    After 2.8 I'm having tons of issues. What are the steps from square 1 to get this working?
    46 Posts 3 Posters 26.5k Views 3 Watching
      sdetweil @Gomalley
      @Gomalley ok, wasnt clear u had just the base MagicMirror.
      If you do pm2 logs, what does it show?
      Also, what does npm -v show?
      U may need to upgrade npm
      npm i -g npm
      Then do the npm install again in the MagicMirror folder
      G 2 Replies Last reply Reply Quote 0
      • G
        Gomalley @sdetweil
        pi@raspberrypi:~ $ pm2 logs
        [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
        internal/modules/cjs/loader.js:583
        throw err;
        Error: Cannot find module ‘shelljs’
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
        at Function.Module._load (internal/modules/cjs/loader.js:507:25)
        at Module.require (internal/modules/cjs/loader.js:637:17)
        at require (/usr/local/lib/node_modules/pm2/node_modules/v8-compile-cache/v8-compile-cache.js:161:20)
        at module.exports.Client.launchDaemon (/usr/local/lib/node_modules/pm2/lib/Client.js:244:7)
        at /usr/local/lib/node_modules/pm2/lib/Client.js:103:10
        at /usr/local/lib/node_modules/pm2/lib/Client.js:311:14
        at process._tickCallback (internal/process/next_tick.js:61:11)
        pi@raspberrypi:~ $ npm -v
        6.10.2
        pi@raspberrypi:~ $
        This is what happened when I did pm2 logs and npm -v. I am about to see what npm i -g npm will do
        • G
          Gomalley @sdetweil
          pi@raspberrypi:~ $ npm i -g npm
          npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules/npm
          npm ERR! path /usr/local/lib/node_modules/npm
          npm ERR! code EACCES
          npm ERR! errno -13
          npm ERR! syscall access
          npm ERR! Error: EACCES: permission denied, access ‘/usr/local/lib/node_modules/npm’
          npm ERR! { [Error: EACCES: permission denied, access ‘/usr/local/lib/node_modules/npm’]
          npm ERR! stack:
          npm ERR! ‘Error: EACCES: permission denied, access '/usr/local/lib/node_modules/npm'’,
          npm ERR! errno: -13,
          npm ERR! code: ‘EACCES’,
          npm ERR! syscall: ‘access’,
          npm ERR! path: ‘/usr/local/lib/node_modules/npm’ }
          npm ERR!
          npm ERR! The operation was rejected by your operating system.
          npm ERR! It is likely you do not have the permissions to access this file as the current user
          npm ERR!
          npm ERR! If you believe this might be a permissions issue, please double-check the
          npm ERR! permissions of the file and its containing directories, or try running
          npm ERR! the command again as root/Administrator (though this is not recommended).
          npm ERR! /home/pi/.npm/_logs/2019-08-05T19_21_26_414Z-debug.log
            sdetweil @Gomalley
            @Gomalley go old sudo screws thing up again…
            cd ~
            sudo chown -R pi .
            Then try again…
            • G
              Gomalley @sdetweil
              @sdetweil this is what happened when I typed in the command
              pi@raspberrypi:~ $ sudo chown -R pi
              chown: missing operand after ‘pi’
              Try ‘chown --help’ for more information.
                sdetweil @Gomalley
                @Gomalley there was a dot at the end, it was important
                • G
                  Gomalley @sdetweil
                  Sorry, I missed that.
                  pi@raspberrypi:~ $ cd ~
                  pi@raspberrypi:~ $ sudo chown -R pi .
                  pi@raspberrypi:~ $
                  It just went to the next line. Not sure why
                    sdetweil @Gomalley
                    @Gomalley it doesn’t say anything, it just changes ownership of everything in the home folder and down to the user pi.
                    Now, back to what u were doing before
                    • G
                      Gomalley @sdetweil
                      I tried to excute some of the commands you gave me
                          throw err;
                      Error: Cannot find module 'shelljs'
                      npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules/npm/node_modules
                      npm ERR! errno -13
                      npm ERR! Error: EACCES: permission denied, access '/usr/local/lib/node_modules/npm'
                      npm ERR!  { [Error: EACCES: permission denied, access '/usr/local/lib/node_modules/npm']
                      npm ERR!   stack:
                      npm ERR!    'Error: EACCES: permission denied, access \'/usr/local/lib/node_modules/npm\'',
                      npm ERR!   code: 'EACCES',
                      npm ERR!   syscall: 'access',
                      npm ERR!   path: '/usr/local/lib/node_modules/npm' }
                      npm ERR!
                      npm ERR!
                      npm ERR!     /home/pi/.npm/_logs/2019-08-06T18_59_40_902Z-debug.log
                      pi@raspberrypi:~ $
                      I ran “pm2 logs” and “npm i -g npm”
                      Looks like I got similar results. Should I do
                      npm install
                      In the MagicMirror folder now?
