    mmm-nest-status unresponsive after 12hours
    34 Posts 4 Posters 18.8k Views 4 Watching
      dazza120
      @sdetweil can you offer any help on how to track down the problem with this be unresponsive after awhile
        sdetweil @dazza120
        @dazza120 I need to.look at that code. I am away til tomorrow.
        I have been fighting a similar crash
        on one of my mirrors… Which seem to be error related. They didn’t run for 6 hours, now w no changes, been running for 5 days!
          dazza120 @sdetweil
          @sdetweil cheers mate I’ll wait till your all good
            costascontis
            had the same problem with this module…had to restart my mm to keep it running so i gave up.Its a pity cause its so nice good looking module but after some hours it gets unresponsive …
              rts58
              I also have been having the same issue with this module. It worked well for months. I’ve just been restarting and haven’t had time to chase down the errors.
                i think this is an api redirect issue, which the current code doesn’t cover…
                please try my updated module
                rename your folder to some other name
                then
                git clone https://github.com/sdetweil/mmm-nest-status
                nothing else has changed
                there is an api call limit… roughly once per minute… doesn’t say if it ever recovers from reaching the limit
                looks like it might recover after 1 hour… SINCE THE LAST CALL… but the app keeps trying every 10 minutes
                but you should see this on the UI…
                ‘The Nest API rate limit has been exceeded.
                This module will try to load data again in 10 minutes.’;
                  dazza120 @sdetweil
                  @sdetweil said in mmm-nest-status unresponsive after 12hours:
                  Yeah when I changed it to every 10seconds it showed the limit exceeded will try again in 10min so I think it does recover. But it’s never showed this when I put it to every 1min as per nest api. I’ll have a go with yours thanks very much mate.👍🏾
                    sdetweil @dazza120
                    @dazza120 cool. I think it should enforce 1 minute minimum…
                      dazza120 @sdetweil
                      @sdetweil seems to be working fine mate cheers 👍🏾
                        dazza120
                        @sdetweil its working a treat mate thanks
                          sdetweil @dazza120
                          @dazza120 mine works, but original does not?
                            dazza120 @sdetweil
                            @sdetweil no yours works well the original doesn’t
                              dazza120 @sdetweil
                              @sdetweil it looks like its playing up again i had couple of days with it working on the button now its back to giving up after 12hours :(
                                sdetweil @dazza120
                                @dazza120 ok. Can u look at the developers window console to see if any messages?
                                  rts58
                                  Bummer, mine has stopped as well.
                                    rts58
                                    I tried to open the console via remote but wasn’t able to. Sorry.
                                      dazza120 @sdetweil
                                      @sdetweil it’s literally just the seconds of the time I’m seeing which I might try to stop not seen any Nest process but I did restart it before this so that error has likely gone, as soon as it happens again I will dev console and check thank you
                                        rts58
                                        Based upon the display, it stopped on me last night. I was running mm serveronly so I could see the dev output in browser. I couldn’t find any errors. It could have stopped when scheduler is set to hide all modules. I did see this in the console after this mornings schedule to show modules:
                                        TypeError: Cannot read property 'statusCode' of undefined
                                            at Request._callback (/home/pi/MagicMirror/modules/mmm-nest-status/node_helper.js:20:25)
                                            at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
                                            at emitOne (events.js:116:13)
                                            at Request.emit (events.js:211:7)
                                            at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:881:8)
                                            at ClientRequest.emit (events.js:211:7)
                                            at TLSSocket.socketErrorListener (_http_client.js:401:9)
                                            at TLSSocket.emit (events.js:211:7)
                                        In the past I don’t think I ever had a conflict between scheduler and nest status.
                                          sdetweil @rts58
                                          @rts58 cool… I just pushed a change to my repo for this error…
                                          if using my repo version, git pull to get the updated node_helper.js
                                          R D 2 Replies Last reply Reply Quote 0
                                            rts58 @sdetweil
                                            @sdetweil just got the update, I’ll let you know what I find. Thanks!
