    Add JS Code to the Mirror
    33 Posts 5 Posters 15.3k Views 5 Watching
      dnj0104
      I added your code snippet in 1st line after
      var mpd = require('mpd'),
      and output
      [2020-10-24 01:56:54.490] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/modules/mpd_client/node_helper.js:1
      var mpd = require('mpd'),const NodeHelper = require("node_helper");
      SyntaxError: Unexpected token const
          at Module._compile (internal/modules/cjs/loader.js:722:23)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
          at Module.load (internal/modules/cjs/loader.js:645:32)
          at Function.Module._load (internal/modules/cjs/loader.js:560:12)
          at Module.require (internal/modules/cjs/loader.js:685:19)
          at require (internal/modules/cjs/helpers.js:16:16)
          at loadModule (/home/pi/MagicMirror/js/app.js:134:17)
          at loadNextModule (/home/pi/MagicMirror/js/app.js:169:5)
          at /home/pi/MagicMirror/js/app.js:171:6
          at Class.loaded (/home/pi/MagicMirror/js/node_helper.js:18:3)
        sdetweil @dnj0104
        @dnj0104 no, I want it to be a line BEFORE the stuff in the file already
          dnj0104
          AH! Sorry!
          Changed it now your snippet in 1st Line
          And we have Success!!! Finally!!
          Thanks Alot @sdetweil
          • 4 / 4
