    mmm-nest-status unresponsive after 12hours
    34 Posts 4 Posters 18.8k Views 4 Watching
      sdetweil @dazza120
      @dazza120 cool. I think it should enforce 1 minute minimum…
        dazza120 @sdetweil
        @sdetweil seems to be working fine mate cheers 👍🏾
          dazza120
          @sdetweil its working a treat mate thanks
            sdetweil @dazza120
            @dazza120 mine works, but original does not?
              dazza120 @sdetweil
              @sdetweil no yours works well the original doesn’t
                dazza120 @sdetweil
                @sdetweil it looks like its playing up again i had couple of days with it working on the button now its back to giving up after 12hours :(
                  sdetweil @dazza120
                  @dazza120 ok. Can u look at the developers window console to see if any messages?
                    rts58
                    Bummer, mine has stopped as well.
                      rts58
                      I tried to open the console via remote but wasn’t able to. Sorry.
                        dazza120 @sdetweil
                        @sdetweil it’s literally just the seconds of the time I’m seeing which I might try to stop not seen any Nest process but I did restart it before this so that error has likely gone, as soon as it happens again I will dev console and check thank you
                          rts58
                          Based upon the display, it stopped on me last night. I was running mm serveronly so I could see the dev output in browser. I couldn’t find any errors. It could have stopped when scheduler is set to hide all modules. I did see this in the console after this mornings schedule to show modules:
                          TypeError: Cannot read property 'statusCode' of undefined
                              at Request._callback (/home/pi/MagicMirror/modules/mmm-nest-status/node_helper.js:20:25)
                              at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
                              at emitOne (events.js:116:13)
                              at Request.emit (events.js:211:7)
                              at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:881:8)
                              at ClientRequest.emit (events.js:211:7)
                              at TLSSocket.socketErrorListener (_http_client.js:401:9)
                              at TLSSocket.emit (events.js:211:7)
                          In the past I don’t think I ever had a conflict between scheduler and nest status.
                            sdetweil @rts58
                            @rts58 cool… I just pushed a change to my repo for this error…
                            if using my repo version, git pull to get the updated node_helper.js
                            R D 2 Replies Last reply Reply Quote 0
                              rts58 @sdetweil
                              @sdetweil just got the update, I’ll let you know what I find. Thanks!
                                dazza120 @sdetweil
                                @sdetweil updated! 👍🏾
                                  rts58
                                  It’s been 24 hours and still working fine! Thanks!
                                    costascontis
                                    is the issue solved?How?
                                      sdetweil @costascontis
                                      @costascontis bug in the original repo, use mine
                                      git clone https://github.com/sdetweil/mmm-nest-status
                                        costascontis @sdetweil
                                        @sdetweil thanx mate.I use your repo ,it works fine but after a day or so i get a "Nest API Error:[object Object]
                                          @costascontis i just added some code to display the contents of that error object,
                                          do a git pull in the module folder and restart the mirror app.
                                            @sdetweil so the error is
                                            Nest API Error:{"code":"ECONNRESET","path"null,"host":"firebase-apiserver38-tah01-iad01.dapi.production.nest.com","port":"9553"}
