    CSS show/hidden module animated
    13 Posts 2 Posters 5.9k Views 2 Watching
    • saljokeS Offline
      saljoke
      Hello,
      I will try to change the transition animation fading when one module is showing then also when suspended.
      I try to animate with custom.css but it only function when using .region.left for example and only when the magicmirror is starting.
      I tried also with .resume() and I try to catch how to disable fade transition.
      Have you got any ideas?
      Thanks from Bea!
        sdetweil
        this is hard coded in main.js
        var hideModule = function(module, speed, callback, options) {
        		options = options || {};
        		// set lockString if set in options.
        		if (options.lockString) {
        			// Log.log("Has lockstring: " + options.lockString);
        			if (module.lockStrings.indexOf(options.lockString) === -1) {
        				module.lockStrings.push(options.lockString);
        		var moduleWrapper = document.getElementById(module.identifier);
        		if (moduleWrapper !== null) {
        			moduleWrapper.style.transition = "opacity " + speed / 1000 + "s";
        			moduleWrapper.style.opacity = 0;
        			clearTimeout(module.showHideTimer);
        			module.showHideTimer = setTimeout(function() {
        • saljokeS Offline
          saljoke
          And how to change this function property in other transition ?
            sdetweil @saljoke
            @saljoke sorry, I don’t understand your question…
            • saljokeS Offline
              saljoke
              How to add in custom.css to define this function and have another transition animation…
                sdetweil @saljoke
                @saljoke I don’t know how to override what the code does
                saljokeS 1 Reply Last reply Reply Quote 0
                • saljokeS Offline
                  saljoke @sdetweil
                  @sdetweil so I have to try to change it in js… And try to define this function in every modules
                    sdetweil @saljoke
                    @saljoke sorry, i do not know… i do not understand what you wish to accomplish
                    • saljokeS Offline
                      saljoke
                      I solved it using the file CSS on MMM-SimpleLogo folder and solve partially the animation but I can’t control the fade property and can’t animated the suspended modules
                      • saljokeS Offline
                        saljoke
                        alt text
                        A little preview…
                          sdetweil @saljoke
                          @saljoke see nothing
                          • saljokeS Offline
                            saljoke @sdetweil
                            @sdetweil https://ibb.co/njNBZTj
                              sdetweil @saljoke
                              @saljoke interesting
