    After 2.8 I'm having tons of issues. What are the steps from square 1 to get this working?
    46 Posts 3 Posters 25.6k Views 3 Watching
    • G Offline
      Gomalley
      So I am trying to download the MM software after the update on July 1st. It won’t work anymore. First dependencies didn’t install, then node wasn’t up to date. Please someone help. Help me fix this!!!
      After a whole bunch of trying things I ended up here
      pi@raspberrypi:~/MagicMirror $ pm2 status all
      │ Name │ id │ mode │ status  │ ↺  │ cpu │ memory │
      │ mm   │ 0  │ fork │ errored │ 30 │ 0%  │ 0 B    │
        sdetweil @Gomalley
        @Gomalley do
        pm2 logs
        More than likely u need to do
        npm install
        In the MagicMirror folder, and in each module folder that has a package.json file.
        • G Offline
          Gomalley @sdetweil
          @sdetweil aright. I’ll try that however I’ve done it before and no luck. How would I do it for the other modules and package.json files. All I know what to do is just to type the command
          Npm install
          But It doesn’t work
            sdetweil @Gomalley
            @Gomalley case sensitive, must be
            npm install
            Look in the modules folder and each of those for a package.json file.
            And if u find one, then in that folder do
            npm install
            There
            You could also try my update script. I haven’t tried it over an attempted update
            See here
            https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
            • G Offline
              Gomalley @sdetweil
              So I deleted everything and I started over. On a new load of raspbian without doing the MM bash command, I typed
              npm install
              It gave me this:
              pi@raspberrypi:~ $ npm install
              npm WARN npm npm does not support Node.js v10.15.2
              npm WARN npm You should probably upgrade to a newer version of node as we
              npm WARN npm can't make any promises that npm will work with this version.
              npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
              npm WARN npm You can find the latest version at https://nodejs.org/
              npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
              npm notice created a lockfile as package-lock.json. You should commit this file.
              npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
              npm WARN pi No description
              npm WARN pi No repository field.
              npm WARN pi No README data
              npm WARN pi No license field.
              up to date in 1.599s
              After this I tried your new code and I got this:
              pi@raspberrypi:~ $ bash -c  "$(curl -sL https://www.dropbox.com/s/4qod39yi8ek0feu/upgrade-script?dl=0)"
              bash: line 24: cd: /home/pi/MagicMirror/installers: No such file or directory
              bash: line 26: cd: OLDPWD not set
              doing test run = true
              bash: line 61: /home/pi/MagicMirror/installers/dumpactivemodules.js: No such file or directory
              update log will be in /home/pi/upgrade.log
              bash: line 70: cd: /home/pi/MagicMirror: No such file or directory
              bash: line 72: cd: css: No such file or directory
              saving custom.css
              cp: cannot stat 'custom.css': No such file or directory
              bash: line 75: cd: OLDPWD not set
              fatal: not a git repository (or any of the parent directories): .git
              fetching latest revisions
              MagicMirror git pull failed
              bash: line 183: cd: css: No such file or directory
              restoring custom.css
              cp: cannot stat 'save_custom.css': No such file or directory
              rm: cannot remove 'save_custom.css': No such file or directory
              bash: line 188: cd: OLDPWD not set
              bash: line 210: cd: OLDPWD not set
              Should I try running the original bash command?:
              bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
                sdetweil @Gomalley
                @Gomalley you are missing some fundamentals.
                THIS is called install
                git clone ....  copies the code from github to your system
                     at this point it will not run
                     you need to change to the MagicMirror folder and execute npm install so that all the additional node
                        routines needed are loaded onto your system
                now, once you have installed
                there are updates every quarter…
                so, then in the MagicMirror folder you need to download the new code OVER the prior code
                so, you do
                git pull
                but we are in the same position as during install…
                routines we need may have changed, or we may have decided to use something different
                so, once again, to get all the updates for other code we use
                npm install
                BUT there is one more step…
                any modules YOU installed may have dependencies too
                SO, they (like MagicMirror) specify those dependencies in a package.json file
                so, we need to look thru ALL the non-default module folders looking for a package.json file
                if we find one, we need to run npm install in that modules folder too.
                repeat til all module folders with a package.json file
                now…
                the install script (raspberry.sh) does the
                git clone
                and
                npm install in tghe MagicMirror folder.
                my update script
                does all the update steps… (I just added a check for the MagicMirror folder being present)
                but you had to have done the install steps first…
                npm install by itself without download any MagicMirror code doesn’t do anything useful, as there is no package.json file in the uses home folder by default.
                • G Offline
                  Gomalley @sdetweil
                  @sdetweil I tried putting npm install into the modules and vendor folders but there weren’t that many json files in that directory.
                    sdetweil @Gomalley
                    @Gomalley no. In the modules/MMM-??? Folders for the modules u have installed in addition to the base MagicMirror
                    • G Offline
                      Gomalley @sdetweil
                      @sdetweil when i go to /home/pi/MagicMirror/modules
                      these are the folders present: Default, node_modules, README.md
                      If i further click into default i get a ton more (alert, calendar, clock, compliment s, currentweather, helloworld , newsfeed, …) Other than the magicmirror program, I have not installed anything else
                        sdetweil @Gomalley
                        @Gomalley ok, wasnt clear u had just the base MagicMirror.
                        If you do pm2 logs, what does it show?
                        Also, what does npm -v show?
