    npm start doesn't do anything but logs random words.
    9 Posts 3 Posters 1.7k Views 3 Watching
    • I Offline
      Ichiritzu @sdetweil
      @sdetweil said in npm start doesn't do anything but logs random words.:
      bullseye
      do I update the software or just reflash my sd?
        sdetweil @Ichiritzu
        @ichiritzu reflash, then use my script. don’t do anything else before that
        • I Offline
          Ichiritzu @sdetweil
          @sdetweil Ok, I reflashed and got Bullseye. Then I immediately followed your script and the same results. After installing nothing happens, it just instructs me to cd to MagicMirror and use pm2 start MagicMirror.
          When I do that, still nothing happens. It says status online, cpu 0%, and memory 2.8mb. Also when I do npm start, all it does is log random words like before.
            sdetweil @Ichiritzu
            @ichiritzu someone on discord is reporting similar issues…
            he said renaming mm folder and doing manual install
            git clone && npm install worked.
            not sure what is going on
            karsten13K 2 Replies Last reply Reply Quote 0
            • karsten13K Offline
              karsten13 @sdetweil
              see https://www.bleepingcomputer.com/news/security/dev-corrupts-npm-libs-colors-and-faker-breaking-thousands-of-apps/
                karsten13 @sdetweil
                it seems to be solved now, npm delivers now colors v1.4.0 as max version …
                • I Offline
                  Ichiritzu @karsten13
                  @karsten13 @sdetweil
                  Awesome! thank y’all. I finally fixed by renaming the folder, changing the dependency ‘colors’ to 1.4.0 (removed the carrot), delete node_modles, and npm install.
