    mmm-nest-status unresponsive after 12hours
    34 Posts 4 Posters 16.9k Views 4 Watching
      dazza120
      @michael5r after 12 or so hours the nest module fails to update the status of the thermostat instead just displaying what was it’s state at the time of going unresponsive have you had this issue/problem?
        sdetweil @dazza120
        @dazza120 are there any errors in the terminal window or developers window console?
        D 2 Replies Last reply Reply Quote 1
          dazza120 @sdetweil
          @sdetweil Unsure mate I’ve changed the update intervals so i’ll see how that works first, Ive never been able to get on that dev console with buster its just white when you get into it and says it needs to reload then does nothing
            dazza120 @sdetweil
            @sdetweil yeah it still freezes after a while, when the magic mirror is restarted or reloaded it works, so I’ve setup a cron job every 12hours to reload MagicMirror
              dazza120
              @sdetweil can you offer any help on how to track down the problem with this be unresponsive after awhile
                sdetweil @dazza120
                @dazza120 I need to.look at that code. I am away til tomorrow.
                I have been fighting a similar crash
                on one of my mirrors… Which seem to be error related. They didn’t run for 6 hours, now w no changes, been running for 5 days!
                  dazza120 @sdetweil
                  @sdetweil cheers mate I’ll wait till your all good
                    costascontis
                    had the same problem with this module…had to restart my mm to keep it running so i gave up.Its a pity cause its so nice good looking module but after some hours it gets unresponsive …
                      rts58
                      I also have been having the same issue with this module. It worked well for months. I’ve just been restarting and haven’t had time to chase down the errors.
                        i think this is an api redirect issue, which the current code doesn’t cover…
                        please try my updated module
                        rename your folder to some other name
                        then
                        git clone https://github.com/sdetweil/mmm-nest-status
                        nothing else has changed
                        there is an api call limit… roughly once per minute… doesn’t say if it ever recovers from reaching the limit
                        looks like it might recover after 1 hour… SINCE THE LAST CALL… but the app keeps trying every 10 minutes
                        but you should see this on the UI…
                        ‘The Nest API rate limit has been exceeded.
                        This module will try to load data again in 10 minutes.’;
                          dazza120 @sdetweil
                          @sdetweil said in mmm-nest-status unresponsive after 12hours:
                          Yeah when I changed it to every 10seconds it showed the limit exceeded will try again in 10min so I think it does recover. But it’s never showed this when I put it to every 1min as per nest api. I’ll have a go with yours thanks very much mate.👍🏾
                            sdetweil @dazza120
                            @dazza120 cool. I think it should enforce 1 minute minimum…
                              dazza120 @sdetweil
                              @sdetweil seems to be working fine mate cheers 👍🏾
                                dazza120
                                @sdetweil its working a treat mate thanks
                                  sdetweil @dazza120
                                  @dazza120 mine works, but original does not?
                                    dazza120 @sdetweil
                                    @sdetweil no yours works well the original doesn’t
                                      dazza120 @sdetweil
                                      @sdetweil it looks like its playing up again i had couple of days with it working on the button now its back to giving up after 12hours :(
                                        sdetweil @dazza120
                                        @dazza120 ok. Can u look at the developers window console to see if any messages?
                                          rts58
                                          Bummer, mine has stopped as well.
                                            rts58
                                            I tried to open the console via remote but wasn’t able to. Sorry.
