    After 2.8 I'm having tons of issues. What are the steps from square 1 to get this working?
    46 Posts 3 Posters 25.6k Views 3 Watching
    • G Offline
      Gomalley @sdetweil
      @sdetweil I was able to start up he mirror by doing
      cd ~ /MagicMirror
      npm start
      The mirror started up like usual but it didn’t restart after I exited out of it.
        sdetweil @Gomalley
        @Gomalley ok, now try
        pm2 list
        If something is there, try
        pm2 start ???
        Where name is whatever was shown
        If nothing, use my new script, see link in troubleshooting section
        G 2 Replies Last reply Reply Quote 0
        • G Offline
          Gomalley @sdetweil
          pm2 list
          gave me error messages so I ran the updated script and keeps coming up with an error for shelljs
          pi@raspberrypi:~ $ pm2 list
          [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
          internal/modules/cjs/loader.js:583
              throw err;
          Error: Cannot find module 'shelljs'
              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
              at Function.Module._load (internal/modules/cjs/loader.js:507:25)
              at Module.require (internal/modules/cjs/loader.js:637:17)
              at require (/usr/local/lib/node_modules/pm2/node_modules/v8-compile-cache/v8-compile-cache.js:161:20)
              at module.exports.Client.launchDaemon (/usr/local/lib/node_modules/pm2/lib/Client.js:244:7)
              at /usr/local/lib/node_modules/pm2/lib/Client.js:103:10
              at /usr/local/lib/node_modules/pm2/lib/Client.js:311:14
              at process._tickCallback (internal/process/next_tick.js:61:11)
          pi@raspberrypi:~ $ bash -c  "$(curl -sL  https://www.dropbox.com/s/cy2z7lbkpifcbrk/fixuppm2.sh?dl=0)"
          bash: line 26: 1: command not found
              throw err;
              throw err;
              at detectInitSystem (/usr/local/lib/node_modules/pm2/lib/API/Startup.js:50:11)
              at API.CLI.startup (/usr/local/lib/node_modules/pm2/lib/API/Startup.js:186:27)
              at Command.<anonymous> (/usr/local/lib/node_modules/pm2/bin/pm2:705:9)
              at Command.listener (/usr/local/lib/node_modules/pm2/node_modules/commander/index.js:315:8)
              at Command.emit (events.js:189:13)
              at Command.parseArgs (/usr/local/lib/node_modules/pm2/node_modules/commander/index.js:651:12)
              throw err;
              throw err;
          pi@raspberrypi:~ $
          I’ve run into this “cannot find shelljs” error before
          • G Offline
            Gomalley @sdetweil
            Is it possibly the version of raspbian that is messing this up because it use to work before they released the latest version of raspbian and before MM 2.8 as well.
              sdetweil @Gomalley
              @Gomalley pm2 needs to be reinstalled, cause the npm version changed.
              lets try my new pm2 fixup script…
              I’ve added your problems to the list it handles
              • G Offline
                Gomalley @sdetweil
                Thank you! The mirror now autostarts!
                So all this time I was doing it on a Lexar micro sd card. It actually froze on the startup page so I threw in a 16gb Ultra sandisk amd started the process all over.
                Heres the steps that I followed:
                pm2 logs
                npm i -g npm
                cd ~
                sudo chown -R pi .
                pm2 logs
                npm i -g npm
                sudo npm i -g npm
                npm install
                pm2 list
                Thank you again for your help!
                  sdetweil @Gomalley
                  @Gomalley glad that it’s working.
                  My new installer might have avoided all the rework after git clone
                    maxheartrate
                    I am having the exact same problem: Black screen after 2.8 update. I followed all the suggestions you two came up with but my screen remains black.
                    This is what I get after npm start:
                    Starting MagicMirror: v2.8.0
                    Loading config ...
                    Loading module helpers ...
                    WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node_helper'
                    App threw an error during load
                        at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                        at Function.Module._load (internal/modules/cjs/loader.js:528:25)
                        at Module.require (internal/modules/cjs/loader.js:658:17)
                        at require (internal/modules/cjs/helpers.js:20:18)
                        at Object.<anonymous> (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:6:18)
                        at Object.<anonymous> (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:94:3)
                        at Module._compile (internal/modules/cjs/loader.js:711:30)
                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                        at Module.load (internal/modules/cjs/loader.js:620:32)
                    { Error: Cannot find module 'node_helper'
                        at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
                    Launching application.
