    Error MMM-Facial-Recognition
    6 Posts 3 Posters 861 Views 3 Watching
    • K Offline
      kms4381
      I tried to run MMM-Facial-Recognition, but it was blocked at this point.
      { Error: KeyError: '/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/training.xml'
          at PythonShell.parseError (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_modules/python-shell/index.js:246:21)
          at terminateIfNeeded (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_modules/python-shell/index.js:129:32)
          at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_modules/python-shell/index.js:121:13)
          at ChildProcess.emit (events.js:182:13)
          at Process.ChildProcess._handle.onexit (internal/child_process.js:237:12)
          ----- Python Traceback -----
          File "modules/MMM-Facial-Recognition/facerecognition/facerecognition.py", line 59, in <module>
            model.read(config.get("/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/training.xml"))
          File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition/facerecognition/config.py", line 55, in get
            return CONFIG[key]
        traceback:
         'Traceback (most recent call last):\n  File "modules/MMM-Facial-Recognition/facerecognition/facerecognition.py", line 59, in <module>\n    model.read(config.get("/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/training.xml"))\n  File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition/facerecognition/config.py", line 55, in get\n    return CONFIG[key]\nKeyError: \'/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/training.xml\'\n',
        executable: 'python',
        options: null,
        script:
         'modules/MMM-Facial-Recognition/facerecognition/facerecognition.py',
        args: null,
        exitCode: 1 }
      my facerecognition.py is
      import sys
      import json
      import time
      import face
      import cv2
      import config
      import signal
      def to_node(type, message):
          try:
              print(json.dumps({type: message}))
          except Exception:
              pass
          sys.stdout.flush()
      to_node("status", "Facerecognition started...")
      current_user = None
      last_match = None
      detection_active = True
      login_timestamp = time.time()
      same_user_detected_in_row = 0
      to_node("status", 'Loading training data...')
      if config.get("recognitionAlgorithm") == 1:
          to_node("status", "ALGORITHM: LBPH")
          model = cv2.face.LBPHFaceRecognizer_create(threshold=config.get("lbphThreshold"))
      elif config.get("recognitionAlgorithm") == 2:
          to_node("status", "ALGORITHM: Fisher")
          model = cv2.createFisherFaceRecognizer(threshold=config.get("fisherThreshold"))
      else:
          to_node("status", "ALGORITHM: Eigen")
          model = cv2.createEigenFaceRecognizer(threshold=config.get("eigenThreshold"))
      # Load training file specified in config.js
      to_node("status", 'Training data loaded!')
      camera = config.get_camera()
      def shutdown(self, signum):
          to_node("status", 'Shutdown: Cleaning up camera...')
          camera.stop()
          quit()
      signal.signal(signal.SIGINT, shutdown)
      time.sleep(1)
      while True:
          time.sleep(config.get("interval"))
          if detection_active is True:
              image = camera.read()
              image = cv2.cvtColor(image, cv2.COLOR_RGB2GRAY)
              result = face.detect_single(image)
              if result is None:
                  if (current_user is not None and time.time() - login_timestamp > config.get("logoutDelay")):
                      to_node("logout", {"user": current_user})
                      current_user = None
                  continue
              x, y, w, h = result
                  crop = face.crop(image, x, y, w, h)
              else:
                  crop = face.resize(face.crop(image, x, y, w, h))
              label, confidence = model.predict(crop)
              if (label != -1 and label != 0):
                  if (label == last_match and same_user_detected_in_row < 2):
                      same_user_detected_in_row += 1
                  if label != last_match:
                  if (label != current_user and same_user_detected_in_row > 1):
                      current_user = label
                      to_node("login", {"user": label, "confidence": str(confidence)})
                  last_match = label
              elif (current_user != 0 and time.time() - login_timestamp > 5):
                  current_user = 0
                  to_node("login", {"user": current_user, "confidence": None})
              else:
                  continue
      #Load training file specified in config.js
      model.read(config.get(“/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/training.xml”))
      Is this the cause?
      What should I do about this part?
      my config.js is
      	module: "newsfeed",
      	position: "bottom_bar",
      	classes: 'minsoo',
      		feeds: [
      				title: "New York Times",
      		showSourceTitle: true,
      		showPublishDate: true
      	module: 'MMM-Facial-Recognition',
      		recognitionAlgorithm: 1,
      		lbphThreshold: 50,
      		fisherThreshold: 250,
      		eigenThreshold: 3000,
      		useUSBCam: true,
      		trainingFile: 'modules/MMM-Facial-Recognition-Tools/training.xml',
      		interval: 2,
      		logoutDelay: 15,
      		users: ['minsoo'],
      		defaultClass: "default",
      		everyoneClass: "everyone",
      		welcomeMessage: true
      I am anxiously waiting for your help.
        merttcoo
        Same problem to me . Did you find a solution ?
          sdetweil
          the readme says
          To train the needed model use the MMM-Facial-Recognition-Tools.
          wen you follow that link, it says
          DEPRECIATED
          This module is no longer supported. When it does work, the facial recognition methods used performed poorly.
          there are a LOT of steps to execute to ‘train the model’
          did u do that? (it creates the missing xml file)
            sdetweil
            to work on a user problem with one of my modules, I installed the https://github.com/nischi/MMM-Face-Reco-DNN module, and it was very complex and time consuming. (I installed in on my linux PC, not my pi)
              merttcoo
              what do you suggest ?
                sdetweil @merttcoo
                @merttcoo i don’t have a recommendation. I don’t use this function
                so you can try the steps to create the model with the one you have partly installed,
                or you can try the other one.
