    Add JS Code to the Mirror
    33 Posts 5 Posters 13.3k Views 5 Watching
      sdetweil @dnj0104
      @dnj0104 can you do
      cd ~/MagicMirror
      grep version package.json
        dnj0104
        yes and and result is
        pi@raspberrypi:~/MagicMirror $ grep version package.json
        	"version": "2.13.0",
          @dnj0104 yeh, mess
          this module should be installed like this to make up for the name problem
          cd ~/ MagicMirror/modules
          git clone https://github.com/timjong93/MMM-MPD.git mpd_client
          cd mpd_client
          npm install
          then everything matches
            sdetweil @dnj0104
            @dnj0104 thanks… so the git checkout would not have worked, sorry…
            try the install as I suggest above
              dnj0104 @sdetweil
              so then i throw mpd client folder in trash and follow your
              install instructions?
              because I believe there have been a problem when I first installed mpd_client, I did not been clear where the npm install should been placed, if you read in mpd-client readme.md maybe you understand, english is not my first language, and my linux-fu is below first grade :)
                sdetweil @dnj0104
                @dnj0104 is ok, he didn’t do the instructions correctly…
                yes, start over
                cd ~/MagicMirror/modules
                rm -rf mod_client
                then do the install as I suggested
                  dnj0104
                  and then change folder name to mod-client ?
                  is it mod-client (folder) and mod_client in config.js in config array. do I also change name in mpd-client.js file?
                    sdetweil @dnj0104
                    @dnj0104 everythign should be named mpd_client
                    look at the files list in the module
                    all mpd_client
                    no, do NOT change the folder name, change the config.js to match
                    module: 'mpd_client',
                      dnj0104 @sdetweil
                      @sdetweil said in Add JS Code to the Mirror:
                      mpd_client
                      ok then
                      fresh install and download after your instructions:
                      [[ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
                          at Object.<anonymous> (/home/pi/MagicMirror/modules/mpd_client/node_helper.js:4:18)
                          at Module._compile (internal/modules/cjs/loader.js:786:30)
                          at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                          at Module.load (internal/modules/cjs/loader.js:645:32)
                          at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                          at Module.require (internal/modules/cjs/loader.js:685:19)
                          at require (internal/modules/cjs/helpers.js:16:16)
                          at loadModule (/home/pi/MagicMirror/js/app.js:134:17)
                          at loadNextModule (/home/pi/MagicMirror/js/app.js:169:5)
                          at /home/pi/MagicMirror/js/app.js:171:6
                      [2020-10-24 01:33:46.979] [LOG]    Loading module helpers ...
                      [2020-10-24 01:33:46.980] [LOG]    No helper found for module: alert.
                      [2020-10-24 01:33:46.981] [LOG]    Initializing new module helper ...
                      [2020-10-24 01:33:46.982] [LOG]    Module helper loaded: updatenotification
                      [2020-10-24 01:33:46.983] [LOG]    No helper found for module: clock.
                      [2020-10-24 01:33:46.984] [LOG]    Initializing new module helper ...
                      [2020-10-24 01:33:46.985] [LOG]    Module helper loaded: calendar
                      [2020-10-24 01:33:46.986] [LOG]    No helper found for module: .
                      [2020-10-24 01:33:46.988] [LOG]    No helper found for module: currentweather.
                      [2020-10-24 01:33:46.990] [LOG]    No helper found for module: weatherforecast.
                      [2020-10-24 01:33:46.991] [LOG]    Initializing new module helper ...
                      [2020-10-24 01:33:46.992] [LOG]    Module helper loaded: newsfeed
                      [2020-10-24 01:33:46.994] [ERROR]  App threw an error during load
                      [2020-10-24 01:33:47.003] [ERROR]  ReferenceError: NodeHelper is not defined
                      [2020-10-24 01:33:47.006] [ERROR]  Whoops! There was an uncaught exception...
                      [2020-10-24 01:33:47.007] [ERROR]  ReferenceError: NodeHelper is not defined
                      [2020-10-24 01:33:47.014] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      [2020-10-24 01:33:47.014] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                      [2020-10-24 01:33:49.707] [LOG]    Launching application.]
                      something wrong with nodehelper I believe.
                      Or maybe I have wrong port and IP to my mpd.
                        sdetweil @dnj0104
                        @dnj0104 bad module,
                        edit the node_helper.js
                        and add this as the 1st line
                        const NodeHelper = require("node_helper");
                        • 3 / 4
