    After 2.8 I'm having tons of issues. What are the steps from square 1 to get this working?
    46 Posts 3 Posters 25.6k Views 3 Watching
      sdetweil @maxheartrate
      @maxheartrate ok. I am away from my system now for a couple days.
      Try
      git checkout -- node_helper/index.js
      If that fails, try
      git status
      Then rename your MagicMirror folder to something else, clone it again, and copy the node_modules/node_helper folder to your previous installation, and rename the new one, then the old one back
        maxheartrate
        Your two suggestions did not work. That is why I followed step 3: cloning MM again and copying node_helper to node_modules.
        I ran npm install in node_modules and in the MagicMirror directory.
        Now it looks like I got one error further … :flushed_face:
        This is what I get now:
        > sh run-start.sh
        Starting MagicMirror: v2.8.0
        Loading config ...
        Loading module helpers ...
        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '../../../js/class.js'
        App threw an error during load
            at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
            at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
            at Function.Module._load (internal/modules/cjs/loader.js:528:25)
            at Module.require (internal/modules/cjs/loader.js:658:17)
            at require (internal/modules/cjs/helpers.js:20:18)
            at Object.<anonymous> (/home/pi/MagicMirror/node_modules/node_helper/index.js:8:13)
            at Object.<anonymous> (/home/pi/MagicMirror/node_modules/node_helper/index.js:127:3)
            at Module._compile (internal/modules/cjs/loader.js:711:30)
            at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
            at Module.load (internal/modules/cjs/loader.js:620:32)
        { Error: Cannot find module '../../../js/class.js'
            at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
        Launching application.
          @maxheartrate no. No npm install in the node_modules folder. That messes everything up.
          Do
          rm -rf node_modules
          cp -R -p ???/node_modules ~/MagicMirror
          Where ??? Is your recently cloned download.
          Then in the MagicMirror folder do
          npm install
          IF u had other modules installed, beyond the initial set, then look thru their folders and see if there is a package.json file present. If so, in each such module folder do a
          npm install
          there
          I made a new script to do all this upgrade stuff, but I don’t know what will happen if the git pull is already done.
          See my upgrade topic in the troubleshooting section
            maxheartrate
            Hi @sdetweil, thanks for joining in and for your advise.
            I followed your steps just as described. The node_helper was the only module in the newly cloned node_modules folder. I then ran npm install and an npm install in every modules folder with a package.json file.
            After that I ran into the missing node_helper error again. Obviously the folder was deleted when I ran the npm install in the MagicMirror folder. Now I copied the node_helper folder from the newly cloned version again and I am back at the error I sent in my previous post. :dizzy_face:
              @maxheartrate
              No it won’t be deleted.
              Let’s start from scratch. U have the extra downloaded copy. Make THAT NAME MagicMirror, and npm install in that folder.
              Start mm and we should be running.
              Then we will copy over your extra modules, and config file
              And work from there
                maxheartrate
                Alright. Now I have something else but a black screen for the first time in days:
                “Magic Mirror - please create a config file”
                What do you suggest now?
                  @maxheartrate
                  And work from there
                    maxheartrate @sdetweil
                    That’s what I did. I have a fresh MagicMirror now. It is running but can’t find the config file (I haven’t copied config.js.sample to config.js yet).
                      @maxheartrate you have to do that, copy the config
                        @maxheartrate I really want you to run my updated install script…if I can only find the topic with the link!
                        See the second post here
                        https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
                          maxheartrate
                          I am now using my original config.js and I am copying the modules one by one, then restarting Magic Mirror and checking if it still works.
                          I have got some stuff back up and running now. Thank so much up to this point.
                            maxheartrate
                            I just did a reboot to see if MagicMirror survives it. :winking_face:
                            Since I ran your @sdetweil script in my time of desparation, pm2 now autostarts two instances of MagicMirror. One is MagicMirror and one my original mm.
                            Where do I edit this again? I forgot how I managed to do the autostart in the first place … sorry.
                              @maxheartrate just do
                              pm2 stop mm
                              pm2 delete mm
                              • 3 / 3
