    MMM-SONOS showing then not showing
    5 Posts 2 Posters 2.0k Views 2 Watching
    • F
      frogywill Project Sponsor
      Hi!
      So I have MMM-Sonos mostly working. ‘Mostly’ because it works normally for a few hours but then, when music has been stopped for a while, it won’t re-appear once music starts playing again. If I restart MM it shows up fine again.
      When it is not showing, the Sonos API server is still working and I can see the correct tracks on the web page (http://ip:5005/zones).
      The logs don’t show any errors so I don’t know where to start looking to troubleshoot it…
      Any ideas?
        sdetweil
        open the developers window
        ctrl-shift-i
        select the console tab
        and scroll up to find any errors (usually red text)
        • F
          Interestingly, when the dev window opens, it cause the MM screen to be re-drawn and it makes the Sonos modules appear.
          The console shows no errors…
            sdetweil
            Can u show your config for this module?
            • F
              This is my config. But I think I may have solved it. I was using CSS to hide the “Zone” and “Type” info. If I remove the “visibility hidden” it works. So let’s see after a full day…
              			module: 'MMM-Sonos',
              			//header: "Now Playing",
              			position: "bottom_bar", // This can be any of the regions, best results in center regions
              			classes: 'daytime_scheduler',
              				showStoppedRoom: false,
              				showAlbumArt: true,
              				showRoomName: false,
              				exclude: ["Garden", "Living Room", "Bedroom"],
