    After 2.8 I'm having tons of issues. What are the steps from square 1 to get this working?
    46 Posts 3 Posters 22.1k Views 3 Watching
      sdetweil @Gomalley
      @Gomalley only
      cd ~/MagicMirror
      npm install
      • G Offline
        Gomalley @sdetweil
        pi@raspberrypi:~/MagicMirror $ npm install
        > magicmirror@2.8.0 install /home/pi/MagicMirror
        > cd vendor && npm install
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        audited 220 packages in 21.352s
        found 5 vulnerabilities (4 low, 1 high)
          run `npm audit fix` to fix them, or `npm audit` for details
        > magicmirror@2.8.0 postinstall /home/pi/MagicMirror
        > sh installers/postinstall/postinstall.sh && npm run install-fonts
        MagicMirror installation successful!
        > magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
        > cd fonts && npm install
        audited 1 package in 1.151s
        found 0 vulnerabilities
        audited 3592 packages in 97.711s
        Looks good. What should I do next?, Try to start the mirror?
          sdetweil @Gomalley
          @Gomalley yes, start it up
          • G Offline
            Gomalley @sdetweil
            @sdetweil I was able to start up he mirror by doing
            cd ~ /MagicMirror
            npm start
            The mirror started up like usual but it didn’t restart after I exited out of it.
              sdetweil @Gomalley
              @Gomalley ok, now try
              pm2 list
              If something is there, try
              pm2 start ???
              Where name is whatever was shown
              If nothing, use my new script, see link in troubleshooting section
              G 2 Replies Last reply Reply Quote 0
              • G Offline
                Gomalley @sdetweil
                pm2 list
                gave me error messages so I ran the updated script and keeps coming up with an error for shelljs
                pi@raspberrypi:~ $ pm2 list
                [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                internal/modules/cjs/loader.js:583
                    throw err;
                Error: Cannot find module 'shelljs'
                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
                    at Function.Module._load (internal/modules/cjs/loader.js:507:25)
                    at Module.require (internal/modules/cjs/loader.js:637:17)
                    at require (/usr/local/lib/node_modules/pm2/node_modules/v8-compile-cache/v8-compile-cache.js:161:20)
                    at module.exports.Client.launchDaemon (/usr/local/lib/node_modules/pm2/lib/Client.js:244:7)
                    at /usr/local/lib/node_modules/pm2/lib/Client.js:103:10
                    at /usr/local/lib/node_modules/pm2/lib/Client.js:311:14
                    at process._tickCallback (internal/process/next_tick.js:61:11)
                pi@raspberrypi:~ $ bash -c  "$(curl -sL  https://www.dropbox.com/s/cy2z7lbkpifcbrk/fixuppm2.sh?dl=0)"
                bash: line 26: 1: command not found
                    throw err;
                    throw err;
                    at detectInitSystem (/usr/local/lib/node_modules/pm2/lib/API/Startup.js:50:11)
                    at API.CLI.startup (/usr/local/lib/node_modules/pm2/lib/API/Startup.js:186:27)
                    at Command.<anonymous> (/usr/local/lib/node_modules/pm2/bin/pm2:705:9)
                    at Command.listener (/usr/local/lib/node_modules/pm2/node_modules/commander/index.js:315:8)
                    at Command.emit (events.js:189:13)
                    at Command.parseArgs (/usr/local/lib/node_modules/pm2/node_modules/commander/index.js:651:12)
                    throw err;
                    throw err;
                pi@raspberrypi:~ $
                I’ve run into this “cannot find shelljs” error before
                • G Offline
                  Gomalley @sdetweil
                  Is it possibly the version of raspbian that is messing this up because it use to work before they released the latest version of raspbian and before MM 2.8 as well.
                    sdetweil @Gomalley
                    @Gomalley pm2 needs to be reinstalled, cause the npm version changed.
                    lets try my new pm2 fixup script…
                    I’ve added your problems to the list it handles
                    • G Offline
                      Gomalley @sdetweil
                      Thank you! The mirror now autostarts!
                      So all this time I was doing it on a Lexar micro sd card. It actually froze on the startup page so I threw in a 16gb Ultra sandisk amd started the process all over.
                      Heres the steps that I followed:
                      pm2 logs
                      npm i -g npm
                      cd ~
                      sudo chown -R pi .
                      pm2 logs
                      npm i -g npm
                      sudo npm i -g npm
                      cd ~/MagicMirror
                      npm install
                      pm2 list
                      Thank you again for your help!
                        sdetweil @Gomalley
                        @Gomalley glad that it’s working.
                        My new installer might have avoided all the rework after git clone
                        • 3 / 5