                    ^Cpi@raspberrypi:~/MagicMirror $
                    pi@raspberrypi:~/MagicMirror $ npm stop
                    npm ERR! missing script: stop
                    npm ERR!     /home/pi/.npm/_logs/2019-08-08T12_50_44_769Z-debug.log
                    pi@raspberrypi:~/MagicMirror $ pm2 stop mm
                    [PM2] Applying action stopProcessId on app [mm](ids: 0)
                    [PM2] [mm](0) ✓
                    │ Name        │ id │ mode │ status  │ ↺ │ cpu │ memory │
                    │ MagicMirror │ 1  │ fork │ stopped │ 0 │ 0%  │ 0 B    │
                    │ mm          │ 0  │ fork │ stopped │ 1 │ 0%  │ 0 B    │
                     Use `pm2 show <id|name>` to get more details about an app
                    pi@raspberrypi:~/MagicMirror $ pm2 list
                    pi@raspberrypi:~/MagicMirror $  pm2 start MagicMirror
                    [PM2] Applying action restartProcessId on app [MagicMirror](ids: 1)
                    [PM2] [MagicMirror](1) ✓
                    [PM2] Process successfully started
                    │ MagicMirror │ 1  │ fork │ online  │ 0 │ 0%  │ 2.5 MB   │
                    > magicmirror@2.8.0 start /home/pi/MagicMirror
                    > sh run-start.sh
                    Loading config ...
                    I also get the black screen when I start with ‘pm2 MagicMirror’ which was created by @sdetweil script and starting with my original command ‘pm2 start mm’.
                    Looks really screwed up and since I have to admit that I am a noob I am lost.
                    Any suggestions? Best, Max
                      weird…
                      node_helper is a special module provided by MM and part of the install package
                      can u do
                       ls ~/MagicMirror/node_modules/node_helper/
                      it should display 1 file, index.js
                      did u remove the node_modules folder?
                      ps. I did that once, and had the same problem!
                      try this
                      git checkout -- node_modules/node_helper/index.js
                      then try restarting MagicMirror
                        maxheartrate @sdetweil
                        Hi, thank you for your advise.
                        shows me
                        ls: Zugriff auf ‘/home/pi/MagicMirror/node_modules/node_helper/’ nicht möglich: Datei oder Verzeichnis nicht gefunden
                        File or folder not found
                        results in
                        error: pathspec ‘node_modules/node_helper/index.js’ did not match any file(s) known to git.
                          sdetweil @maxheartrate
                          @maxheartrate ok. I am away from my system now for a couple days.
                          Try
                          git checkout -- node_helper/index.js
                          If that fails, try
                          git status
                          Then rename your MagicMirror folder to something else, clone it again, and copy the node_modules/node_helper folder to your previous installation, and rename the new one, then the old one back
                            maxheartrate
                            Your two suggestions did not work. That is why I followed step 3: cloning MM again and copying node_helper to node_modules.
                            I ran npm install in node_modules and in the MagicMirror directory.
                            Now it looks like I got one error further … :flushed_face:
                            This is what I get now:
                            > sh run-start.sh
                            Loading config ...
                            WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '../../../js/class.js'
                                at Object.<anonymous> (/home/pi/MagicMirror/node_modules/node_helper/index.js:8:13)
                                at Object.<anonymous> (/home/pi/MagicMirror/node_modules/node_helper/index.js:127:3)
                            { Error: Cannot find module '../../../js/class.js'
                              @maxheartrate no. No npm install in the node_modules folder. That messes everything up.
                              Do
                              rm -rf node_modules
                              cp -R -p ???/node_modules ~/MagicMirror
                              Where ??? Is your recently cloned download.
                              Then in the MagicMirror folder do
                              npm install
                              IF u had other modules installed, beyond the initial set, then look thru their folders and see if there is a package.json file present. If so, in each such module folder do a
                              npm install
                              there
                              I made a new script to do all this upgrade stuff, but I don’t know what will happen if the git pull is already done.
                              See my upgrade topic in the troubleshooting section
                                maxheartrate
                                Hi @sdetweil, thanks for joining in and for your advise.
                                I followed your steps just as described. The node_helper was the only module in the newly cloned node_modules folder. I then ran npm install and an npm install in every modules folder with a package.json file.
                                After that I ran into the missing node_helper error again. Obviously the folder was deleted when I ran the npm install in the MagicMirror folder. Now I copied the node_helper folder from the newly cloned version again and I am back at the error I sent in my previous post. :dizzy_face:
                                  @maxheartrate
                                  No it won’t be deleted.
                                  Let’s start from scratch. U have the extra downloaded copy. Make THAT NAME MagicMirror, and npm install in that folder.
                                  Start mm and we should be running.
                                  Then we will copy over your extra modules, and config file
                                  And work from there
                                    maxheartrate
                                    Alright. Now I have something else but a black screen for the first time in days:
                                    “Magic Mirror - please create a config file”
                                    What do you suggest now?
                                      @maxheartrate
                                      And work from there
                                        That’s what I did. I have a fresh MagicMirror now. It is running but can’t find the config file (I haven’t copied config.js.sample to config.js yet).
                                          @maxheartrate you have to do that, copy the config
                                            @maxheartrate I really want you to run my updated install script…if I can only find the topic with the link!
                                            See the second post here
                                            https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
                                            • 2 / 3
