    Withings
    health
    26 Posts 14 Posters 27.0k Views 17 Watching
      matt25 @frog
      @frog Ok sorry. When creating a withings app it is necessary to write something in the application website (127.0.0.1). In the Withings authentification process, do not fill the the ‘callback url’ field. Hope it helps.
      • F
        frog
        Ah, OK,
        Now a different error.
        When I get to Step 3, do I stop there or continue on (I’m getting a Bad Request on step 4)
        Also it says in step 2 I should get a URL once I access the user - but I get Access Granted - and another token - no URL.
        To be clear about the parameters for the config.js:
        oath_consumer key is the key given in the partner app page. under My Keys and called APIKey
        oauth_signature is listed right at the bottom in the black box in step 3.
        clientID - no idea what that is
        oauth_token is taken from the black box in step 3 and is highlighted. There are two copies of it.
        Oh, One last request about functionality. It would be great if you could specify in Config.js which readings are actually shown. I only use the scales and so the other stuff is superfluous. I suspect the majority of people would not necessarily have the full set (steps and sleep).
          matt25
          @frog
          Seems that you are not using correct parameters in the Withings authentification process:
          • Step1 : Use API keys and API secret generated during your Withings apps creation.
            You get a result URL with oauth_token and oauth_token_secret.
          • Step2: Use oath_token and oauth_token_secret generated at step1. This will generate a result URL. Click on it and look at the adress bar, you will get in the URL your userid (6 digits), ‘&userid=xxxxxxx’
          • Step3: use the userid got from step2. you will get an URL result with oauth_signature and oauth_token.
          Hope it helps.
          Selecting the data you want to display is the next step, that is why currently this is just a basic module and I did not yet published a official release.
          • F
            frog @matt25
            @matt25 Hi,
            Thanks, with your pointers, I got through to step 4 and the resultant URL does retrieve data so I know the credentials are working- but putting that into the config.js (all info it looks like you ask for is contained in that request URL), I still get zeros.
            I suspect I’m close, but not sure what could be wrong.
            I 1 Reply Last reply Reply Quote 1
            • I
              ih800a @frog
              @frog I’m getting the same results as you. I suspect the MM_Withings.js script needs to be tweaked a bit. I manually tested all the variables used in the config.js file, confirming that the API is setup correctly and returning data. My guess is that the output string of the MM_Withings.js script is different than what I’m testing.
                matt25 @ih800a
                @ih800a @frog
                Hi, sorry, was out last few weeks. Just tried the module on another raspberry card with from scratch installation and I cannot reproduce the issue you describe. When you launch the mirror, do you have any issue in the logs? (use “npm start dev” command). Thanks
                • I
                  ih800a @matt25
                  @matt25
                  Per the console, I do receive weight (poids=90.67;) and date (date=1481195497) information, but then see the following:
                  status=0
                  error TypeError: Cannot read property ‘date’ of undefined
                  error TypeError: Cannot read property ‘body’ of undefined
                  data=undefined
                  data is null
                    matt25 @ih800a
                    @ih800a
                    ok thanks.
                    Do you only have a Withings scale, correct? or do you also have a watch or others?
                    My guess is that as my module is just currently a proof of concept, I try to display all the related information (weight, sleep, activity ) but if you do not have the withings device related it crashes.
                    Also, could you tell me when:
                    “error TypeError: Cannot read property ‘date’ of undefined”
                    which line in the MM_Withings.js script is related. It should be written in the debug console. Thanks
                    • I
                      ih800a @matt25
                      @matt25
                      I have a few Withings devices (pulse, scale, BP monitor, etc), so your theory makes good sense. Kudos, by the way on this proof of concept - I like it and this will be one of my first Pi / Magic Mirror / module customizations, so I appreciate any insight you have.
                      The errors appear at MM_Withings.js:208, which I believe is the line that writes the error to the log.
                      • A
                        aluini
                        I corrected some things on the module :
                        • correction of the @ih800a bug (I had the same)
                        • add external CSS
                        • add the loader
                        • add translation
                        I’ll review the design of the module
                        [card:aluini/MM_Withings]
                        • SnilleS
                          Snille Module Developer
                          Hi @aluini, is your module still working correctly? I’m only getting the weight. :)
                          I have an Body Cardio Scale, do I have to define this somewhere?
                          Thanks!
                          • F
                            fox
                            @aluini said in Withings:
                            • add external CSS
                            • add the loader
                            • add translation
                            Nice. I want to test it.
                            My data from my withings steel also showable?
                            Issues With MMM-WatchDog known?
                            https://forum.magicmirror.builders/post/29827
                            Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                              Jayh391
                              I can not get it to work. I only have the scale.
                              • F
                                fabbr
                                I looked at the module and it just need to be updated however, I can find a way to be able to get the JSON data to be displayed. All I get is a {“status”:342,“error”:“The signature (using Oauth) is invalid”}
                                I tried almost everything already.
                                If anyone can give it a try and make that work, I can update the module and even create new features.
                                • A
                                  AgP42 Project Sponsor Module Developer
                                  I also try to make it work, but I didn’t succed. Probably I did some wrong behaviour during the oAuth process.
                                  At the end I can see on my MagicMirror logs an error 283, that correspond according to Nokia API website to : “283 : Token is invalid or doesn’t exist”.
                                  I considered it was OAuth version 1.0 because it look like it.
                                  Also it is written on Nokia website :
                                  “The Health Mate API is now fully functional with OAuth 2.0 authentication protocol.
                                  Therefore, the OAuth 1.0 process will no longer be supported beginning:
                                  November 30, 2018”
                                  Also I do not really want to fight to make it work if the service will be cut by Nokia/Withings on a few months.
                                  Does someone have the knowledge to update this module with OAuth 2.0 ?
                                  • I
                                    iwaldrum
                                    Anybody get this working with the new OAuth 2.0?
