    How to use the 'node_helper', 'serialport'
    23 Posts 2 Posters 8.9k Views 2 Watching
    • N
      nhpunch
      const NodeHelper = require('node_helper')
      const Serialport = require("serialport");
        start: function () {
        socketNotificationReceived: function (notification, payload) {
          const self = this
          if (notification === 'CONFIG') {
            self.config = payload
          var serialport = new Serialport('/dev/ttyACM0', {
      		baudRate: 9600
          var led = 0;
            serialport.open(function () {
              console.log('connect...');
              serialport.on('data', function(data) { // 아두이노로부터 전달된 데이터
                console.log('data received: ' + data);
              setInterval( function() { // 2초마다 아두이노에게 문자열을 전송하는 예
                led = !led;
                serialport.write(led==true ? "1" : "0", function(err, result){
                  if(err){
                   console.log(err);
              }, 5000);
      this is node_helper
      Module.register('MMM-Serial-Notifications', {
        defaults: {
        getScripts: function() {
      		return ["modules/MMM-Serial-Notifications/js/jquery.js"];
      	getStyles: function() {
      		return ["mm-MMM-Serial-Notifications-style.css"];
          Log.info("Starting module: " + this.name);
          this.sendSocketNotification('CONFIG', this.config)
      	this.sendNotification(notification, payload)
      	getDom: function() {
      		var button = document.createElement("div");
      		var text = document.createElement("span");
      		var overlay = document.createElement("div");
      		var hidden = true;
      		overlay.className = "paint-it-black";
      		button.className = "hide-toggle";
      		button.appendChild(text);
      		text.innerHTML = "ON";
      		var led = 0;
          wrapper.appendChild(button);
      		wrapper.appendChild(overlay);$(button).on("click", function(){
      			if(hidden){
      				$(overlay).fadeIn(1000);
      				$(button).fadeTo(1000, 0.3);
      				$(text).html('OFF');
      				hidden = false;
      				serialport.write('0');
      			}else{
      				$(overlay).fadeOut(1000);
      				$(button).fadeTo(1000, 1);
      				$(text).html('ON');
      				hidden = true;
      				serialport.write('1');
      		return wrapper;
      this is module
      I want to send ‘1’, ‘0’ to Arduino by pressing the button
      Now the node_helper is communicating in setInterval
      but, can not use serialport.write in a module
      How do I use the serialport in the module?
      Or, how do I create a button event in the node_helper?
      I am a very beginner. Please let me know. :disappointed_but_relieved_face:
        sdetweil @nhpunch
        @nhpunch u cannot talk to hardware in module, you do that in node_helper.
        if you split the mirror into two parts server and client… node_helper runs on the server,
        module runs in the client browser…(even in the same machine)
        here is a package u can install to enable code to talk to serial port in node helper
        https://www.npmjs.com/package/serialport
        button would be in the module. you can use an html button, or more advanced div and span
        then when u get the button action in the module, you sendSocketNotification() a message to the node_helper… then node_helper then talks serial port to your arduino.
        • N
          nhpunch @sdetweil
          Thank you very much for your reply.
          You said that hardware and modules did not communicate, but communication is possible.
                    led = !led;
                      if(err){
                       console.log(err);
                  }, 5000);
          In this code, it is possible to send a string to Arduino
          What I’m wondering is how to do sendSocketNotification ().
          I referenced https://github.com/MichMich/MagicMirror/tree/master/modules but did not understand
          Please let me know how to send it. Then I will be very thankful:folded_hands_light_skin_tone:
            sdetweil @nhpunch
            @nhpunch there are two parts of a MagicMirror module
            1. node_helper, runs on server, can use require(…some other library…)
            2. module_name.js, runs in browser, manages data presented on screen, cannot use require(…)
            so, the two parts can talk to each other by sending socket messages, using the supplied function
            sendSocketNotification(some_id_string, some_data_packet)
            the receiver of the message gets called at the function socketNotificationReceived(some_id_string, some_data_packet)
            get my sample module that has both parts, and uses timer,
            https://github.com/sdetweil/SampleModule
            also see the developers doc here
            my sample implements all the functions so you can see them…
            not all are needed… so u can comment out the ones u don’t need to use
            config for my sample, to add to config.js is
                module: "SampleModule",
                position: "center",
                  message: "this is a test from config entry"
            • N
              nhpunch @sdetweil
              I was really grateful and ran the sample code.
              But I do not know what to send as a module to do what I want.
              Can you help me with my module and node_helper?
                sdetweil @nhpunch
                @nhpunch sorry, i don’t understand
                  @sdetweil you make up your own messages…
                  so, you have a push button on the screen (done by module_name,js)… when push button,
                  send button name and 1 to node helper… when it gets 1, it uses serial port to send to arduino.
                  when u let up on button , you send 0…
                  write out what you WANT the system to do… (design)
                  then implement THAT design
                  • N
                    nhpunch @sdetweil
                    I’m doing what you said, but I do not know how to send it to the node_helper when the button is pressed.
                    I’m so sorry.
                      sdetweil @nhpunch
                      @nhpunch this.sendSocketNotification(…,…)
                      from the doc
                      this.sendSocketNotification(notification, payload)
                      notification String - The notification identifier.
                      payload AnyType - Optional. A notification payload.
                      If you want to send a notification to the node_helper, use the sendSocketNotification(notification, payload). Only the node_helper of this module will receive the socket notification.
