    MMM-BMWConnected (BMW Connected Drive data)
    32 Posts 15 Posters 18.1k Views 14 Watching
    • hdurdleH Offline
      hdurdle
      Description:
      Day two of knowing Magic Mirror was a thing. I built something for my car. If you have a BMW with active BMW Connected Drive service, you can use this module to show:
      • lock status
      • charging/unplugged
      • battery charge
      • total miles driven
      • electric only range (miles)
      • fuel range (miles)
      • last time the Connected Drive portal received data from the car
      It also downloads the image of the car itself from the BMW API, so I would be really interested to see someone else running it, to see if that works for anything other than the i8. If you do, send me pics at https://twitter.com/hdurdle
      Screenshots:
      MMM-BMWConnected
      Download:
      [card:hdurdle/MMM-BMWConnected]
      Version 1
      • Initial release
      iMAGiCI 2 Replies Last reply Reply Quote 3
        philmavedzenge
        Hi, Greetings from South Africa, i have tried the module but it only shows as loading. I followed your instructions for powershell and i get some data for my car. Could you please point me in the right direction so that it works on MagicMirror? i used the …co.za apiBase and i get the vehicle data
        • iMAGiCI Offline
          iMAGiC @hdurdle
          @hdurdle This is cool, the picture is correct, but icons. (I live in Taiwan)
          Could you help? what should I do to fix icon links? thank you very much.
          BMW
          Choice * Judgment * Values
          iMAGiCI 1 Reply Last reply Reply Quote 0
          • iMAGiCI Offline
            iMAGiC @iMAGiC
            I found an error in css "faIcon.classList.add(“fas”); – that’s why no icon show up.
            and NaN Km – my car it’s not hybrid…
            @hdurdle does BMW API has “Current location” feature? thanks.
            BMW
              philmavedzenge @iMAGiC
              @iMAGiC hi yes it does have longitude and latitude values. Download the powershell scripts and play around with them to see what values are available. I have changed mine to remove electric vehicle specific parameters and added things like fuel remaining, window/sunroof status and also the vehicle pictures that change after a set time.
                PH1TCH
                @hdurdle: Hi Howard, pretty cool module!
                Can it be tweaked to work for Mini vehicles as well? I do have access to a connected service for my car using: https://www.mini-connected.com/germany/de/
                Thanks in advance!
                • iMAGiCI Offline
                  iMAGiC @hdurdle
                  @hdurdle Is this module still working on your side?
                  It has stopped work since last week.
                  Is it a token issue or BWM has already modified API?
                  Thank you~
                  Jake
                    musicnrw @iMAGiC
                    @imagic , since yesterday I only got the information from the module, “Lade …”, so for english user “loading …”. Whats going wrong here?
                    • iMAGiCI Offline
                      iMAGiC @musicnrw
                      @musicnrw I don’t know, either. already sent message to @hdurdle.
                      • K Offline
                        Klassieker
                        @imagic Is this problem solved?
                        Just installed this module and also says “bezig met laden”
                        I can’t reach @hdurdle , don’t have facebook, twitter, instagram and other social media ;-)
                        Also don’t know how to use the shell scripts.
                          sdetweil @Klassieker
                          @klassieker said in MMM-BMWConnected (BMW Connected Drive data):
                          shell scripts are just commands (written in text form)
                          so u can execute a bunch of commands and use logic…
                          to execute one of those, you would open a terminal window
                          ctrl-alt-t on the pi desktop, or open an ssh session from your windows/mac box to the pi
                          (to minimize MM to get to the desktop, alt-spacebar, n just line on windows for minimze fullscreen app)
                          I don’t know about the module…
                          • K Offline
                            Klassieker @sdetweil
                            @sdetweil Hi Sam, Thanks for your answer. I can’t get it to run on the pi (not enough knowledge of the pi, i’m learning),
                            but I managed running it on my Windows PC and got some data from the script.
                            So I think there is a problem in the module.
                            • K Offline
                              Klassieker @Klassieker
                              @klassieker
                              I have made some changes in the module and now it is working for me (changed defaults: apiBase, couldn’t get it to work with config: apiBase)
                              Also put an extra variable in the defaults: for selecting my cars
                              S C 2 Replies Last reply Reply Quote 0
                                what happened there? we should figure that out as its part of the base MM design
                                • K Offline
                                  the module didn’t react on config: apiBase. after changing the url in the default, I could go further.
                                  Furthermore, I added a car: element in the config and copied the module, so I could see both my cars.
                                    ok, don’t know what that means…
                                    what did u try to do in the module config that didn’t work
                                    • K Offline
                                      Adding the row:
                                      apiBase: “https://www.bmw-connecteddrive.com”,
                                        @klassieker >apiBase: “https://www.bmw-connecteddrive.com”,
                                        it doesn’t want the “https://” in the front, it adds that internally
                                        apiBase	The location of the base API URL for your region.
                                        Default: www.bmw-connecteddrive.co.uk
                                        • K Offline
                                          Ah, I overread that part of https://.
                                          I changed it back and it is still working .
                                          Many thanks for helping me.
                                          • W Offline
                                            wwats
                                            I still have the problem with “Loading”, and nothing happened. My module looks like the print screen. What is my fault?
                                            Thanks a lot !
