npm start doesn't do anything but logs random words.
@ichiritzu don’t do Jessie or stretch
…use the latest, bullseyeand then use my install script
see
https://github.com/sdetweil/MagicMirror_scripts -
@sdetweil said in npm start doesn't do anything but logs random words.:
bullseye
do I update the software or just reflash my sd?
@ichiritzu reflash, then use my script. don’t do anything else before that
@sdetweil Ok, I reflashed and got Bullseye. Then I immediately followed your script and the same results. After installing nothing happens, it just instructs me to cd to MagicMirror and use pm2 start MagicMirror.
When I do that, still nothing happens. It says status online, cpu 0%, and memory 2.8mb. Also when I do npm start, all it does is log random words like before.
@ichiritzu someone on discord is reporting similar issues…
he said renaming mm folder and doing manual install
git clone && npm install worked.
not sure what is going on
it seems to be solved now, npm delivers now colors v1.4.0 as max version …
Awesome! thank y’all. I finally fixed by renaming the folder, changing the dependency ‘colors’ to 1.4.0 (removed the carrot), delete node_modles, and npm install.
