    After 2.8 I'm having tons of issues. What are the steps from square 1 to get this working?
    46 Posts 3 Posters 26.5k Views 3 Watching
      sdetweil @Gomalley
      @Gomalley it doesn’t say anything, it just changes ownership of everything in the home folder and down to the user pi.
      Now, back to what u were doing before
      • G
        Gomalley @sdetweil
        I tried to excute some of the commands you gave me
        pi@raspberrypi:~ $ pm2 logs
        [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
        internal/modules/cjs/loader.js:583
            throw err;
        Error: Cannot find module 'shelljs'
            at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
            at Function.Module._load (internal/modules/cjs/loader.js:507:25)
            at Module.require (internal/modules/cjs/loader.js:637:17)
            at require (/usr/local/lib/node_modules/pm2/node_modules/v8-compile-cache/v8-compile-cache.js:161:20)
            at module.exports.Client.launchDaemon (/usr/local/lib/node_modules/pm2/lib/Client.js:244:7)
            at /usr/local/lib/node_modules/pm2/lib/Client.js:103:10
            at /usr/local/lib/node_modules/pm2/lib/Client.js:311:14
            at process._tickCallback (internal/process/next_tick.js:61:11)
        pi@raspberrypi:~ $ npm i -g npm
        npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules/npm
        npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules/npm/node_modules
        npm ERR! path /usr/local/lib/node_modules/npm
        npm ERR! code EACCES
        npm ERR! errno -13
        npm ERR! syscall access
        npm ERR! Error: EACCES: permission denied, access '/usr/local/lib/node_modules/npm'
        npm ERR!  { [Error: EACCES: permission denied, access '/usr/local/lib/node_modules/npm']
        npm ERR!   stack:
        npm ERR!    'Error: EACCES: permission denied, access \'/usr/local/lib/node_modules/npm\'',
        npm ERR!   errno: -13,
        npm ERR!   code: 'EACCES',
        npm ERR!   syscall: 'access',
        npm ERR!   path: '/usr/local/lib/node_modules/npm' }
        npm ERR!
        npm ERR! The operation was rejected by your operating system.
        npm ERR! It is likely you do not have the permissions to access this file as the current user
        npm ERR!
        npm ERR! If you believe this might be a permissions issue, please double-check the
        npm ERR! permissions of the file and its containing directories, or try running
        npm ERR! the command again as root/Administrator (though this is not recommended).
        npm ERR!     /home/pi/.npm/_logs/2019-08-06T18_59_40_902Z-debug.log
        pi@raspberrypi:~ $
        I ran “pm2 logs” and “npm i -g npm”
        Looks like I got similar results. Should I do
        npm install
        In the MagicMirror folder now?
          sdetweil @Gomalley
          @Gomalley no. Looks like u installed npm w sudo(root)
          So, short term do
          sudo npm i -g npm
          • G
            Gomalley @sdetweil
            @sdetweil Sweet I think that worked
            pi@raspberrypi:~ $ sudo npm i -g npm
            /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
            /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
            + npm@6.10.3
            updated 3 packages in 128.39s
            pi@raspberrypi:~ $
            Now that I have done that, Should I run
            npm install
            and then:
            npm install
              sdetweil @Gomalley
              @Gomalley only
              npm install
              • G
                Gomalley @sdetweil
                pi@raspberrypi:~/MagicMirror $ npm install
                > magicmirror@2.8.0 install /home/pi/MagicMirror
                > cd vendor && npm install
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                audited 220 packages in 21.352s
                found 5 vulnerabilities (4 low, 1 high)
                  run `npm audit fix` to fix them, or `npm audit` for details
                > magicmirror@2.8.0 postinstall /home/pi/MagicMirror
                > sh installers/postinstall/postinstall.sh && npm run install-fonts
                MagicMirror installation successful!
                > magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
                > cd fonts && npm install
                audited 1 package in 1.151s
                found 0 vulnerabilities
                audited 3592 packages in 97.711s
                Looks good. What should I do next?, Try to start the mirror?
                  sdetweil @Gomalley
                  @Gomalley yes, start it up
                  • G
                    Gomalley @sdetweil
                    @sdetweil I was able to start up he mirror by doing
                    cd ~ /MagicMirror
                    npm start
                    The mirror started up like usual but it didn’t restart after I exited out of it.
                      sdetweil @Gomalley
                      @Gomalley ok, now try
                      pm2 list
                      If something is there, try
                      pm2 start ???
                      Where name is whatever was shown
                      If nothing, use my new script, see link in troubleshooting section
                      G 2 Replies Last reply Reply Quote 0
                      • G
                        Gomalley @sdetweil
                        pm2 list
                        gave me error messages so I ran the updated script and keeps coming up with an error for shelljs
                        pi@raspberrypi:~ $ pm2 list
                            throw err;
                        pi@raspberrypi:~ $ bash -c  "$(curl -sL  https://www.dropbox.com/s/cy2z7lbkpifcbrk/fixuppm2.sh?dl=0)"
                        bash: line 26: 1: command not found
                            throw err;
                            throw err;
                            at detectInitSystem (/usr/local/lib/node_modules/pm2/lib/API/Startup.js:50:11)
                            at API.CLI.startup (/usr/local/lib/node_modules/pm2/lib/API/Startup.js:186:27)
                            at Command.<anonymous> (/usr/local/lib/node_modules/pm2/bin/pm2:705:9)
                            at Command.listener (/usr/local/lib/node_modules/pm2/node_modules/commander/index.js:315:8)
                            at Command.emit (events.js:189:13)
                            at Command.parseArgs (/usr/local/lib/node_modules/pm2/node_modules/commander/index.js:651:12)
                            throw err;
                            throw err;
                        pi@raspberrypi:~ $
                        I’ve run into this “cannot find shelljs” error before
                        • G
                          Gomalley @sdetweil
                          Is it possibly the version of raspbian that is messing this up because it use to work before they released the latest version of raspbian and before MM 2.8 as well.
                            sdetweil @Gomalley
                            @Gomalley pm2 needs to be reinstalled, cause the npm version changed.
                            lets try my new pm2 fixup script…
                            I’ve added your problems to the list it handles
                            • G
                              Gomalley @sdetweil
                              Thank you! The mirror now autostarts!
                              So all this time I was doing it on a Lexar micro sd card. It actually froze on the startup page so I threw in a 16gb Ultra sandisk amd started the process all over.
                              Heres the steps that I followed:
                              pm2 logs
                              npm i -g npm
                              cd ~
                              sudo chown -R pi .
                              pm2 logs
                              npm i -g npm
                              sudo npm i -g npm
                              npm install
                              pm2 list
                              Thank you again for your help!
                                sdetweil @Gomalley
                                @Gomalley glad that it’s working.
                                My new installer might have avoided all the rework after git clone
                                  maxheartrate
                                  I am having the exact same problem: Black screen after 2.8 update. I followed all the suggestions you two came up with but my screen remains black.
                                  This is what I get after npm start:
                                  Starting MagicMirror: v2.8.0
                                  Loading config ...
                                  Loading module helpers ...
                                  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node_helper'
                                  App threw an error during load
                                      at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
                                      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                                      at Function.Module._load (internal/modules/cjs/loader.js:528:25)
                                      at Module.require (internal/modules/cjs/loader.js:658:17)
                                      at require (internal/modules/cjs/helpers.js:20:18)
                                      at Object.<anonymous> (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:6:18)
                                      at Object.<anonymous> (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:94:3)
                                      at Module._compile (internal/modules/cjs/loader.js:711:30)
                                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                                      at Module.load (internal/modules/cjs/loader.js:620:32)
                                  { Error: Cannot find module 'node_helper'
                                      at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
                                  Launching application.
