    mmm-nest-status unresponsive after 12hours
    34 Posts 4 Posters 19.0k Views 4 Watching
      rts58 @sdetweil
      @sdetweil just got the update, I’ll let you know what I find. Thanks!
        dazza120 @sdetweil
        @sdetweil updated! 👍🏾
          rts58
          It’s been 24 hours and still working fine! Thanks!
            costascontis
            is the issue solved?How?
              sdetweil @costascontis
              @costascontis bug in the original repo, use mine
              git clone https://github.com/sdetweil/mmm-nest-status
              C 1 Reply Last reply
                costascontis @sdetweil
                @sdetweil thanx mate.I use your repo ,it works fine but after a day or so i get a "Nest API Error:[object Object]
                  @costascontis i just added some code to display the contents of that error object,
                  do a git pull in the module folder and restart the mirror app.
                    @sdetweil so the error is
                    Nest API Error:{"code":"ECONNRESET","path"null,"host":"firebase-apiserver38-tah01-iad01.dapi.production.nest.com","port":"9553"}
                      @costascontis ain’t that helpful!
                        @sdetweil this is the error appearing at my MM screen after 6-8 hours.What else can i do to help?
                          @costascontis the nest server is having some trouble… I don’t know what… maybe change the timeout longer? I don’t know anything about the api. I just fixed a bug in the error handling
