    After 2.8 I'm having tons of issues. What are the steps from square 1 to get this working?
    46 Posts 3 Posters 26.9k Views 3 Watching
      sdetweil @Gomalley
      @Gomalley go old sudo screws thing up again…
      cd ~
      sudo chown -R pi .
      Then try again…
      G 1 Reply Last reply
      • G
        Gomalley @sdetweil
        @sdetweil this is what happened when I typed in the command
        pi@raspberrypi:~ $ sudo chown -R pi
        chown: missing operand after ‘pi’
        Try ‘chown --help’ for more information.
          sdetweil @Gomalley
          @Gomalley there was a dot at the end, it was important
          • G
            Gomalley @sdetweil
            Sorry, I missed that.
            This is what happened
            pi@raspberrypi:~ $ cd ~
            pi@raspberrypi:~ $ sudo chown -R pi .
            pi@raspberrypi:~ $
            It just went to the next line. Not sure why
              sdetweil @Gomalley
              @Gomalley it doesn’t say anything, it just changes ownership of everything in the home folder and down to the user pi.
              Now, back to what u were doing before
              • G
                Gomalley @sdetweil
                I tried to excute some of the commands you gave me
                pi@raspberrypi:~ $ pm2 logs
                [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                internal/modules/cjs/loader.js:583
                    throw err;
                Error: Cannot find module 'shelljs'
                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
                    at Function.Module._load (internal/modules/cjs/loader.js:507:25)
                    at Module.require (internal/modules/cjs/loader.js:637:17)
                    at require (/usr/local/lib/node_modules/pm2/node_modules/v8-compile-cache/v8-compile-cache.js:161:20)
                    at module.exports.Client.launchDaemon (/usr/local/lib/node_modules/pm2/lib/Client.js:244:7)
                    at /usr/local/lib/node_modules/pm2/lib/Client.js:103:10
                    at /usr/local/lib/node_modules/pm2/lib/Client.js:311:14
                    at process._tickCallback (internal/process/next_tick.js:61:11)
                pi@raspberrypi:~ $ npm i -g npm
                npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules/npm
                npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules/npm/node_modules
                npm ERR! path /usr/local/lib/node_modules/npm
                npm ERR! code EACCES
                npm ERR! errno -13
                npm ERR! syscall access
                npm ERR! Error: EACCES: permission denied, access '/usr/local/lib/node_modules/npm'
                npm ERR!  { [Error: EACCES: permission denied, access '/usr/local/lib/node_modules/npm']
                npm ERR!   stack:
                npm ERR!    'Error: EACCES: permission denied, access \'/usr/local/lib/node_modules/npm\'',
                npm ERR!   errno: -13,
                npm ERR!   code: 'EACCES',
                npm ERR!   syscall: 'access',
                npm ERR!   path: '/usr/local/lib/node_modules/npm' }
                npm ERR!
                npm ERR! The operation was rejected by your operating system.
                npm ERR! It is likely you do not have the permissions to access this file as the current user
                npm ERR!
                npm ERR! If you believe this might be a permissions issue, please double-check the
                npm ERR! permissions of the file and its containing directories, or try running
                npm ERR! the command again as root/Administrator (though this is not recommended).
                npm ERR!     /home/pi/.npm/_logs/2019-08-06T18_59_40_902Z-debug.log
                pi@raspberrypi:~ $
                I ran “pm2 logs” and “npm i -g npm”
                Looks like I got similar results. Should I do
                npm install
                In the MagicMirror folder now?
                  sdetweil @Gomalley
                  @Gomalley no. Looks like u installed npm w sudo(root)
                  So, short term do
                  sudo npm i -g npm
                  • G
                    Gomalley @sdetweil
                    @sdetweil Sweet I think that worked
                    pi@raspberrypi:~ $ sudo npm i -g npm
                    /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                    /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                    + npm@6.10.3
                    updated 3 packages in 128.39s
                    pi@raspberrypi:~ $
                    Now that I have done that, Should I run
                    npm install
                    and then:
                    npm install
                      sdetweil @Gomalley
                      @Gomalley only
                      npm install
                      • G
                        Gomalley @sdetweil
                        pi@raspberrypi:~/MagicMirror $ npm install
                        > magicmirror@2.8.0 install /home/pi/MagicMirror
                        > cd vendor && npm install
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                        audited 220 packages in 21.352s
                        found 5 vulnerabilities (4 low, 1 high)
                          run `npm audit fix` to fix them, or `npm audit` for details
                        > magicmirror@2.8.0 postinstall /home/pi/MagicMirror
                        > sh installers/postinstall/postinstall.sh && npm run install-fonts
                        MagicMirror installation successful!
                        > magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
                        > cd fonts && npm install
                        audited 1 package in 1.151s
                        found 0 vulnerabilities
                        audited 3592 packages in 97.711s
                        Looks good. What should I do next?, Try to start the mirror?
                          sdetweil @Gomalley
                          @Gomalley yes, start it up
                          • G
                            Gomalley @sdetweil
                            @sdetweil I was able to start up he mirror by doing
                            cd ~ /MagicMirror
                            npm start
                            The mirror started up like usual but it didn’t restart after I exited out of it.
                              sdetweil @Gomalley
                              @Gomalley ok, now try
                              pm2 list
                              If something is there, try
                              pm2 start ???