                                  ^Cpi@raspberrypi:~/MagicMirror $
                                  pi@raspberrypi:~/MagicMirror $ npm stop
                                  npm ERR! missing script: stop
                                  npm ERR!     /home/pi/.npm/_logs/2019-08-08T12_50_44_769Z-debug.log
                                  pi@raspberrypi:~/MagicMirror $ pm2 stop mm
                                  [PM2] Applying action stopProcessId on app [mm](ids: 0)
                                  [PM2] [mm](0) ✓
                                  │ Name        │ id │ mode │ status  │ ↺ │ cpu │ memory │
                                  │ MagicMirror │ 1  │ fork │ stopped │ 0 │ 0%  │ 0 B    │
                                  │ mm          │ 0  │ fork │ stopped │ 1 │ 0%  │ 0 B    │
                                   Use `pm2 show <id|name>` to get more details about an app
                                  pi@raspberrypi:~/MagicMirror $ pm2 list
                                  pi@raspberrypi:~/MagicMirror $  pm2 start MagicMirror
                                  [PM2] Applying action restartProcessId on app [MagicMirror](ids: 1)
                                  [PM2] [MagicMirror](1) ✓
                                  [PM2] Process successfully started
                                  │ MagicMirror │ 1  │ fork │ online  │ 0 │ 0%  │ 2.5 MB   │
                                  > magicmirror@2.8.0 start /home/pi/MagicMirror
                                  > sh run-start.sh
                                  Loading config ...
                                  I also get the black screen when I start with ‘pm2 MagicMirror’ which was created by @sdetweil script and starting with my original command ‘pm2 start mm’.
                                  Looks really screwed up and since I have to admit that I am a noob I am lost.
                                  Any suggestions? Best, Max
                                    weird…
                                    node_helper is a special module provided by MM and part of the install package
                                    can u do
                                     ls ~/MagicMirror/node_modules/node_helper/
                                    it should display 1 file, index.js
                                    did u remove the node_modules folder?
                                    ps. I did that once, and had the same problem!
                                    try this
                                    git checkout -- node_modules/node_helper/index.js
                                    then try restarting MagicMirror
                                      maxheartrate @sdetweil
                                      Hi, thank you for your advise.
                                      shows me
                                      ls: Zugriff auf ‘/home/pi/MagicMirror/node_modules/node_helper/’ nicht möglich: Datei oder Verzeichnis nicht gefunden
                                      File or folder not found
                                      results in
                                      error: pathspec ‘node_modules/node_helper/index.js’ did not match any file(s) known to git.
                                        sdetweil @maxheartrate
                                        @maxheartrate ok. I am away from my system now for a couple days.
                                        Try
                                        git checkout -- node_helper/index.js
                                        If that fails, try
                                        git status
                                        Then rename your MagicMirror folder to something else, clone it again, and copy the node_modules/node_helper folder to your previous installation, and rename the new one, then the old one back
                                          maxheartrate
                                          Your two suggestions did not work. That is why I followed step 3: cloning MM again and copying node_helper to node_modules.
                                          I ran npm install in node_modules and in the MagicMirror directory.
                                          Now it looks like I got one error further … :flushed_face:
                                          This is what I get now:
                                          > sh run-start.sh
                                          Loading config ...
                                          WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '../../../js/class.js'
                                              at Object.<anonymous> (/home/pi/MagicMirror/node_modules/node_helper/index.js:8:13)
                                              at Object.<anonymous> (/home/pi/MagicMirror/node_modules/node_helper/index.js:127:3)
                                          { Error: Cannot find module '../../../js/class.js'
                                            @maxheartrate no. No npm install in the node_modules folder. That messes everything up.
                                            Do
                                            rm -rf node_modules
                                            cp -R -p ???/node_modules ~/MagicMirror
                                            Where ??? Is your recently cloned download.
                                            Then in the MagicMirror folder do
                                            npm install
                                            IF u had other modules installed, beyond the initial set, then look thru their folders and see if there is a package.json file present. If so, in each such module folder do a
                                            npm install
                                            there
                                            I made a new script to do all this upgrade stuff, but I don’t know what will happen if the git pull is already done.
                                            See my upgrade topic in the troubleshooting section
                                            • 2 / 3
