    After 2.8 I'm having tons of issues. What are the steps from square 1 to get this working?
    46 Posts 3 Posters 26.9k Views 3 Watching
      sdetweil @Gomalley
      @Gomalley case sensitive, must be
      npm install
      Look in the modules folder and each of those for a package.json file.
      And if u find one, then in that folder do
      npm install
      There
      You could also try my update script. I haven’t tried it over an attempted update
      See here
      https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
      G 1 Reply Last reply
      • G
        Gomalley @sdetweil
        So I deleted everything and I started over. On a new load of raspbian without doing the MM bash command, I typed
        npm install
        It gave me this:
        pi@raspberrypi:~ $ npm install
        npm WARN npm npm does not support Node.js v10.15.2
        npm WARN npm You should probably upgrade to a newer version of node as we
        npm WARN npm can't make any promises that npm will work with this version.
        npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
        npm WARN npm You can find the latest version at https://nodejs.org/
        npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
        npm notice created a lockfile as package-lock.json. You should commit this file.
        npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
        npm WARN pi No description
        npm WARN pi No repository field.
        npm WARN pi No README data
        npm WARN pi No license field.
        up to date in 1.599s
        After this I tried your new code and I got this:
        pi@raspberrypi:~ $ bash -c  "$(curl -sL https://www.dropbox.com/s/4qod39yi8ek0feu/upgrade-script?dl=0)"
        bash: line 24: cd: /home/pi/MagicMirror/installers: No such file or directory
        bash: line 26: cd: OLDPWD not set
        doing test run = true
        bash: line 61: /home/pi/MagicMirror/installers/dumpactivemodules.js: No such file or directory
        update log will be in /home/pi/upgrade.log
        bash: line 70: cd: /home/pi/MagicMirror: No such file or directory
        bash: line 72: cd: css: No such file or directory
        saving custom.css
        cp: cannot stat 'custom.css': No such file or directory
        bash: line 75: cd: OLDPWD not set
        fatal: not a git repository (or any of the parent directories): .git
        fetching latest revisions
        MagicMirror git pull failed
        bash: line 183: cd: css: No such file or directory
        restoring custom.css
        cp: cannot stat 'save_custom.css': No such file or directory
        rm: cannot remove 'save_custom.css': No such file or directory
        bash: line 188: cd: OLDPWD not set
        bash: line 210: cd: OLDPWD not set
        Should I try running the original bash command?:
        bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
          sdetweil @Gomalley
          @Gomalley you are missing some fundamentals.
          THIS is called install
          git clone ....  copies the code from github to your system
               at this point it will not run
               you need to change to the MagicMirror folder and execute npm install so that all the additional node
                  routines needed are loaded onto your system
          now, once you have installed
          there are updates every quarter…
          so, then in the MagicMirror folder you need to download the new code OVER the prior code
          so, you do
          git pull
          but we are in the same position as during install…
          routines we need may have changed, or we may have decided to use something different
          so, once again, to get all the updates for other code we use
          npm install
          BUT there is one more step…
          any modules YOU installed may have dependencies too
          SO, they (like MagicMirror) specify those dependencies in a package.json file
          so, we need to look thru ALL the non-default module folders looking for a package.json file
          if we find one, we need to run npm install in that modules folder too.
          repeat til all module folders with a package.json file
          now…
          the install script (raspberry.sh) does the
          git clone
          and
          npm install in tghe MagicMirror folder.
          my update script
          does all the update steps… (I just added a check for the MagicMirror folder being present)
          but you had to have done the install steps first…
          npm install by itself without download any MagicMirror code doesn’t do anything useful, as there is no package.json file in the uses home folder by default.
          • G
            Gomalley @sdetweil
            @sdetweil I tried putting npm install into the modules and vendor folders but there weren’t that many json files in that directory.
              sdetweil @Gomalley
              @Gomalley no. In the modules/MMM-??? Folders for the modules u have installed in addition to the base MagicMirror
              • G
                Gomalley @sdetweil
                @sdetweil when i go to /home/pi/MagicMirror/modules
                these are the folders present: Default, node_modules, README.md
                If i further click into default i get a ton more (alert, calendar, clock, compliment s, currentweather, helloworld , newsfeed, …) Other than the magicmirror program, I have not installed anything else
                  sdetweil @Gomalley
                  @Gomalley ok, wasnt clear u had just the base MagicMirror.
                  If you do pm2 logs, what does it show?
                  Also, what does npm -v show?
