    HotWords Module - Exception when saying "Magic Mirror"
    3 Posts 2 Posters 1.5k Views 2 Watching
      blee1997
      Error message appears only when saying the key words to activate Google Assistant
      Error Message:
      { Error: spawn ENOMEM
          at ChildProcess.spawn (internal/child_process.js:357:11)
          at spawn (child_process.js:540:9)
          at LPCM16.start (/home/pi/MagicMirror/modules/MMM-Hotword/components/lpcm16.js:101:15)
          at Class.startListening (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:217:14)
          at Class.activate (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:175:10)
          at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:72:16)
          at Socket.<anonymous> (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
          at Socket.emit (events.js:182:13)
          at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
          at process._tickCallback (internal/process/next_tick.js:61:11) errno: 'ENOMEM', code: 'ENOMEM', syscall: 'spawn' }
      I am running MagicMirror2 on a Raspberry Pi 3B+
      • ? Offline
        A Former User @blee1997
        @blee1997
        Error means Memory shortage. If there is no memory issue from other modules, add afterRecordLimit:0 to your config for Hotword. (See the docs for configuration)
          blee1997 @Guest
          @Sean I did a clean install of MM again, added AssistantMk2 and Hotwords. Then added the line to the Hotwords config and the error still occurs.
