    After 2.8 I'm having tons of issues. What are the steps from square 1 to get this working?
    46 Posts 3 Posters 25.6k Views 3 Watching
    • G Offline
      Gomalley @sdetweil
      Thank you! The mirror now autostarts!
      So all this time I was doing it on a Lexar micro sd card. It actually froze on the startup page so I threw in a 16gb Ultra sandisk amd started the process all over.
      Heres the steps that I followed:
      pm2 logs
      npm i -g npm
      cd ~
      sudo chown -R pi .
      pm2 logs
      npm i -g npm
      sudo npm i -g npm
      npm install
      pm2 list
      bash -c "$(curl -sL  https://www.dropbox.com/s/cy2z7lbkpifcbrk/fixuppm2.sh?dl=0)"
      Thank you again for your help!
        sdetweil @Gomalley
        @Gomalley glad that it’s working.
        My new installer might have avoided all the rework after git clone
          maxheartrate
          I am having the exact same problem: Black screen after 2.8 update. I followed all the suggestions you two came up with but my screen remains black.
          This is what I get after npm start:
          Starting MagicMirror: v2.8.0
          Loading config ...
          Loading module helpers ...
          WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node_helper'
          App threw an error during load
              at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
              at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
              at Function.Module._load (internal/modules/cjs/loader.js:528:25)
              at Module.require (internal/modules/cjs/loader.js:658:17)
              at require (internal/modules/cjs/helpers.js:20:18)
              at Object.<anonymous> (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:6:18)
              at Object.<anonymous> (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:94:3)
              at Module._compile (internal/modules/cjs/loader.js:711:30)
              at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
              at Module.load (internal/modules/cjs/loader.js:620:32)
          { Error: Cannot find module 'node_helper'
              at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
          Launching application.
          ^Cpi@raspberrypi:~/MagicMirror $
          pi@raspberrypi:~/MagicMirror $ npm stop
          npm ERR! missing script: stop
          npm ERR!     /home/pi/.npm/_logs/2019-08-08T12_50_44_769Z-debug.log
          pi@raspberrypi:~/MagicMirror $ pm2 stop mm
          [PM2] Applying action stopProcessId on app [mm](ids: 0)
          [PM2] [mm](0) ✓
          │ Name        │ id │ mode │ status  │ ↺ │ cpu │ memory │
          │ MagicMirror │ 1  │ fork │ stopped │ 0 │ 0%  │ 0 B    │
          │ mm          │ 0  │ fork │ stopped │ 1 │ 0%  │ 0 B    │
           Use `pm2 show <id|name>` to get more details about an app
          pi@raspberrypi:~/MagicMirror $ pm2 list
          pi@raspberrypi:~/MagicMirror $  pm2 start MagicMirror
          [PM2] Applying action restartProcessId on app [MagicMirror](ids: 1)
          [PM2] [MagicMirror](1) ✓
          [PM2] Process successfully started
          │ MagicMirror │ 1  │ fork │ online  │ 0 │ 0%  │ 2.5 MB   │
          > magicmirror@2.8.0 start /home/pi/MagicMirror
          > sh run-start.sh
          Loading config ...
          I also get the black screen when I start with ‘pm2 MagicMirror’ which was created by @sdetweil script and starting with my original command ‘pm2 start mm’.
          Looks really screwed up and since I have to admit that I am a noob I am lost.
          Any suggestions? Best, Max
            weird…
            node_helper is a special module provided by MM and part of the install package
            can u do
             ls ~/MagicMirror/node_modules/node_helper/
            it should display 1 file, index.js
            did u remove the node_modules folder?
            ps. I did that once, and had the same problem!
            try this
            git checkout -- node_modules/node_helper/index.js
            then try restarting MagicMirror
              maxheartrate @sdetweil
              Hi, thank you for your advise.
              shows me
              ls: Zugriff auf ‘/home/pi/MagicMirror/node_modules/node_helper/’ nicht möglich: Datei oder Verzeichnis nicht gefunden
              File or folder not found
              results in
              error: pathspec ‘node_modules/node_helper/index.js’ did not match any file(s) known to git.
                sdetweil @maxheartrate
                @maxheartrate ok. I am away from my system now for a couple days.
                Try
                git checkout -- node_helper/index.js
                If that fails, try
                git status
                Then rename your MagicMirror folder to something else, clone it again, and copy the node_modules/node_helper folder to your previous installation, and rename the new one, then the old one back
                  maxheartrate
                  Your two suggestions did not work. That is why I followed step 3: cloning MM again and copying node_helper to node_modules.
                  I ran npm install in node_modules and in the MagicMirror directory.
                  Now it looks like I got one error further … :flushed_face:
                  This is what I get now:
                  > sh run-start.sh
                  Loading config ...
                  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '../../../js/class.js'
                      at Object.<anonymous> (/home/pi/MagicMirror/node_modules/node_helper/index.js:8:13)
                      at Object.<anonymous> (/home/pi/MagicMirror/node_modules/node_helper/index.js:127:3)
                  { Error: Cannot find module '../../../js/class.js'
                    @maxheartrate no. No npm install in the node_modules folder. That messes everything up.
                    Do
                    rm -rf node_modules
                    cp -R -p ???/node_modules ~/MagicMirror
                    Where ??? Is your recently cloned download.
                    Then in the MagicMirror folder do
                    npm install
                    IF u had other modules installed, beyond the initial set, then look thru their folders and see if there is a package.json file present. If so, in each such module folder do a
                    npm install
                    there
                    I made a new script to do all this upgrade stuff, but I don’t know what will happen if the git pull is already done.
                    See my upgrade topic in the troubleshooting section
                      maxheartrate
                      Hi @sdetweil, thanks for joining in and for your advise.
                      I followed your steps just as described. The node_helper was the only module in the newly cloned node_modules folder. I then ran npm install and an npm install in every modules folder with a package.json file.
                      After that I ran into the missing node_helper error again. Obviously the folder was deleted when I ran the npm install in the MagicMirror folder. Now I copied the node_helper folder from the newly cloned version again and I am back at the error I sent in my previous post. :dizzy_face:
                        @maxheartrate
                        No it won’t be deleted.
                        Let’s start from scratch. U have the extra downloaded copy. Make THAT NAME MagicMirror, and npm install in that folder.
                        Start mm and we should be running.
                        Then we will copy over your extra modules, and config file
                        And work from there
                          maxheartrate
                          Alright. Now I have something else but a black screen for the first time in days:
                          “Magic Mirror - please create a config file”
                          What do you suggest now?
                            @maxheartrate
                            And work from there
                              That’s what I did. I have a fresh MagicMirror now. It is running but can’t find the config file (I haven’t copied config.js.sample to config.js yet).
                                @maxheartrate you have to do that, copy the config
                                  @maxheartrate I really want you to run my updated install script…if I can only find the topic with the link!
                                  See the second post here
                                  https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
                                    maxheartrate
                                    I am now using my original config.js and I am copying the modules one by one, then restarting Magic Mirror and checking if it still works.
                                    I have got some stuff back up and running now. Thank so much up to this point.
                                      maxheartrate
                                      I just did a reboot to see if MagicMirror survives it. :winking_face:
                                      Since I ran your @sdetweil script in my time of desparation, pm2 now autostarts two instances of MagicMirror. One is MagicMirror and one my original mm.
                                      Where do I edit this again? I forgot how I managed to do the autostart in the first place … sorry.
                                        @maxheartrate just do
                                        pm2 stop mm
                                        pm2 delete mm
                                        • 2 / 3
