    Would this be possible?
    17 Posts 4 Posters 4.3k Views 4 Watching
    • ? Offline
      A Former User @motdog
      @motdog
      Are you talking about “MMM-Spotify”?
      You can do it more simple way.
      Add this into your css/custom.css
      #SPOTIFY.pausing {
      display:none;
      This could make module hiding when paused.
      M S 2 Replies Last reply Reply Quote 0
        bolish
        When the boss talks… :-)
        Indeed it seems easier as @Sean proposed if you use his new MMM-Spotify module. (Which I will try soon also).
        I’ve learnt one more thing myself.
        Thanks.
          motdog @Guest
          @Sean yep. That’s it. So if I put another module in the same spot but after it in the config, Spotify would show up when playing and when paused/shut down the other module would show up?
          • ? Offline
            @motdog
            Later module will jump down when spotify is appeared.
              motdog @Guest
              @Sean after further review I am using MMM-NowPlayingonSpotify Would it work on that or do I need to install MMM-Spotify. Looks like they do the same thing, MMM-Spotify lets you control via voice if you so choose, which I don’t have set up but it shouldn’t be a problem I assume.
              • ? Offline
                @motdog
                Controlling spotify on MM (besides voice, there could be many possibilities, - sensors, or any programmable condition) is difference. If you need not, nothing different.
                  motdog @Guest
                  @Sean thanks. Ill try to modify the .css in the module I have and see what happens.
                    bolish
                    @Sean
                    Still, would it be possible that MMM-Spotify sends notification when start playing and when end playing as I would like to hide some other modules when this one is playing?
                    Or is that also possible through .css?
                    Thx
                    • ? Offline
                      A Former User @bolish
                      @bolish
                      No notification about status emits . It will be added next updates.
                      He just asked hidnig module on pausing, that is possible with only css.
                        bolish
                        @Sean
                        OK, would be great (at least for my need). I will follow the git to be informed about the next update then. Thx.
