicMir | at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128) 0|MagicMir | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29) 0|MagicMir | at Module._load (internal/modules/cjs/loader.js:732:27) 0|MagicMir | at Function.f._load (electron/js2c/asar_bundle.js:5:12913) 0|MagicMir | at Module.require (internal/modules/cjs/loader.js:959:19) 0|MagicMir | [16.12.2021 19:17.24.972] [ERROR] Whoops! There was an uncaught exception... 0|MagicMir | [16.12.2021 19:17.24.977] [ERROR] Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './v4' is not defined by "exports" in /home/pi/MagicMirror/modules/MMM-OpeningHours/node_modules/uuid/package.json 0|MagicMir | at throwExportsNotFound (internal/modules/esm/resolve.js:290:9) 0|MagicMir | at packageExportsResolve (internal/modules/esm/resolve.js:513:3) 0|MagicMir | at resolveExports (internal/modules/cjs/loader.js:439:36) 0|MagicMir | at Function.Module._findPath (internal/modules/cjs/loader.js:479:31) 0|MagicMir | at Module._resolveFilename (internal/modules/cjs/loader.js:874:27) 0|MagicMir | at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128) 0|MagicMir | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29) 0|MagicMir | at Module._load (internal/modules/cjs/loader.js:732:27) 0|MagicMir | at Function.f._load (electron/js2c/asar_bundle.js:5:12913) 0|MagicMir | at Module.require (internal/modules/cjs/loader.js:959:19) { 0|MagicMir | code: 'ERR_PACKAGE_PATH_NOT_EXPORTED'
@tcsevens very interesting. can u do
npm -v
node -vlooks like uuid library has a dependency that can’t be met
.v4
@sdetweil thanks again :)
$ npm -v 6.14.15 $ node -v v14.18.2
