    After 2.8 I'm having tons of issues. What are the steps from square 1 to get this working?
    46 Posts 3 Posters 26.5k Views 3 Watching
    • G
      Gomalley @sdetweil
      @sdetweil I tried putting npm install into the modules and vendor folders but there weren’t that many json files in that directory.
        sdetweil @Gomalley
        @Gomalley no. In the modules/MMM-??? Folders for the modules u have installed in addition to the base MagicMirror
        • G
          Gomalley @sdetweil
          @sdetweil when i go to /home/pi/MagicMirror/modules
          these are the folders present: Default, node_modules, README.md
          If i further click into default i get a ton more (alert, calendar, clock, compliment s, currentweather, helloworld , newsfeed, …) Other than the magicmirror program, I have not installed anything else
            sdetweil @Gomalley
            @Gomalley ok, wasnt clear u had just the base MagicMirror.
            If you do pm2 logs, what does it show?
            Also, what does npm -v show?
            U may need to upgrade npm
            npm i -g npm
            Then do the npm install again in the MagicMirror folder
            G 2 Replies Last reply Reply Quote 0
            • G
              Gomalley @sdetweil
              pi@raspberrypi:~ $ pm2 logs
              [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
              internal/modules/cjs/loader.js:583
              throw err;
              Error: Cannot find module ‘shelljs’
              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
              at Function.Module._load (internal/modules/cjs/loader.js:507:25)
              at Module.require (internal/modules/cjs/loader.js:637:17)
              at require (/usr/local/lib/node_modules/pm2/node_modules/v8-compile-cache/v8-compile-cache.js:161:20)
              at module.exports.Client.launchDaemon (/usr/local/lib/node_modules/pm2/lib/Client.js:244:7)
              at /usr/local/lib/node_modules/pm2/lib/Client.js:103:10
              at /usr/local/lib/node_modules/pm2/lib/Client.js:311:14
              at process._tickCallback (internal/process/next_tick.js:61:11)
              pi@raspberrypi:~ $ npm -v
              6.10.2
              pi@raspberrypi:~ $
              This is what happened when I did pm2 logs and npm -v. I am about to see what npm i -g npm will do
              • G
                Gomalley @sdetweil
                pi@raspberrypi:~ $ npm i -g npm
                npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules/npm
                npm ERR! path /usr/local/lib/node_modules/npm
                npm ERR! code EACCES
                npm ERR! errno -13
                npm ERR! syscall access
                npm ERR! Error: EACCES: permission denied, access ‘/usr/local/lib/node_modules/npm’
                npm ERR! { [Error: EACCES: permission denied, access ‘/usr/local/lib/node_modules/npm’]
                npm ERR! stack:
                npm ERR! ‘Error: EACCES: permission denied, access '/usr/local/lib/node_modules/npm'’,
                npm ERR! errno: -13,
                npm ERR! code: ‘EACCES’,
                npm ERR! syscall: ‘access’,
                npm ERR! path: ‘/usr/local/lib/node_modules/npm’ }
                npm ERR!
                npm ERR! The operation was rejected by your operating system.
                npm ERR! It is likely you do not have the permissions to access this file as the current user
                npm ERR!
                npm ERR! If you believe this might be a permissions issue, please double-check the
                npm ERR! permissions of the file and its containing directories, or try running
                npm ERR! the command again as root/Administrator (though this is not recommended).
                npm ERR! /home/pi/.npm/_logs/2019-08-05T19_21_26_414Z-debug.log
                  sdetweil @Gomalley
                  @Gomalley go old sudo screws thing up again…
                  cd ~
                  sudo chown -R pi .
                  Then try again…
                  • G
                    Gomalley @sdetweil
                    @sdetweil this is what happened when I typed in the command
                    pi@raspberrypi:~ $ sudo chown -R pi
                    chown: missing operand after ‘pi’
                    Try ‘chown --help’ for more information.
                      sdetweil @Gomalley
                      @Gomalley there was a dot at the end, it was important
                      • G
                        Gomalley @sdetweil
                        Sorry, I missed that.
                        pi@raspberrypi:~ $ cd ~
                        pi@raspberrypi:~ $ sudo chown -R pi .
                        pi@raspberrypi:~ $
                        It just went to the next line. Not sure why
                          sdetweil @Gomalley
                          @Gomalley it doesn’t say anything, it just changes ownership of everything in the home folder and down to the user pi.
