    Raspberry Pi Memory Loss
    17 Posts 3 Posters 6.3k Views 3 Watching
      dazza120 @evroom
      @evroom restarted the hole thing so memory is good. i have no idea what this other thing is that you and @jsteel715 are talking about lol but here is what you asked for with the code. this is normal operation apart from chromium that is shutdown everytime im not using it
      pi@raspberrypi:~ $ free
                    total        used        free      shared  buff/cache   available
      Mem:        3999788      509844     2834580      197580      655364     3197620
      Swap:        102396           0      102396
      pi@raspberrypi:~ $ swapon -s
      Filename				Type		Size	Used	Priority
      /var/swap                              	file    	102396	0	-2
      pi@raspberrypi:~ $ vmstat 5 10
      procs -----------memory---------- ---swap-- -----io---- -system-- ------cpu-----
       r  b   swpd   free   buff  cache   si   so    bi    bo   in   cs us sy id wa st
       1  0      0 2833448  45296 610956    0    0   867    25  513  852 17  8 69  5  0
       1  0      0 2830796  45304 613168    0    0     0     6  552  626  2  1 97  0  0
       0  0      0 2835100  45312 609128    0    0     0    37  537  615  2  1 97  0  0
       0  0      0 2836716  45320 609156    0    0     0    10  433  483  3  1 96  0  0
       0  0      0 2836220  45320 609132    0    0     0     0  383  410  1  1 98  0  0
       0  0      0 2833132  45328 609768    0    0     0    23  308  329  2  1 96  0  0
       0  0      0 2833684  45328 609136    0    0     0    32  502  528  1  1 98  0  0
       0  0      0 2839432  45328 602188    0    0     1     2 1054 1883  6  4 90  0  0
       0  0      0 2830820  45336 609832    0    0     9    13 1684 2816 18  6 76  0  0
       3  0      0 2825096  45344 615684    0    0     0    11 1597 2651 19  5 76  0  0
      pi@raspberrypi:~ $ top -b -o +%MEM | head -n 22
      top - 19:50:21 up 6 min,  2 users,  load average: 1.35, 0.78, 0.38
      Tasks: 159 total,   1 running, 157 sleeping,   0 stopped,   1 zombie
      %Cpu(s):  7.7 us,  3.8 sy,  0.0 ni, 88.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3906.0 total,   2774.0 free,    502.4 used,    629.6 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3131.1 avail Mem
        PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
       1452 pi        20   0  411492 145144  95428 S   0.0   3.6   0:37.40 chromium-+
        815 pi        20   0  537468 141332  82408 S  10.5   3.5   0:26.66 electron
        905 pi        20   0  356568 114216  62964 S   0.0   2.9   0:13.56 electron
       1155 pi        20   0  473740  99856  80016 S   0.0   2.5   0:11.76 chromium-+
       1484 pi        20   0  336364  74940  56704 S   0.0   1.9   0:02.31 chromium-+
       1201 pi        20   0  318296  74660  56632 S   0.0   1.9   0:18.70 chromium-+
        900 pi        20   0  301448  66488  48860 S   0.0   1.7   0:04.48 electron
        494 root      20   0  151824  52472  37340 S   0.0   1.3   0:38.00 Xorg
       1206 pi        20   0  266728  50416  38620 S   0.0   1.3   0:01.99 chromium-+
        539 pi        20   0  136068  44144  25440 S   0.0   1.1   0:01.74 PM2 v3.5.+
       1535 pi        20   0  286880  39344  31156 S   0.0   1.0   0:00.09 chromium-+
        728 pi        20   0  128372  37932  25488 S   0.0   0.9   0:00.98 npm
       1176 pi        20   0  198328  34484  28812 S   0.0   0.9   0:00.17 chromium-+
        451 root      20   0   58952  33852  17416 S  10.5   0.8   0:28.86 vncserver+
        634 pi        20   0  149252  28832  22788 S   0.0   0.7   0:01.44 lxpanel
      pi@raspberrypi:~ $
      • evroomE Offline
        evroom
        Could you repeat this when memory usage has increased substantially?
        The chromium processes are taking up quite some memory.
        I myself have none running.
        Did you get the latest packages?
        $ sudo apt-get update
        $ sudo apt-get dist-upgrade
        MagicMirror version: 2.33.0
        Test environment:
        MagicMirror version: v2.31.0
          dazza120 @evroom
          @evroom said in Raspberry Pi Memory Loss:
          ok so ive done the apt-get update before so not much but dam the apt-get dist-upgrade took about 10mins or so. I just turned off the chromium run in the background even when it is closed and the use accelerated hardware.
            dazza120
            @evroom this is how the mirror runs normally no other processes than this.
