    How can I run console.log("text") when I click on an image?
    3 Posts 2 Posters 828 Views 2 Watching
    • E Offline
      emrhssla
      MMM-imageSlideshow
      Only some of the codes in MMM-imageSlideshow were added.
      Module.register("MMM-BeforeImage", {
      	// Default module config.
      	defaults: {
          // load function
      	start: function () {
      	// Define required scripts.
      	getStyles: function() {
      	// the socket handler
      	// Override dom generator.
      	getDom: function () {
              // if an error, say so (currently no errors can occur)
              if (this.errorMessage != null) {
                  wrapper.innerHTML = this.errorMessage;
              // if no errors
              else {
                  // if the image list has been loaded
                  if (this.loaded === true) {
      				// if was delayed until restart, reset index reset timer
      				if (this.imageIndex == -2) {
      					this.imageIndex = -1;
      					clearInterval(this.interval);
      					var self = this;
      					this.interval = setInterval(function() {
      						self.updateDom(0);
      						}, this.config.slideshowSpeed);
                      // iterate the image list index
                      this.imageIndex += 1;
      				// set flag to show stuff
      				var showSomething = true;
                      // if exceeded the size of the list, go back to zero
                      if (this.imageIndex == this.imageList.length) {
                                             // console.log("MMM-ImageSlideshow sending reload request");
      				       // reload image list at end of iteration, if config option set
                                             if (this.config.reloadImageList)
                                                 this.sendSocketNotification('IMAGESLIDESHOW_RELOAD_FILELIST', this.config);
      					// if delay after last image, set to wait
      					if (this.config.delayUntilRestart > 0) {
      						this.imageIndex = -2;
      						wrapper.innerHTML = " ";
      						showSomething = false;
      						var self = this;
      							self.updateDom(0);
      							}, this.config.delayUntilRestart);
      					// if not reset index
      					else
      						this.imageIndex = 0;
      				if (showSomething) {
      					// create the image dom bit
      					var image = document.createElement("img");
        //@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ adding this code @@@@@@@@@@@@@@@@@@@@@@@@@@@@
      					image.id="imgid";
                                              var elemimg = document.getElementById("imgid")
                                                    elemimg.addEventListener("click", () => {
                                                      console.log(" click success !")
       //@@@@@@@@@@@@@@@@@@@@@@@@@@@ adding this code @@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                             // if set to make grayscale, flag the class set in the .css file
      					if (this.config.makeImagesGrayscale)
      						image.className = "desaturate";
      					// create an empty string
      					var styleString = '';
      					// if width or height or non-zero, add them to the style string
      					if (this.config.fixedImageWidth != 0)
      						styleString += 'width:' + this.config.fixedImageWidth + 'px;';
      					if (this.config.fixedImageHeight != 0)
      						styleString += 'height:' + this.config.fixedImageHeight + 'px;';
      					// if style string has antyhing, set it
      					if (styleString != '')
      						image.style = styleString;
      					// set the image location
      					// ad the image to the dom
      					//var elem = document.getElementById("imageclick")
      					wrapper.appendChild(image);
                  else {
                      // if no data loaded yet, empty html
              // return the dom
      		return wrapper;
      but Console show ‘Uncaught TypeError : Cannot read property ‘addEventListener’ of null’
        sdetweil
        @emrhssla said in How can I run console.log("text") when I click on an image?:
        var elemimg = document.getElementById(“imgid”)
        elemimg.addEventListener(“click”, () => {
        because the getDom() function has not returned the new content to be added to the dom, you cannot search the dom to find it YET… cause its only in memory for your module…
        i always want this routine to be called getDomContribution(), cause thats what it does. it gets this modules content contrubition to the single web page… on return, the MM runtime will then insert the content in the position the module is defined in.
        but, you don’t need to search… you have it already
        					image.id="imgid";
        					image.addEventListener("click", () => {
          sdetweil @emrhssla
          @emrhssla also, on the module side, logging is Log.log() instead of console.log()
          then u open the developers window, and select the console tab…
          currently there is no mechanism to show both parts of a module in the same place
          node_helper = console.log() - shows in terminal window
          module.js = Log.log() - shows in developers window, console tab
