MMM-BMWConnected (BMW Connected Drive data)
Description:
Day two of knowing Magic Mirror was a thing. I built something for my car. If you have a BMW with active BMW Connected Drive service, you can use this module to show:
- lock status
- charging/unplugged
- battery charge
- total miles driven
- electric only range (miles)
- fuel range (miles)
- last time the Connected Drive portal received data from the car
It also downloads the image of the car itself from the BMW API, so I would be really interested to see someone else running it, to see if that works for anything other than the i8. If you do, send me pics at https://twitter.com/hdurdle
Screenshots:
Download:
Version 1
- Initial release
Hi, Greetings from South Africa, i have tried the module but it only shows as loading. I followed your instructions for powershell and i get some data for my car. Could you please point me in the right direction so that it works on MagicMirror? i used the …co.za apiBase and i get the vehicle data
@hdurdle This is cool, the picture is correct, but icons. (I live in Taiwan)
Could you help? what should I do to fix icon links? thank you very much.
I found an error in css "faIcon.classList.add(“fas”); – that’s why no icon show up.
and NaN Km – my car it’s not hybrid…@hdurdle does BMW API has “Current location” feature? thanks.
@iMAGiC hi yes it does have longitude and latitude values. Download the powershell scripts and play around with them to see what values are available. I have changed mine to remove electric vehicle specific parameters and added things like fuel remaining, window/sunroof status and also the vehicle pictures that change after a set time.
@hdurdle: Hi Howard, pretty cool module!
Can it be tweaked to work for Mini vehicles as well? I do have access to a connected service for my car using: https://www.mini-connected.com/germany/de/
Thanks in advance!
@hdurdle Is this module still working on your side?
It has stopped work since last week.
Is it a token issue or BWM has already modified API?Thank you~
Jake -
@imagic , since yesterday I only got the information from the module, “Lade …”, so for english user “loading …”. Whats going wrong here?
