    mmm-nest-status unresponsive after 12hours
    34 Posts 4 Posters 18.8k Views 4 Watching
      dazza120 @sdetweil
      @sdetweil no yours works well the original doesn’t
        dazza120 @sdetweil
        @sdetweil it looks like its playing up again i had couple of days with it working on the button now its back to giving up after 12hours :(
          sdetweil @dazza120
          @dazza120 ok. Can u look at the developers window console to see if any messages?
            rts58
            Bummer, mine has stopped as well.
              rts58
              I tried to open the console via remote but wasn’t able to. Sorry.
                dazza120 @sdetweil
                @sdetweil it’s literally just the seconds of the time I’m seeing which I might try to stop not seen any Nest process but I did restart it before this so that error has likely gone, as soon as it happens again I will dev console and check thank you
                  rts58
                  Based upon the display, it stopped on me last night. I was running mm serveronly so I could see the dev output in browser. I couldn’t find any errors. It could have stopped when scheduler is set to hide all modules. I did see this in the console after this mornings schedule to show modules:
                  TypeError: Cannot read property 'statusCode' of undefined
                      at Request._callback (/home/pi/MagicMirror/modules/mmm-nest-status/node_helper.js:20:25)
                      at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
                      at emitOne (events.js:116:13)
                      at Request.emit (events.js:211:7)
                      at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:881:8)
                      at ClientRequest.emit (events.js:211:7)
                      at TLSSocket.socketErrorListener (_http_client.js:401:9)
                      at TLSSocket.emit (events.js:211:7)
                  In the past I don’t think I ever had a conflict between scheduler and nest status.
                    sdetweil @rts58
                    @rts58 cool… I just pushed a change to my repo for this error…
                    if using my repo version, git pull to get the updated node_helper.js
                    R D 2 Replies Last reply Reply Quote 0
                      rts58 @sdetweil
                      @sdetweil just got the update, I’ll let you know what I find. Thanks!
                        dazza120 @sdetweil
                        @sdetweil updated! 👍🏾
                          rts58
                          It’s been 24 hours and still working fine! Thanks!
                            costascontis
                            is the issue solved?How?
                              sdetweil @costascontis
                              @costascontis bug in the original repo, use mine
                              git clone https://github.com/sdetweil/mmm-nest-status
                                costascontis @sdetweil
                                @sdetweil thanx mate.I use your repo ,it works fine but after a day or so i get a "Nest API Error:[object Object]
                                  @costascontis i just added some code to display the contents of that error object,
                                  do a git pull in the module folder and restart the mirror app.
                                    @sdetweil so the error is
                                    Nest API Error:{"code":"ECONNRESET","path"null,"host":"firebase-apiserver38-tah01-iad01.dapi.production.nest.com","port":"9553"}
                                      @costascontis ain’t that helpful!
                                        @sdetweil this is the error appearing at my MM screen after 6-8 hours.What else can i do to help?
                                          @costascontis the nest server is having some trouble… I don’t know what… maybe change the timeout longer? I don’t know anything about the api. I just fixed a bug in the error handling
