    Error with node fetch for calendar on fresh install
    10 Posts 3 Posters 1.5k Views 3 Watching
      sdetweil @landaisbenj
      @landaisbenj don’t know. my upgrade script tries to take care of all the extra details
      see
        @landaisbenj never seen this using my install script
        • L Offline
          landaisbenj
          Ok si i could try with your script today. I follow instruction on documentation.
            @landaisbenj move the existing mm folder out of the way if doing install
            cd ~
            mv MagicMirror MagicMirror.save
            • L Offline
              landaisbenj
              OMG It’s really helpfull… Need to be the first way on documentation… Ok, it work, i try now to réinstall all my modules.
              • L Offline
                landaisbenj
                All my module work. Thanks a lot… I’m on this by a few day…
                • mumblebajM Offline
                  mumblebaj Module Developer @landaisbenj
                  @landaisbenj I have seen this error before. It comes from installing the latest version of node-fetch whereas the module uses an older version of node-fetch. The latest version is an ES module and must be import’d instead of require’d in the node_helper.
                    sdetweil @mumblebaj
                    @mumblebaj but how did that happen? MM asks for newer, but module wants older?
                      @sdetweil I would assume that the user may have installed a newer version. MM requires 2.6.6 which is not the ES version I think they changed from v3 onwards.
