config.js help
18 Posts 5 Posters 4.1k Views 5 Watching
  • S Away
    sdetweil @DaVinki
    @DaVinki just for testting, can u move the module block to the top of the list in config.js?
    the modules are placed in order of appearance in the config file…
    mine is date/time, calendar, then MMM-MyDutchWeather
    trying to get a pic uploaded…
    With Weather
      DaVinki
      Just had a look at it, but I can’t find anything weird:
      I Have never done it before, so I think I can do it.
      S 1 Reply Last reply Jul 23, 2019, 3:06 PM Reply Quote 0
      • S Away
        sdetweil @DaVinki
        @DaVinki that is the elements tab, select the console tab please
        D 1 Reply Last reply Jul 23, 2019, 3:11 PM Reply Quote 0
          DaVinki @sdetweil
          @sdetweil And there we have it. Just wondering. the server it is referring to, is that local server, or the server from which data is pulled from?
          S 1 Reply Last reply Jul 23, 2019, 3:22 PM Reply Quote 0
          • S Away
            sdetweil @DaVinki
            @DaVinki
            server is the local system… the mirror is a web page, trying to load the javascript from a ‘server’ (local)
            the name is MMM-MyDutchWeather, you have it coded somewhere as
            MMM-**My_**MyDutchWeather (1st error)
            can you
            from the MagicMirror/modules folder do
            ls
            and show the results here
            D 1 Reply Last reply Jul 23, 2019, 4:46 PM Reply Quote 0
              DaVinki @sdetweil
              @sdetweil Solved.
              Did you know that the git command to download from git repositories is also case sensitive? :face_with_tears_of_joy:
              S 1 Reply Last reply Jul 23, 2019, 4:49 PM Reply Quote 0
              • S Away
                sdetweil @DaVinki
                @DaVinki yes… that is why you push the button and copy the url to your cut/paste cache
                glad u got it solved!
                  drone001
                  you forgot the comma after (position: “top_left”)
                  2 / 2