                          Now, back to what u were doing before
                          • G
                            Gomalley @sdetweil
                            I tried to excute some of the commands you gave me
                                throw err;
                            Error: Cannot find module 'shelljs'
                            npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules/npm/node_modules
                            npm ERR! errno -13
                            npm ERR! Error: EACCES: permission denied, access '/usr/local/lib/node_modules/npm'
                            npm ERR!  { [Error: EACCES: permission denied, access '/usr/local/lib/node_modules/npm']
                            npm ERR!   stack:
                            npm ERR!    'Error: EACCES: permission denied, access \'/usr/local/lib/node_modules/npm\'',
                            npm ERR!   code: 'EACCES',
                            npm ERR!   syscall: 'access',
                            npm ERR!   path: '/usr/local/lib/node_modules/npm' }
                            npm ERR!
                            npm ERR!
                            npm ERR!     /home/pi/.npm/_logs/2019-08-06T18_59_40_902Z-debug.log
                            pi@raspberrypi:~ $
                            I ran “pm2 logs” and “npm i -g npm”
                            Looks like I got similar results. Should I do
                            npm install
                            In the MagicMirror folder now?
                              sdetweil @Gomalley
                              @Gomalley no. Looks like u installed npm w sudo(root)
                              So, short term do
                              sudo npm i -g npm
                              • G
                                Gomalley @sdetweil
                                @sdetweil Sweet I think that worked
                                pi@raspberrypi:~ $ sudo npm i -g npm
                                /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                                /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                                + npm@6.10.3
                                updated 3 packages in 128.39s
                                pi@raspberrypi:~ $
                                Now that I have done that, Should I run
                                npm install
                                and then:
                                npm install
                                  sdetweil @Gomalley
                                  @Gomalley only
                                  npm install
                                  • G
                                    Gomalley @sdetweil
                                    pi@raspberrypi:~/MagicMirror $ npm install
                                    > magicmirror@2.8.0 install /home/pi/MagicMirror
                                    > cd vendor && npm install
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                    audited 220 packages in 21.352s
                                    found 5 vulnerabilities (4 low, 1 high)
                                      run `npm audit fix` to fix them, or `npm audit` for details
                                    > magicmirror@2.8.0 postinstall /home/pi/MagicMirror
                                    > sh installers/postinstall/postinstall.sh && npm run install-fonts
                                    MagicMirror installation successful!
                                    > magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
                                    > cd fonts && npm install
                                    audited 1 package in 1.151s
                                    found 0 vulnerabilities
                                    audited 3592 packages in 97.711s
                                    Looks good. What should I do next?, Try to start the mirror?
                                      sdetweil @Gomalley
                                      @Gomalley yes, start it up
                                      • G
                                        Gomalley @sdetweil
                                        @sdetweil I was able to start up he mirror by doing
                                        cd ~ /MagicMirror
                                        npm start
                                        The mirror started up like usual but it didn’t restart after I exited out of it.
                                          sdetweil @Gomalley
                                          @Gomalley ok, now try
                                          pm2 list
                                          If something is there, try
                                          pm2 start ???
                                          Where name is whatever was shown
                                          If nothing, use my new script, see link in troubleshooting section
                                          • G
                                            Gomalley @sdetweil
                                            pm2 list
                                            gave me error messages so I ran the updated script and keeps coming up with an error for shelljs
                                            pi@raspberrypi:~ $ pm2 list
                                                throw err;
                                            pi@raspberrypi:~ $ bash -c  "$(curl -sL  https://www.dropbox.com/s/cy2z7lbkpifcbrk/fixuppm2.sh?dl=0)"
                                            bash: line 26: 1: command not found
                                                throw err;
                                                throw err;
                                                at detectInitSystem (/usr/local/lib/node_modules/pm2/lib/API/Startup.js:50:11)
                                                at API.CLI.startup (/usr/local/lib/node_modules/pm2/lib/API/Startup.js:186:27)
                                                at Command.<anonymous> (/usr/local/lib/node_modules/pm2/bin/pm2:705:9)
                                                at Command.listener (/usr/local/lib/node_modules/pm2/node_modules/commander/index.js:315:8)
                                                at Command.emit (events.js:189:13)
                                                at Command.parseArgs (/usr/local/lib/node_modules/pm2/node_modules/commander/index.js:651:12)
                                                throw err;
                                                throw err;
                                            pi@raspberrypi:~ $
                                            I’ve run into this “cannot find shelljs” error before
