HotWords Module - Exception when saying "Magic Mirror"
Error message appears only when saying the key words to activate Google Assistant
Error Message:Whoops! There was an uncaught exception... { Error: spawn ENOMEM at ChildProcess.spawn (internal/child_process.js:357:11) at spawn (child_process.js:540:9) at LPCM16.start (/home/pi/MagicMirror/modules/MMM-Hotword/components/lpcm16.js:101:15) at Class.startListening (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:217:14) at Class.activate (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:175:10) at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:72:16) at Socket.<anonymous> (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11) at Socket.emit (events.js:182:13) at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12 at process._tickCallback (internal/process/next_tick.js:61:11) errno: 'ENOMEM', code: 'ENOMEM', syscall: 'spawn' }I am running MagicMirror2 on a Raspberry Pi 3B+
@blee1997
Error means Memory shortage. If there is no memory issue from other modules, addafterRecordLimit:0to your config for Hotword. (See the docs for configuration) -
@Sean I did a clean install of MM again, added AssistantMk2 and Hotwords. Then added the line to the Hotwords config and the error still occurs.
