    mmm-nest-status unresponsive after 12hours
    34 Posts 4 Posters 18.8k Views 4 Watching
      costascontis
      had the same problem with this module…had to restart my mm to keep it running so i gave up.Its a pity cause its so nice good looking module but after some hours it gets unresponsive …
        rts58
        I also have been having the same issue with this module. It worked well for months. I’ve just been restarting and haven’t had time to chase down the errors.
          i think this is an api redirect issue, which the current code doesn’t cover…
          please try my updated module
          rename your folder to some other name
          then
          git clone https://github.com/sdetweil/mmm-nest-status
          nothing else has changed
          there is an api call limit… roughly once per minute… doesn’t say if it ever recovers from reaching the limit
          looks like it might recover after 1 hour… SINCE THE LAST CALL… but the app keeps trying every 10 minutes
          but you should see this on the UI…
          ‘The Nest API rate limit has been exceeded.
          This module will try to load data again in 10 minutes.’;
            dazza120 @sdetweil
            @sdetweil said in mmm-nest-status unresponsive after 12hours:
            Yeah when I changed it to every 10seconds it showed the limit exceeded will try again in 10min so I think it does recover. But it’s never showed this when I put it to every 1min as per nest api. I’ll have a go with yours thanks very much mate.👍🏾
              sdetweil @dazza120
              @dazza120 cool. I think it should enforce 1 minute minimum…
                dazza120 @sdetweil
                @sdetweil seems to be working fine mate cheers 👍🏾
                  dazza120
                  @sdetweil its working a treat mate thanks
                    sdetweil @dazza120
                    @dazza120 mine works, but original does not?
                      dazza120 @sdetweil
                      @sdetweil no yours works well the original doesn’t
                        dazza120 @sdetweil
                        @sdetweil it looks like its playing up again i had couple of days with it working on the button now its back to giving up after 12hours :(
                          sdetweil @dazza120
                          @dazza120 ok. Can u look at the developers window console to see if any messages?
                            rts58
                            Bummer, mine has stopped as well.
                              rts58
                              I tried to open the console via remote but wasn’t able to. Sorry.
                                dazza120 @sdetweil
                                @sdetweil it’s literally just the seconds of the time I’m seeing which I might try to stop not seen any Nest process but I did restart it before this so that error has likely gone, as soon as it happens again I will dev console and check thank you
                                  rts58
                                  Based upon the display, it stopped on me last night. I was running mm serveronly so I could see the dev output in browser. I couldn’t find any errors. It could have stopped when scheduler is set to hide all modules. I did see this in the console after this mornings schedule to show modules:
                                  TypeError: Cannot read property 'statusCode' of undefined
                                      at Request._callback (/home/pi/MagicMirror/modules/mmm-nest-status/node_helper.js:20:25)
                                      at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
                                      at emitOne (events.js:116:13)
                                      at Request.emit (events.js:211:7)
                                      at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:881:8)
                                      at ClientRequest.emit (events.js:211:7)
                                      at TLSSocket.socketErrorListener (_http_client.js:401:9)
                                      at TLSSocket.emit (events.js:211:7)
                                  In the past I don’t think I ever had a conflict between scheduler and nest status.
                                    sdetweil @rts58
                                    @rts58 cool… I just pushed a change to my repo for this error…
                                    if using my repo version, git pull to get the updated node_helper.js
                                    R D 2 Replies Last reply Reply Quote 0
                                      rts58 @sdetweil
                                      @sdetweil just got the update, I’ll let you know what I find. Thanks!
                                        dazza120 @sdetweil
                                        @sdetweil updated! 👍🏾
                                          rts58
                                          It’s been 24 hours and still working fine! Thanks!
                                            costascontis
                                            is the issue solved?How?
