    After 2.8 I'm having tons of issues. What are the steps from square 1 to get this working?
    46 Posts 3 Posters 22.7k Views 3 Watching
      maxheartrate
      I am having the exact same problem: Black screen after 2.8 update. I followed all the suggestions you two came up with but my screen remains black.
      This is what I get after npm start:
      Starting MagicMirror: v2.8.0
      Loading config ...
      Loading module helpers ...
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node_helper'
      App threw an error during load
          at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
          at Function.Module._load (internal/modules/cjs/loader.js:528:25)
          at Module.require (internal/modules/cjs/loader.js:658:17)
          at require (internal/modules/cjs/helpers.js:20:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:6:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:94:3)
          at Module._compile (internal/modules/cjs/loader.js:711:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
          at Module.load (internal/modules/cjs/loader.js:620:32)
      { Error: Cannot find module 'node_helper'
          at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
      Launching application.
      ^Cpi@raspberrypi:~/MagicMirror $
      pi@raspberrypi:~/MagicMirror $ npm stop
      npm ERR! missing script: stop
      npm ERR!     /home/pi/.npm/_logs/2019-08-08T12_50_44_769Z-debug.log
      pi@raspberrypi:~/MagicMirror $ pm2 stop mm
      [PM2] Applying action stopProcessId on app [mm](ids: 0)
      [PM2] [mm](0) ✓
      │ Name        │ id │ mode │ status  │ ↺ │ cpu │ memory │
      │ MagicMirror │ 1  │ fork │ stopped │ 0 │ 0%  │ 0 B    │
      │ mm          │ 0  │ fork │ stopped │ 1 │ 0%  │ 0 B    │
       Use `pm2 show <id|name>` to get more details about an app
      pi@raspberrypi:~/MagicMirror $ pm2 list
      pi@raspberrypi:~/MagicMirror $  pm2 start MagicMirror
      [PM2] Applying action restartProcessId on app [MagicMirror](ids: 1)
      [PM2] [MagicMirror](1) ✓
      [PM2] Process successfully started
      │ MagicMirror │ 1  │ fork │ online  │ 0 │ 0%  │ 2.5 MB   │
      > magicmirror@2.8.0 start /home/pi/MagicMirror
      > sh run-start.sh
      Loading config ...
      I also get the black screen when I start with ‘pm2 MagicMirror’ which was created by @sdetweil script and starting with my original command ‘pm2 start mm’.
      Looks really screwed up and since I have to admit that I am a noob I am lost.
      Any suggestions? Best, Max
        sdetweil
        weird…
        node_helper is a special module provided by MM and part of the install package
        can u do
         ls ~/MagicMirror/node_modules/node_helper/
        it should display 1 file, index.js
        did u remove the node_modules folder?
        ps. I did that once, and had the same problem!
        try this
        cd ~/MagicMirror
        git checkout -- node_modules/node_helper/index.js
        then try restarting MagicMirror
          maxheartrate @sdetweil
          Hi, thank you for your advise.
          shows me
          ls: Zugriff auf ‘/home/pi/MagicMirror/node_modules/node_helper/’ nicht möglich: Datei oder Verzeichnis nicht gefunden
          File or folder not found
          results in
          error: pathspec ‘node_modules/node_helper/index.js’ did not match any file(s) known to git.
            sdetweil @maxheartrate
            @maxheartrate ok. I am away from my system now for a couple days.
            Try
            git checkout -- node_helper/index.js
            If that fails, try
            git status
            Then rename your MagicMirror folder to something else, clone it again, and copy the node_modules/node_helper folder to your previous installation, and rename the new one, then the old one back
              maxheartrate
              Your two suggestions did not work. That is why I followed step 3: cloning MM again and copying node_helper to node_modules.
              I ran npm install in node_modules and in the MagicMirror directory.
              Now it looks like I got one error further … :flushed_face:
              This is what I get now:
              > sh run-start.sh
              Loading config ...
              WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '../../../js/class.js'
                  at Object.<anonymous> (/home/pi/MagicMirror/node_modules/node_helper/index.js:8:13)
                  at Object.<anonymous> (/home/pi/MagicMirror/node_modules/node_helper/index.js:127:3)
              { Error: Cannot find module '../../../js/class.js'
                @maxheartrate no. No npm install in the node_modules folder. That messes everything up.
                Do
                cd ~/MagicMirror
                rm -rf node_modules
                cp -R -p ???/node_modules ~/MagicMirror
                Where ??? Is your recently cloned download.
                Then in the MagicMirror folder do
                npm install
                IF u had other modules installed, beyond the initial set, then look thru their folders and see if there is a package.json file present. If so, in each such module folder do a
                npm install
                there
                I made a new script to do all this upgrade stuff, but I don’t know what will happen if the git pull is already done.
                See my upgrade topic in the troubleshooting section
                  maxheartrate
                  Hi @sdetweil, thanks for joining in and for your advise.
                  I followed your steps just as described. The node_helper was the only module in the newly cloned node_modules folder. I then ran npm install and an npm install in every modules folder with a package.json file.
                  After that I ran into the missing node_helper error again. Obviously the folder was deleted when I ran the npm install in the MagicMirror folder. Now I copied the node_helper folder from the newly cloned version again and I am back at the error I sent in my previous post. :dizzy_face:
                    @maxheartrate
                    No it won’t be deleted.
                    Let’s start from scratch. U have the extra downloaded copy. Make THAT NAME MagicMirror, and npm install in that folder.
                    Start mm and we should be running.
                    Then we will copy over your extra modules, and config file
                    And work from there
                      maxheartrate
                      Alright. Now I have something else but a black screen for the first time in days:
                      “Magic Mirror - please create a config file”
                      What do you suggest now?
                        sdetweil
                        @maxheartrate
                        And work from there
                        • 4 / 5
