    MMM-Nest-Cameras no longer works
    2 Posts 2 Posters 920 Views 2 Watching
    • F
      FreelanceMKE
      does anyone know or have seen any new modules for nest cameras? I tried to install the MMM-Nest-Cameras module but since Nest no longer has their own API’s and you have to go do things through Google I was wondering if anyone has been able to modify their current module to work with the new API, or if they have seen any new modules for nest cameras with the new api?
      • J
        Jbabineau
        From the information on the nest site. Google is forcing you to use their assistant. and the API is closed down. Not sure there will be a new API to update to but you have until August 31st to create an account under the nest work with nest (WWN) program. You will need a WWN account though to access the existing API.
