    mmm-nest-status unresponsive after 12hours
    34 Posts 4 Posters 16.4k Views 4 Watching
      dazza120
      @sdetweil can you offer any help on how to track down the problem with this be unresponsive after awhile
        sdetweil @dazza120
        @dazza120 I need to.look at that code. I am away til tomorrow.
        I have been fighting a similar crash
        on one of my mirrors… Which seem to be error related. They didn’t run for 6 hours, now w no changes, been running for 5 days!
          dazza120 @sdetweil
          @sdetweil cheers mate I’ll wait till your all good
          • C Offline
            costascontis
            had the same problem with this module…had to restart my mm to keep it running so i gave up.Its a pity cause its so nice good looking module but after some hours it gets unresponsive …
              rts58
              I also have been having the same issue with this module. It worked well for months. I’ve just been restarting and haven’t had time to chase down the errors.
                sdetweil
                i think this is an api redirect issue, which the current code doesn’t cover…
                please try my updated module
                rename your folder to some other name
                then
                git clone https://github.com/sdetweil/mmm-nest-status
                nothing else has changed
                there is an api call limit… roughly once per minute… doesn’t say if it ever recovers from reaching the limit
                looks like it might recover after 1 hour… SINCE THE LAST CALL… but the app keeps trying every 10 minutes
                but you should see this on the UI…
                ‘The Nest API rate limit has been exceeded.
                This module will try to load data again in 10 minutes.’;
                  dazza120 @sdetweil
                  @sdetweil said in mmm-nest-status unresponsive after 12hours:
                  Yeah when I changed it to every 10seconds it showed the limit exceeded will try again in 10min so I think it does recover. But it’s never showed this when I put it to every 1min as per nest api. I’ll have a go with yours thanks very much mate.👍🏾
                    sdetweil @dazza120
                    @dazza120 cool. I think it should enforce 1 minute minimum…
                      dazza120 @sdetweil
                      @sdetweil seems to be working fine mate cheers 👍🏾
                        dazza120
                        @sdetweil its working a treat mate thanks
                        • 4 / 4