                        U may need to upgrade npm
                        npm i -g npm
                        Then do the npm install again in the MagicMirror folder
                        G 2 Replies Last reply Reply Quote 0
                        • G Offline
                          Gomalley @sdetweil
                          pi@raspberrypi:~ $ pm2 logs
                          [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                          internal/modules/cjs/loader.js:583
                          throw err;
                          Error: Cannot find module ‘shelljs’
                          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
                          at Function.Module._load (internal/modules/cjs/loader.js:507:25)
                          at Module.require (internal/modules/cjs/loader.js:637:17)
                          at require (/usr/local/lib/node_modules/pm2/node_modules/v8-compile-cache/v8-compile-cache.js:161:20)
                          at module.exports.Client.launchDaemon (/usr/local/lib/node_modules/pm2/lib/Client.js:244:7)
                          at /usr/local/lib/node_modules/pm2/lib/Client.js:103:10
                          at /usr/local/lib/node_modules/pm2/lib/Client.js:311:14
                          at process._tickCallback (internal/process/next_tick.js:61:11)
                          pi@raspberrypi:~ $ npm -v
                          6.10.2
                          pi@raspberrypi:~ $
                          This is what happened when I did pm2 logs and npm -v. I am about to see what npm i -g npm will do
                          • G Offline
                            Gomalley @sdetweil
                            pi@raspberrypi:~ $ npm i -g npm
                            npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules/npm
                            npm ERR! path /usr/local/lib/node_modules/npm
                            npm ERR! code EACCES
                            npm ERR! errno -13
                            npm ERR! syscall access
                            npm ERR! Error: EACCES: permission denied, access ‘/usr/local/lib/node_modules/npm’
                            npm ERR! { [Error: EACCES: permission denied, access ‘/usr/local/lib/node_modules/npm’]
                            npm ERR! stack:
                            npm ERR! ‘Error: EACCES: permission denied, access '/usr/local/lib/node_modules/npm'’,
                            npm ERR! errno: -13,
                            npm ERR! code: ‘EACCES’,
                            npm ERR! syscall: ‘access’,
                            npm ERR! path: ‘/usr/local/lib/node_modules/npm’ }
                            npm ERR!
                            npm ERR! The operation was rejected by your operating system.
                            npm ERR! It is likely you do not have the permissions to access this file as the current user
                            npm ERR!
                            npm ERR! If you believe this might be a permissions issue, please double-check the
                            npm ERR! permissions of the file and its containing directories, or try running
                            npm ERR! the command again as root/Administrator (though this is not recommended).
                            npm ERR! /home/pi/.npm/_logs/2019-08-05T19_21_26_414Z-debug.log
                              sdetweil @Gomalley
                              @Gomalley go old sudo screws thing up again…
                              cd ~
                              sudo chown -R pi .
                              Then try again…
                              • G Offline
                                Gomalley @sdetweil
                                @sdetweil this is what happened when I typed in the command
                                pi@raspberrypi:~ $ sudo chown -R pi
                                chown: missing operand after ‘pi’
                                Try ‘chown --help’ for more information.
                                  sdetweil @Gomalley
                                  @Gomalley there was a dot at the end, it was important
                                  • G Offline
                                    Gomalley @sdetweil
                                    Sorry, I missed that.
                                    pi@raspberrypi:~ $ cd ~
                                    pi@raspberrypi:~ $ sudo chown -R pi .
                                    pi@raspberrypi:~ $
                                    It just went to the next line. Not sure why
                                      sdetweil @Gomalley
                                      @Gomalley it doesn’t say anything, it just changes ownership of everything in the home folder and down to the user pi.
                                      Now, back to what u were doing before
                                      • G Offline
                                        Gomalley @sdetweil
                                        I tried to excute some of the commands you gave me
                                            throw err;
                                        Error: Cannot find module 'shelljs'
                                        npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules/npm/node_modules
                                        npm ERR! errno -13
                                        npm ERR! Error: EACCES: permission denied, access '/usr/local/lib/node_modules/npm'
                                        npm ERR!  { [Error: EACCES: permission denied, access '/usr/local/lib/node_modules/npm']
                                        npm ERR!   stack:
                                        npm ERR!    'Error: EACCES: permission denied, access \'/usr/local/lib/node_modules/npm\'',
                                        npm ERR!   code: 'EACCES',
                                        npm ERR!   syscall: 'access',
                                        npm ERR!   path: '/usr/local/lib/node_modules/npm' }
                                        npm ERR!
                                        npm ERR!
                                        npm ERR!     /home/pi/.npm/_logs/2019-08-06T18_59_40_902Z-debug.log
                                        pi@raspberrypi:~ $
                                        I ran “pm2 logs” and “npm i -g npm”
                                        Looks like I got similar results. Should I do
                                        npm install
                                        In the MagicMirror folder now?
                                          sdetweil @Gomalley
                                          @Gomalley no. Looks like u installed npm w sudo(root)
                                          So, short term do
                                          sudo npm i -g npm
                                          • G Offline
                                            Gomalley @sdetweil
                                            @sdetweil Sweet I think that worked
                                            pi@raspberrypi:~ $ sudo npm i -g npm
                                            /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                                            /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                                            + npm@6.10.3
                                            updated 3 packages in 128.39s
                                            pi@raspberrypi:~ $
                                            Now that I have done that, Should I run
                                            npm install
                                            and then:
                                            npm install
