Navigation
    • Search
    SOLVED unable to install dependencies
    Troubleshooting
    • T
      Terrago37 last edited by
      on my raspberry pi model 3 B+ with raspbian, I can’t install dependencies.
      nodejs and npm installed :
      nodejs : v10.15.3
      npm : 6.9.0
      root@raspberrypi:~/MagicMirror# npm install
      npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
      npm WARN tar ENOENT: no such file or directory, open ‘/root/MagicMirror/node_modules/.staging/wdio-dot-reporter-172d5a83/lib/reporter.js’
      npm WARN tar ENOENT: no such file or directory, open ‘/root/MagicMirror/node_modules/.staging/w3c-hr-time-b0db04bb/package.json’
      npm WARN tar ENOENT: no such file or directory, open ‘/root/MagicMirror/node_modules/.staging/jsprim-608f0a49/lib/jsprim.js’
      npm WARN tar ENOENT: no such file or directory, lstat ‘/root/MagicMirror/node_modules/.staging/w3c-hr-time-b0db04bb/coverage/hr-time’
      npm WARN tar ENOENT: no such file or directory, open ‘/root/MagicMirror/node_modules/.staging/socket.io-client-9b11ffbf/dist/socket.io.slim.dev.js.map’
      npm WARN tar ENOENT: no such file or directory, open ‘/root/MagicMirror/node_modules/.staging/mocha-f71b53de/README.md’
      npm WARN tar ENOENT: no such file or directory, open ‘/root/MagicMirror/node_modules/.staging/w3c-hr-time-b0db04bb/lib/calculate-clock-offset.js’
      npm WARN tar ENOENT: no such file or directory, open ‘/root/MagicMirror/node_modules/.staging/w3c-hr-time-b0db04bb/lib/clock-is-accurate.js’
      npm WARN tar ENOENT: no such file or directory, open ‘/root/MagicMirror/node_modules/.staging/w3c-hr-time-b0db04bb/lib/global-monotonic-clock.js’
      npm WARN tar ENOENT: no such file or directory, open ‘/root/MagicMirror/node_modules/.staging/w3c-hr-time-b0db04bb/lib/performance.js’
      npm WARN tar ENOENT: no such file or directory, open ‘/root/MagicMirror/node_modules/.staging/w3c-hr-time-b0db04bb/lib/utils.js’
      • A
        AxLed Module Developer last edited by
        @Terrago37
        You are logged in as root, did you try with logged in as pi?
        AxLED
        • T
          Hi AxLed,
          thank you, it’s works only in “pi” user.