                  U may need to upgrade npm
                  npm i -g npm
                  Then do the npm install again in the MagicMirror folder
                  G 2 Replies Last reply
                  • G
                    Gomalley @sdetweil
                    pi@raspberrypi:~ $ pm2 logs
                    [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                    internal/modules/cjs/loader.js:583
                    throw err;
                    Error: Cannot find module ‘shelljs’
                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
                    at Function.Module._load (internal/modules/cjs/loader.js:507:25)
                    at Module.require (internal/modules/cjs/loader.js:637:17)
                    at require (/usr/local/lib/node_modules/pm2/node_modules/v8-compile-cache/v8-compile-cache.js:161:20)
                    at module.exports.Client.launchDaemon (/usr/local/lib/node_modules/pm2/lib/Client.js:244:7)
                    at /usr/local/lib/node_modules/pm2/lib/Client.js:103:10
                    at /usr/local/lib/node_modules/pm2/lib/Client.js:311:14
                    at process._tickCallback (internal/process/next_tick.js:61:11)
                    pi@raspberrypi:~ $ npm -v
                    6.10.2
                    pi@raspberrypi:~ $
                    This is what happened when I did pm2 logs and npm -v. I am about to see what npm i -g npm will do
                    • G
                      Gomalley @sdetweil
                      pi@raspberrypi:~ $ npm i -g npm
                      npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules/npm
                      npm ERR! path /usr/local/lib/node_modules/npm
                      npm ERR! code EACCES
                      npm ERR! errno -13
                      npm ERR! syscall access
                      npm ERR! Error: EACCES: permission denied, access ‘/usr/local/lib/node_modules/npm’
                      npm ERR! { [Error: EACCES: permission denied, access ‘/usr/local/lib/node_modules/npm’]
                      npm ERR! stack:
                      npm ERR! ‘Error: EACCES: permission denied, access '/usr/local/lib/node_modules/npm'’,
                      npm ERR! errno: -13,
                      npm ERR! code: ‘EACCES’,
                      npm ERR! syscall: ‘access’,
                      npm ERR! path: ‘/usr/local/lib/node_modules/npm’ }
                      npm ERR!
                      npm ERR! The operation was rejected by your operating system.
                      npm ERR! It is likely you do not have the permissions to access this file as the current user
                      npm ERR!
                      npm ERR! If you believe this might be a permissions issue, please double-check the
                      npm ERR! permissions of the file and its containing directories, or try running
                      npm ERR! the command again as root/Administrator (though this is not recommended).
                      npm ERR! /home/pi/.npm/_logs/2019-08-05T19_21_26_414Z-debug.log
                        sdetweil @Gomalley
                        @Gomalley go old sudo screws thing up again…
                        cd ~
                        sudo chown -R pi .
                        Then try again…
                        • G
                          Gomalley @sdetweil
                          @sdetweil this is what happened when I typed in the command
                          pi@raspberrypi:~ $ sudo chown -R pi
                          chown: missing operand after ‘pi’
                          Try ‘chown --help’ for more information.
                            sdetweil @Gomalley
                            @Gomalley there was a dot at the end, it was important
                            • G
                              Gomalley @sdetweil
                              Sorry, I missed that.
                              pi@raspberrypi:~ $ cd ~
                              pi@raspberrypi:~ $ sudo chown -R pi .
                              pi@raspberrypi:~ $
                              It just went to the next line. Not sure why
                                sdetweil @Gomalley
                                @Gomalley it doesn’t say anything, it just changes ownership of everything in the home folder and down to the user pi.
                                Now, back to what u were doing before
                                • G
                                  Gomalley @sdetweil
                                  I tried to excute some of the commands you gave me
                                      throw err;
                                  Error: Cannot find module 'shelljs'
                                  npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules/npm/node_modules
                                  npm ERR! errno -13
                                  npm ERR! Error: EACCES: permission denied, access '/usr/local/lib/node_modules/npm'
                                  npm ERR!  { [Error: EACCES: permission denied, access '/usr/local/lib/node_modules/npm']
                                  npm ERR!   stack:
                                  npm ERR!    'Error: EACCES: permission denied, access \'/usr/local/lib/node_modules/npm\'',
                                  npm ERR!   code: 'EACCES',
                                  npm ERR!   syscall: 'access',
                                  npm ERR!   path: '/usr/local/lib/node_modules/npm' }
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!     /home/pi/.npm/_logs/2019-08-06T18_59_40_902Z-debug.log
                                  pi@raspberrypi:~ $
                                  I ran “pm2 logs” and “npm i -g npm”
                                  Looks like I got similar results. Should I do
                                  npm install
                                  In the MagicMirror folder now?
                                    sdetweil @Gomalley
                                    @Gomalley no. Looks like u installed npm w sudo(root)
                                    So, short term do
                                    sudo npm i -g npm
                                    • G
                                      Gomalley @sdetweil
                                      @sdetweil Sweet I think that worked
                                      pi@raspberrypi:~ $ sudo npm i -g npm
                                      /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                                      /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                                      + npm@6.10.3
                                      updated 3 packages in 128.39s
                                      pi@raspberrypi:~ $
                                      Now that I have done that, Should I run
                                      npm install
                                      and then:
                                      npm install
                                        sdetweil @Gomalley
                                        @Gomalley only
                                        npm install
                                        • G
                                          Gomalley @sdetweil
                                          pi@raspberrypi:~/MagicMirror $ npm install
                                          > magicmirror@2.8.0 install /home/pi/MagicMirror
                                          > cd vendor && npm install
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                          audited 220 packages in 21.352s
                                          found 5 vulnerabilities (4 low, 1 high)
                                            run `npm audit fix` to fix them, or `npm audit` for details
                                          > magicmirror@2.8.0 postinstall /home/pi/MagicMirror
                                          > sh installers/postinstall/postinstall.sh && npm run install-fonts
                                          MagicMirror installation successful!
                                          > magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
                                          > cd fonts && npm install
                                          audited 1 package in 1.151s
                                          found 0 vulnerabilities
                                          audited 3592 packages in 97.711s
                                          Looks good. What should I do next?, Try to start the mirror?
                                            sdetweil @Gomalley
                                            @Gomalley yes, start it up