                              Where name is whatever was shown
                              If nothing, use my new script, see link in troubleshooting section
                              G 2 Replies Last reply
                              • G
                                Gomalley @sdetweil
                                pm2 list
                                gave me error messages so I ran the updated script and keeps coming up with an error for shelljs
                                pi@raspberrypi:~ $ pm2 list
                                    throw err;
                                pi@raspberrypi:~ $ bash -c  "$(curl -sL  https://www.dropbox.com/s/cy2z7lbkpifcbrk/fixuppm2.sh?dl=0)"
                                bash: line 26: 1: command not found
                                    throw err;
                                    throw err;
                                    at detectInitSystem (/usr/local/lib/node_modules/pm2/lib/API/Startup.js:50:11)
                                    at API.CLI.startup (/usr/local/lib/node_modules/pm2/lib/API/Startup.js:186:27)
                                    at Command.<anonymous> (/usr/local/lib/node_modules/pm2/bin/pm2:705:9)
                                    at Command.listener (/usr/local/lib/node_modules/pm2/node_modules/commander/index.js:315:8)
                                    at Command.emit (events.js:189:13)
                                    at Command.parseArgs (/usr/local/lib/node_modules/pm2/node_modules/commander/index.js:651:12)
                                    throw err;
                                    throw err;
                                pi@raspberrypi:~ $
                                I’ve run into this “cannot find shelljs” error before
                                • G
                                  Gomalley @sdetweil
                                  Is it possibly the version of raspbian that is messing this up because it use to work before they released the latest version of raspbian and before MM 2.8 as well.
                                    sdetweil @Gomalley
                                    @Gomalley pm2 needs to be reinstalled, cause the npm version changed.
                                    lets try my new pm2 fixup script…
                                    I’ve added your problems to the list it handles
                                    • G
                                      Gomalley @sdetweil
                                      Thank you! The mirror now autostarts!
                                      So all this time I was doing it on a Lexar micro sd card. It actually froze on the startup page so I threw in a 16gb Ultra sandisk amd started the process all over.
                                      Heres the steps that I followed:
                                      pm2 logs
                                      npm i -g npm
                                      cd ~
                                      sudo chown -R pi .
                                      pm2 logs
                                      npm i -g npm
                                      sudo npm i -g npm
                                      npm install
                                      pm2 list
                                      Thank you again for your help!
                                        sdetweil @Gomalley
                                        @Gomalley glad that it’s working.
                                        My new installer might have avoided all the rework after git clone
                                          maxheartrate
                                          I am having the exact same problem: Black screen after 2.8 update. I followed all the suggestions you two came up with but my screen remains black.
                                          This is what I get after npm start:
                                          Starting MagicMirror: v2.8.0
                                          Loading config ...
                                          Loading module helpers ...
                                          WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node_helper'
                                          App threw an error during load
                                              at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
                                              at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                                              at Function.Module._load (internal/modules/cjs/loader.js:528:25)
                                              at Module.require (internal/modules/cjs/loader.js:658:17)
                                              at require (internal/modules/cjs/helpers.js:20:18)
                                              at Object.<anonymous> (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:6:18)
                                              at Object.<anonymous> (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:94:3)
                                              at Module._compile (internal/modules/cjs/loader.js:711:30)
                                              at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                                              at Module.load (internal/modules/cjs/loader.js:620:32)
                                          { Error: Cannot find module 'node_helper'
                                              at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
                                          Launching application.
                                          ^Cpi@raspberrypi:~/MagicMirror $
                                          pi@raspberrypi:~/MagicMirror $ npm stop
                                          npm ERR! missing script: stop
                                          npm ERR!     /home/pi/.npm/_logs/2019-08-08T12_50_44_769Z-debug.log
                                          pi@raspberrypi:~/MagicMirror $ pm2 stop mm
                                          [PM2] Applying action stopProcessId on app [mm](ids: 0)
                                          [PM2] [mm](0) ✓
                                          │ Name        │ id │ mode │ status  │ ↺ │ cpu │ memory │
                                          │ MagicMirror │ 1  │ fork │ stopped │ 0 │ 0%  │ 0 B    │
                                          │ mm          │ 0  │ fork │ stopped │ 1 │ 0%  │ 0 B    │
                                           Use `pm2 show <id|name>` to get more details about an app
                                          pi@raspberrypi:~/MagicMirror $ pm2 list
                                          pi@raspberrypi:~/MagicMirror $  pm2 start MagicMirror
                                          [PM2] Applying action restartProcessId on app [MagicMirror](ids: 1)
                                          [PM2] [MagicMirror](1) ✓
                                          [PM2] Process successfully started
                                          │ MagicMirror │ 1  │ fork │ online  │ 0 │ 0%  │ 2.5 MB   │
                                          > magicmirror@2.8.0 start /home/pi/MagicMirror
                                          > sh run-start.sh
                                          Loading config ...
                                          I also get the black screen when I start with ‘pm2 MagicMirror’ which was created by @sdetweil script and starting with my original command ‘pm2 start mm’.
                                          Looks really screwed up and since I have to admit that I am a noob I am lost.
                                          Any suggestions? Best, Max
                                            weird…
                                            node_helper is a special module provided by MM and part of the install package
                                            can u do
                                             ls ~/MagicMirror/node_modules/node_helper/
                                            it should display 1 file, index.js
                                            did u remove the node_modules folder?
                                            ps. I did that once, and had the same problem!
                                            try this
                                            git checkout -- node_modules/node_helper/index.js
                                            then try restarting MagicMirror
                                            M 1 Reply Last reply
                                            • 2 / 3