                        sdetweil @Gomalley
                        @Gomalley no. Looks like u installed npm w sudo(root)
                        So, short term do
                        sudo npm i -g npm
                        • G
                          Gomalley @sdetweil
                          @sdetweil Sweet I think that worked
                          pi@raspberrypi:~ $ sudo npm i -g npm
                          /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                          /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                          + npm@6.10.3
                          updated 3 packages in 128.39s
                          pi@raspberrypi:~ $
                          Now that I have done that, Should I run
                          npm install
                          and then:
                          npm install
                            sdetweil @Gomalley
                            @Gomalley only
                            npm install
                            • G
                              Gomalley @sdetweil
                              pi@raspberrypi:~/MagicMirror $ npm install
                              > magicmirror@2.8.0 install /home/pi/MagicMirror
                              > cd vendor && npm install
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                              audited 220 packages in 21.352s
                              found 5 vulnerabilities (4 low, 1 high)
                                run `npm audit fix` to fix them, or `npm audit` for details
                              > magicmirror@2.8.0 postinstall /home/pi/MagicMirror
                              > sh installers/postinstall/postinstall.sh && npm run install-fonts
                              MagicMirror installation successful!
                              > magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
                              > cd fonts && npm install
                              audited 1 package in 1.151s
                              found 0 vulnerabilities
                              audited 3592 packages in 97.711s
                              Looks good. What should I do next?, Try to start the mirror?
                                sdetweil @Gomalley
                                @Gomalley yes, start it up
                                • G
                                  Gomalley @sdetweil
                                  @sdetweil I was able to start up he mirror by doing
                                  cd ~ /MagicMirror
                                  npm start
                                  The mirror started up like usual but it didn’t restart after I exited out of it.
                                    sdetweil @Gomalley
                                    @Gomalley ok, now try
                                    pm2 list
                                    If something is there, try
                                    pm2 start ???
                                    Where name is whatever was shown
                                    If nothing, use my new script, see link in troubleshooting section
                                    • G
                                      Gomalley @sdetweil
                                      pm2 list
                                      gave me error messages so I ran the updated script and keeps coming up with an error for shelljs
                                      pi@raspberrypi:~ $ pm2 list
                                          throw err;
                                      pi@raspberrypi:~ $ bash -c  "$(curl -sL  https://www.dropbox.com/s/cy2z7lbkpifcbrk/fixuppm2.sh?dl=0)"
                                      bash: line 26: 1: command not found
                                          throw err;
                                          throw err;
                                          at detectInitSystem (/usr/local/lib/node_modules/pm2/lib/API/Startup.js:50:11)
                                          at API.CLI.startup (/usr/local/lib/node_modules/pm2/lib/API/Startup.js:186:27)
                                          at Command.<anonymous> (/usr/local/lib/node_modules/pm2/bin/pm2:705:9)
                                          at Command.listener (/usr/local/lib/node_modules/pm2/node_modules/commander/index.js:315:8)
                                          at Command.emit (events.js:189:13)
                                          at Command.parseArgs (/usr/local/lib/node_modules/pm2/node_modules/commander/index.js:651:12)
                                          throw err;
                                          throw err;
                                      pi@raspberrypi:~ $
                                      I’ve run into this “cannot find shelljs” error before
                                      • G
                                        Gomalley @sdetweil
                                        Is it possibly the version of raspbian that is messing this up because it use to work before they released the latest version of raspbian and before MM 2.8 as well.
                                          sdetweil @Gomalley
                                          @Gomalley pm2 needs to be reinstalled, cause the npm version changed.
                                          lets try my new pm2 fixup script…
                                          I’ve added your problems to the list it handles
                                          • G
                                            Gomalley @sdetweil
                                            Thank you! The mirror now autostarts!
                                            So all this time I was doing it on a Lexar micro sd card. It actually froze on the startup page so I threw in a 16gb Ultra sandisk amd started the process all over.
                                            Heres the steps that I followed:
                                            pm2 logs
                                            npm i -g npm
                                            cd ~
                                            sudo chown -R pi .
                                            pm2 logs
                                            npm i -g npm
                                            sudo npm i -g npm
                                            npm install
                                            pm2 list
                                            Thank you again for your help!
