    After 2.8 I'm having tons of issues. What are the steps from square 1 to get this working?
    46 Posts 3 Posters 22.7k Views 3 Watching
    • G Offline
      Gomalley @sdetweil
      pi@raspberrypi:~ $ pm2 logs
      [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
      internal/modules/cjs/loader.js:583
      throw err;
      Error: Cannot find module ‘shelljs’
      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
      at Function.Module._load (internal/modules/cjs/loader.js:507:25)
      at Module.require (internal/modules/cjs/loader.js:637:17)
      at require (/usr/local/lib/node_modules/pm2/node_modules/v8-compile-cache/v8-compile-cache.js:161:20)
      at module.exports.Client.launchDaemon (/usr/local/lib/node_modules/pm2/lib/Client.js:244:7)
      at /usr/local/lib/node_modules/pm2/lib/Client.js:103:10
      at /usr/local/lib/node_modules/pm2/lib/Client.js:311:14
      at process._tickCallback (internal/process/next_tick.js:61:11)
      pi@raspberrypi:~ $ npm -v
      6.10.2
      pi@raspberrypi:~ $
      This is what happened when I did pm2 logs and npm -v. I am about to see what npm i -g npm will do
      • G Offline
        Gomalley @sdetweil
        pi@raspberrypi:~ $ npm i -g npm
        npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules/npm
        npm ERR! path /usr/local/lib/node_modules/npm
        npm ERR! code EACCES
        npm ERR! errno -13
        npm ERR! syscall access
        npm ERR! Error: EACCES: permission denied, access ‘/usr/local/lib/node_modules/npm’
        npm ERR! { [Error: EACCES: permission denied, access ‘/usr/local/lib/node_modules/npm’]
        npm ERR! stack:
        npm ERR! ‘Error: EACCES: permission denied, access '/usr/local/lib/node_modules/npm'’,
        npm ERR! errno: -13,
        npm ERR! code: ‘EACCES’,
        npm ERR! syscall: ‘access’,
        npm ERR! path: ‘/usr/local/lib/node_modules/npm’ }
        npm ERR!
        npm ERR! The operation was rejected by your operating system.
        npm ERR! It is likely you do not have the permissions to access this file as the current user
        npm ERR!
        npm ERR! If you believe this might be a permissions issue, please double-check the
        npm ERR! permissions of the file and its containing directories, or try running
        npm ERR! the command again as root/Administrator (though this is not recommended).
        npm ERR! /home/pi/.npm/_logs/2019-08-05T19_21_26_414Z-debug.log
          sdetweil @Gomalley
          @Gomalley go old sudo screws thing up again…
          cd ~
          sudo chown -R pi .
          Then try again…
          • G Offline
            Gomalley @sdetweil
            @sdetweil this is what happened when I typed in the command
            pi@raspberrypi:~ $ sudo chown -R pi
            chown: missing operand after ‘pi’
            Try ‘chown --help’ for more information.
              sdetweil @Gomalley
              @Gomalley there was a dot at the end, it was important
              • G Offline
                Gomalley @sdetweil
                Sorry, I missed that.
                pi@raspberrypi:~ $ cd ~
                pi@raspberrypi:~ $ sudo chown -R pi .
                pi@raspberrypi:~ $
                It just went to the next line. Not sure why
                  sdetweil @Gomalley
                  @Gomalley it doesn’t say anything, it just changes ownership of everything in the home folder and down to the user pi.
                  Now, back to what u were doing before
                  • G Offline
                    Gomalley @sdetweil
                    I tried to excute some of the commands you gave me
                        throw err;
                    Error: Cannot find module 'shelljs'
                    npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules/npm/node_modules
                    npm ERR! errno -13
                    npm ERR! Error: EACCES: permission denied, access '/usr/local/lib/node_modules/npm'
                    npm ERR!  { [Error: EACCES: permission denied, access '/usr/local/lib/node_modules/npm']
                    npm ERR!   stack:
                    npm ERR!    'Error: EACCES: permission denied, access \'/usr/local/lib/node_modules/npm\'',
                    npm ERR!   code: 'EACCES',
                    npm ERR!   syscall: 'access',
                    npm ERR!   path: '/usr/local/lib/node_modules/npm' }
                    npm ERR!
                    npm ERR!
                    npm ERR!     /home/pi/.npm/_logs/2019-08-06T18_59_40_902Z-debug.log
                    pi@raspberrypi:~ $
                    I ran “pm2 logs” and “npm i -g npm”
                    Looks like I got similar results. Should I do
                    npm install
                    In the MagicMirror folder now?
                      sdetweil @Gomalley
                      @Gomalley no. Looks like u installed npm w sudo(root)
                      So, short term do
                      sudo npm i -g npm
                      • G Offline
                        Gomalley @sdetweil
                        @sdetweil Sweet I think that worked
                        pi@raspberrypi:~ $ sudo npm i -g npm
                        /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                        /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                        + npm@6.10.3
                        updated 3 packages in 128.39s
                        pi@raspberrypi:~ $
                        Now that I have done that, Should I run
                        npm install
                        and then:
                        cd ~/MagicMirror
                        npm install
                        • 2 / 5