            Mem:        3999788      376340     3175032      110328      448416     3418840
             0  0      0 3176112  44568 402592    0    0   789    17  431  701 11  7 76  6  0
            0  0      0 3175952  44568 403184    0    0     0     2  263  276  1  1 97  0  0
             0  0      0 3174436  44568 403332    0    0     0     1  255  239  2  1 97  0  0
             0  0      0 3174572  44576 402708    0    0     0     3  289  291  1  2 97  0  0
             0  0      0 3174476  44576 402708    0    0     0     0  333  338  1  2 97  0  0
             0  0      0 3175072  44576 402708    0    0     0     0  237  236  2  1 97  0  0
             0  0      0 3173972  44576 402708    0    0     0     0  303  307  2  2 97  0  0
             1  0      0 3172272  44576 403184    0    0     1     0  342  374  2  2 97  0  0
             1  0      0 3172448  44584 404204    0    0     0     3  293  288  4  2 94  0  0
             0  0      0 3172144  44584 404196    0    0     0     2  274  259  1  2 97  0  0
            top - 21:30:36 up 2 min,  2 users,  load average: 0.27, 0.25, 0.10
            Tasks: 162 total,   1 running, 160 sleeping,   0 stopped,   1 zombie
            %Cpu(s):  4.4 us,  1.5 sy,  0.0 ni, 94.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   3906.0 total,   3097.4 free,    370.0 used,    438.7 buff/cache
            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3336.5 avail Mem
              814 pi        20   0  537468 140148  82128 S   0.0   3.5   0:17.93 electron
              904 pi        20   0  356056 111640  62768 S   0.0   2.8   0:12.55 electron
              899 pi        20   0  303116  67132  49136 S   0.0   1.7   0:06.92 electron
              493 root      20   0  151288  51768  37196 S   6.2   1.3   0:05.34 Xorg
              537 pi        20   0  136076  43848  25392 S   0.0   1.1   0:01.72 PM2 v3.5.+
              702 pi        20   0  127868  37380  25404 S   0.0   0.9   0:00.99 npm
              439 root      20   0   78344  34092  17460 S   6.2   0.9   0:06.21 vncserver+
              807 pi        20   0   86380  28656  23016 S   0.0   0.7   0:00.19 node
              610 pi        20   0  157416  28516  22584 S   0.0   0.7   0:01.23 lxpanel
             1153 pi        20   0   85700  28048  22108 S   0.0   0.7   0:00.76 lxterminal
              816 pi        20   0  139544  25756  19504 S   0.0   0.6   0:00.10 electron
              611 pi        20   0   83220  21764  17288 S   0.0   0.5   0:00.79 pcmanfm
              605 pi        20   0   62252  14620  12332 S   0.0   0.4   0:00.30 openbox
              677 pi        20   0   31400  14188  12644 S   0.0   0.4   0:00.11 vncserver+
              664 pi        20   0   31772  12832  10560 S   0.0   0.3   0:00.42 vncserver+
            pi@raspberrypi:~ $
              dazza120
              @evroom this is it at 60% just running the mirror
              Mem:        3999788     1191448     1723096      363156     1085244     2410100
               0  0      0 1724372  83516 1000540    0    0     1     2   37   10  8  4 88  0  0
               0  0      0 1722544  83516 1000824    0    0     0     0  357  423  1  1 98  0  0
               0  0      0 1722348  83516 1000652    0    0     0     5  226  217  1  1 98  0  0
               0  0      0 1723448  83516 999932    0    0     0     0  261  277  1  1 97  0  0
               0  0      0 1723164  83516 1000676    0    0     0     0  247  249  1  1 98  0  0
               4  0      0 1725856  83520 1000652    0    0     0     2  443  310 56  1 43  0  0
               0  0      0 1736892  83520 1000652    0    0     0     0  419  319 39  2 59  0  0
               0  0      0 1735444  83520 1002136    0    0     0     0  245  260  1  1 97  0  0
               0  0      0 1735384  83520 1002136    0    0     0     0  296  356  1  2 97  0  0
               0  0      0 1735408  83520 1002136    0    0     0     1  270  283  1  1 98  0  0
              top - 04:48:48 up 1 day,  7:21,  2 users,  load average: 0.69, 0.75, 0.70
              Tasks: 151 total,   1 running, 149 sleeping,   0 stopped,   1 zombie
              %Cpu(s): 18.9 us,  8.1 sy,  0.0 ni, 73.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   3906.0 total,   1694.7 free,   1151.2 used,   1060.1 buff/cache
              MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2365.6 avail Mem
                904 pi        20   0 1382888   1.1g 313184 S  38.9  28.4 330:15.93 electron
                814 pi        20   0  790640 152908  83008 S   0.0   3.8 247:27.16 electron
                899 pi        20   0  309132  69832  49136 S   0.0   1.7 223:14.37 electron
                493 root      20   0  152020  52524  37268 S  16.7   1.3  54:27.50 Xorg
                537 pi        20   0  138800  43548  25412 S   0.0   1.1   0:13.47 PM2 v3.5.+
                439 root      20   0   80140  36180  17492 S  11.1   0.9   0:53.80 vncserver+
                610 pi        20   0  157644  28832  22600 S   0.0   0.7   0:51.52 lxpanel
               4608 pi        20   0   85108  27664  21924 S   0.0   0.7   0:00.62 lxterminal
                611 pi        20   0   83220  21764  17288 S   0.0   0.5   0:00.91 pcmanfm
                677 pi        20   0   31400  14836  13292 S   0.0   0.4   0:00.25 vncserver+
                605 pi        20   0   62488  14620  12332 S   0.0   0.4   0:00.51 openbox
                664 pi        20   0   31772  12832  10560 S   0.0   0.3   0:01.06 vncserver+
              pi@raspberrypi:~ $
              • evroomE Offline
                evroom
                So it is an electron process, hence MM process, alright.
                Now find a way how to determine which module is causing this.
                Which modules do you have active?
                Test environment:
                • evroomE Offline
                  evroom
                  Can you do following ?
                  Please do not post output that is very long.
                  Just want to get a feeling if these commands lead to anything, hence the MMM module eating memory
                  $ top -b -o +%MEM | head -n 8
                  $ strace -T -o /tmp/strace.out -p PID_from_top_command
                  After about 15 seconds, use control-c to stop strace.
                  For example:
                  $ strace -T -o /tmp/strace.out -p 904
                  $ grep 'name_of_MMM_module' /tmp/strace.out
                  For example:
                  $ grep 'mmm-systemtemperature' /tmp/strace.out
                  $ grep 'name_of_MMM_module' /tmp/strace.out | wc -l
                  For example:
                  $ grep 'mmm-systemtemperature' /tmp/strace.out | wc -l
                  Test environment:
