    After 2.8 I'm having tons of issues. What are the steps from square 1 to get this working?
    46 Posts 3 Posters 26.9k Views 3 Watching
      maxheartrate
      Hi @sdetweil, thanks for joining in and for your advise.
      I followed your steps just as described. The node_helper was the only module in the newly cloned node_modules folder. I then ran npm install and an npm install in every modules folder with a package.json file.
      After that I ran into the missing node_helper error again. Obviously the folder was deleted when I ran the npm install in the MagicMirror folder. Now I copied the node_helper folder from the newly cloned version again and I am back at the error I sent in my previous post. :dizzy_face:
        sdetweil @maxheartrate
        @maxheartrate
        No it won’t be deleted.
        Let’s start from scratch. U have the extra downloaded copy. Make THAT NAME MagicMirror, and npm install in that folder.
        Start mm and we should be running.
        Then we will copy over your extra modules, and config file
        And work from there
          maxheartrate
          Alright. Now I have something else but a black screen for the first time in days:
          “Magic Mirror - please create a config file”
          What do you suggest now?
            @maxheartrate
            And work from there
            M 1 Reply Last reply
              maxheartrate @sdetweil
              That’s what I did. I have a fresh MagicMirror now. It is running but can’t find the config file (I haven’t copied config.js.sample to config.js yet).
              S 2 Replies Last reply
                @maxheartrate you have to do that, copy the config
                  @maxheartrate I really want you to run my updated install script…if I can only find the topic with the link!
                  See the second post here
                  https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
                    maxheartrate
                    I am now using my original config.js and I am copying the modules one by one, then restarting Magic Mirror and checking if it still works.
                    I have got some stuff back up and running now. Thank so much up to this point.
                      maxheartrate
                      I just did a reboot to see if MagicMirror survives it. :winking_face:
                      Since I ran your @sdetweil script in my time of desparation, pm2 now autostarts two instances of MagicMirror. One is MagicMirror and one my original mm.
                      Where do I edit this again? I forgot how I managed to do the autostart in the first place … sorry.
                        @maxheartrate just do
                        pm2 stop mm
                        pm2 delete mm
                        • 3 / 3