                      Example:
                      this.sendSocketNotification('SET_CONFIG', this.config);
                      you’ll see in the sample that this is used twice… once by the module_name.js to send the config over to the node_helper and once by the node_helper to send a new text string to the module_name.js to display
                      its also used in your module, from the first post above
                      • N
                        nhpunch
                        I did my best, but I did not succeed.
                        I’m a real idiot.
                        Can you take a look at my code?
                          sdetweil @nhpunch
                          @nhpunch sure. Make a GitHub repo, and let me know
                          • N
                            nhpunch
                            https://github.com/nhpunch/sohard
                            I created ‘is_Pushed’ and tried to work by repeating false, true when the button was pressed
                              sdetweil @nhpunch
                              @nhpunch said in How to use the 'node_helper', 'serialport':
                              Ok, the fundamental problem is what happens in getDom()…
                              until getDom() returns this modules contribution to the single web page… that content is NOT IN the DOM… It is just in memory in your module.
                              so the jquery $(button) will not work. ($ means document.) and the content is NOT IN the document… (yet)
                              SO, you could change to use the non jquery
                              button.addEventListener('click', ()=> {
                                 	//$(button).on("click", function(){
                                 		if(self.hidden){
                                 		//	$(overlay).fadeIn(1000);
                                 		//	$(button).fadeTo(1000, 0.3);
                                 		//	$(text).html('OFF');
                                                             Log.log("button pushed 'on' ")
                                 			self.hidden = false;
                                 			self._isPushed = false;
                                 		}else{
                                 		//	$(overlay).fadeOut(1000);
                                 		//	$(button).fadeTo(1000, 1);
                                 		//	$(text).html('ON');
                                                             Log.log("button pushed 'off' ")
                                 			self.hidden = true;
                                 			self._isPushed = true;
                                 	return wrapper;
                              but… all the data elements button, overlay and text will be long gone by the time the button is pushed.
                              so you will have to redesign finding them again (document.getElementByID()… or something, a different jquery selector.)
                              OR
                              you can push the jquery code off into a timeout handler (wait a second or 2)…
                              but you will still have to redesign how to find the button… as its data element on the stack of getDom() will be long gone.
                              think of getDom() as a person taking notes… they write it down on their notepad.
                              then LATER they edit a big document and add their text…
                              until they complete that task, you can search thru the big document all u want, the text will NOT be there…
                              when I used the sample above, the button responded…
                              u know you can open the developers window (npm start dev) and select the console window,
                              and messages from the module_name.js will show there
                              message from the node_helper will appear in the terminal window where u issued npm start dev & (note the & at the end to allow the prompt to come back)…
                              • N
                                nhpunch @sdetweil
                                      const self = this;
                                      self.config = payload;
                                    else if(notification ==='BUTTON_PRESSED')
                                		baudRate: 9600
                                    var led = 0;
                                        if(this._isPushed==false)
                                          serialport.write("0");
                                        else if(this._isPushed==true)
                                          serialport.write("1");
                                Thank you very much…!!! Overlay is not important.
                                It was working as you told me.
                                Currently, node_helper sets the following, but serial.write does not work. May I ask you one last time?
                                I’m really desperate:folded_hands_light_skin_tone: :folded_hands_light_skin_tone: :folded_hands_light_skin_tone: :folded_hands_light_skin_tone:
                                I uploaded the Arduino code.
                                int led = 13;
                                void setup() {
                                  Serial.begin(9600);
                                  pinMode(led, OUTPUT);
                                  Serial.println(“hello”);
                                void loop() {
                                  static int incomingValue = 0; // nodeJS에서 보낸값
                                  if ( Serial.available() > 0 ) { // 뭔가 입력값이 있다면
                                    incomingValue = Serial.read();
                                    Serial.println(incomingValue);
                                  if ( incomingValue == 49 ) { // 값이 ‘1’ 이면
                                  digitalWrite(13, HIGH); // LED를 켠다.
                                  if ( incomingValue == 48 ) { // 값이 ‘0’ 이면
                                  digitalWrite(13, LOW); // LED를 끈다.
                                  deayl(2000);
                                  sdetweil
                                  where is _isPushed defined or set?
                                  i know it is in module_name.js, but node_helper cannot see it…
                                  you should send that as the payload on button_pressed message
                                  • N
                                    nhpunch
                                          const self = this;
                                          this._isPushed = payload;
                                    		baudRate: 9600
                                    Is that right? I’m really sorry for you.
                                      sdetweil @nhpunch
                                      @nhpunch yes if you send it that way
                                      this.sendSocketNotification(“BUTTON_PUSHED”,this._isPushed)
                                      N 2 Replies Last reply Reply Quote 0
                                      • N
                                        nhpunch @sdetweil
                                        false, true works with two button in module
                                        It seems that the value can not be sent to the node_helper
                                        why?
                                        	buttonoff.addEventListener('click', ()=> {
                                        			Log.log("button pushed 'on'")
                                           			this._isPushed = false;
                                        			console.log(this._isPushed);
                                           			this._isPushed = true;
                                        this is module
                                                  serialport.write(this._isPushed==true? '1' : '0');
                                        this is node_helper
                                        • N
                                          nhpunch @sdetweil
                                                console.log(payload);
                                          ‘false’ is displayed in the terminal window
                                          ._isPushed is passed to node_helper, but I think that the changed value is not sent when the button is pressed.
                                          Please advise…:folded_hands_light_skin_tone: :folded_hands_light_skin_tone: :folded_hands_light_skin_tone:
                                          If this is solved, it’s really a success.:flexed_biceps_light_skin_tone:
                                            sdetweil @nhpunch
